| Streetfighter Joined: Sep 2007 From: Seattle, WA I Ride: the walk | dusty out there! chest cam and rekluse for me.. Finally got around to mounting GoPro on my chest protector. I really like the footage but something needs to be done with sound. The Camelback hose that's dangling down there as well as generally the chest protector are producing all sorts of creeks and knocks. Anybody got ideas/experience? Looks to me external mic or changing chest protector are the only options, which means it'll just stay as is for now ![]() Also finally got around to trying an auto clutch. Long time coming, scored an EXP 2.0 off eBay and rode for the first time. In the beginning had some trouble figuring out which gear am I in, and also I'm riding my crf250 like it's a 2-stroke and normally using clutch a whole lot. So it took an hour or so to wrap my head around it. So far I see two major benefits, the obvious one of not ever stalling even after falling over. Second one, specifically on those clear cut trails at Tahuya I was always annoyed by having to click between 2nd and 3rd gear a lot, and a lot of times it was awkward or I was too slow to react etc. Now I can just keep it in 3rd for the most part and rely on the clutch to pull through. Ok so there's some clutch abuse going on but for the most part, at least at my skill level, simply knowing that I can get on the gas and not worry about fanning the clutch just right makes me go faster enough that I'd be "eligible" for 3rd gear anyway. Bottom line, auto clutch stays in and I don't think I want to ride without it anymore. Specifically EXP 2.0 took me all of maybe 15 minutes to install and there were no any other adjustments needed, it "just works". Manual clutch override still works just fine as long as engine revs are above idle. Design is a bit of a compromise since it eliminates 2 (out of what 7 or Never mind my spaz riding style, here's the chest cam sample |
| Streetfighter Joined: Sep 2007 From: Seattle, WA I Ride: the walk | It's one of the typical clear cut snakes south of Tahuya Rd.. My opinion isn't worth much on wheelies, rolling off the trottle instead of using the rear brake doesn't work for balance wheelies obviously, otherwise manual clutch works exactly like it did without the Rekluse except the lever pull is a bit harder since they make you install stiffer clutch springs. |
| Retired Joined: Feb 2005 From: s. greenlake bitch I Ride: KTM 625 smc | TL1000S/R | wr450 | CB350 | CRF50/88 | TTR50 | your mom | I didn't really like the chest rig.. you should try some different camera angles.. Also using the open back cover helps sound work better, vs the waterproof case. |
| | #9 | |
| Knee Dragger Joined: Sep 2007 From: 2nd star to the right and straight on 'til morning I Ride: on ice at 15F below zero. GO ICEHOLES!!! | using a rekluse is cheating. They sure do make riding easier, I guess I just prefer the challenge of using the left hand lever. If I was racing a dirtbike regularly (instead of using it for physical training) I would probably have one |
| Knee Dragger Joined: Sep 2007 From: 2nd star to the right and straight on 'til morning I Ride: on ice at 15F below zero. GO ICEHOLES!!! | Agreed, I always thought that made a lot of sense. Well.... Broke the thumb metacarpal into 3 pieces, surgery (done) 3 pins in place, swelling is finally down so the pins get pulled friday and I get a hard cast for the next 4-6 weeks. (they say 6, but I will probably pull it off myself after 4-5) Race season over. (not too bad of a year if you don't count the shortened season part) If I could ride I would, but my hand is basically out of commission for a while. I really wish I could have ridden with you and Mike,I have never been on a road course with him. Next time. Sounded like you guys were having a blast. I hope to make the Iceholes weekend!!! |
| Retired Joined: Feb 2005 From: s. greenlake bitch I Ride: KTM 625 smc | TL1000S/R | wr450 | CB350 | CRF50/88 | TTR50 | your mom | allister come ride some dirt when your patched up... ALSO invite me to iceholes (both of you) I wanna check it out! |
| Licensed Joined: Feb 2011 From: tacoma I Ride: kx450f | here is some of my single track from this weekend with some track also. I have a kx450f with a rekluse z-start pro... |
| | #15 | |
![]() Mike bought that GSXR, so we will be at the OPRT day at PR next Wednesday, you could always bring us some beer and keep us company in the pits? | |
| Novice Racer Joined: Apr 2009 From: Renton, WA I Ride: 05 KTM450SMR, 04 YZF250 and one bad ass Truck hehe | ![]() ![]() and Shhhhh Pete ![]() |
| Knee Dragger Joined: Sep 2007 From: 2nd star to the right and straight on 'til morning I Ride: on ice at 15F below zero. GO ICEHOLES!!! | ![]() Well... not actually... my damn triple clamps came loose and the fork tubes moved up (alot) and the dang bike was unrideable, I was having a super hard time running at pace and keeping it on the trail... Didn't realize what had happened until I was looking at the bikes in the garage and noticed the tubes sticking up about 1-1/2" above the top triple. Damn. I just might do that , but since I won t be riding there is a serious possibility that there will not be any beer left at the end of the day. |
| Streetfighter Joined: Sep 2007 From: Seattle, WA I Ride: the walk | ![]() What about using electric starter? Or fuel injection? Or the ultimate cheat of all times, 2 less strokes? |
| | #20 | |
No worries on the beer, we'll be prepared too. | |
