Old 01-04-2010, 08:05 AM   #61
trailgoon's Avatar
I Ride: 05 SV650, 12 F650GS, 07 450 EXC, 07 200 XC-W, 05 Beta Rev3 270, 89 TRX 310R
Originally Posted by Rick View Post
The OSU Gas pumps at Motor Pool is another option. It is on Campus Way bewteen 30th and 35th.
Thanks everyone for all the offers/replies.
Rick, you just sparked my memory there is also a free line on the SE corner of the Dixon rec center. I completely forgot about this, even though I've used it on multiple occasions.
Old 01-04-2010, 09:05 AM   #62
Race Qualifier
dwschultzy's Avatar
Originally Posted by james1300 View Post
The OP asked for FREE.
no shit mr weather man
i was simply explaining how long they tend to run
but yes....i can see how $.75 is going to break the bank and i am completely wrong to suggest someone to cough up a life savings to obtain something as simple as air
i mean.....what sick fuck charges other people for air?
Old 01-04-2010, 10:04 AM   #63
Osufireman's Avatar
I Ride: 1991 Kawasaki ZX-6
Not sure of Corvallis area, but if you're just a bit north in Monmouth, I'm pretty sure the Shell station right on Hwy99 still has free air. Not close, but an option if you're up north by 20 miles
Old 01-07-2010, 05:39 PM   #64
smilin jack's Avatar
I Ride: DR650 & CB250 Adventure bike
Aluminum sheet metal
Originally Posted by tbolt View Post
I'm looking for a local source of aluminum sheet 1/16" thick. More specifically, I need a piece that's 3in by 3.5in. Bigger is fine since I can have it cut down to size.
I've checked Home Depot and Robnett's, but the closest they have is 1.5in wide bar stock.
Thank you kindly!
Check the heating/plumbing shop in Corvallis downtown next to the tracks... about two blocks north of Western. Middleton is the name, and they have lots and will cut to size and bend for you.
They have stainless and copper sheet too.
Dave
Old 01-11-2010, 10:14 AM   #65
tbolt's Avatar
I Ride: SV650, part deux
Dave
Dave, great tip, thanks!!
(Sorry I missed you guys at bike night this month. I was enjoying the sunshine in Colorado.)
Old 02-25-2010, 08:06 AM   #66
tbolt's Avatar
I noticed a hissing noise coming from the new bike when parked after a ride... traced it to the gas cap. Sounds like something (vapors? magic fog? mojo?) is seeping out around the key hole on the cap.
Do I have a venting issue, or is this ok. I don't recall the old SV doing this.
Old 02-25-2010, 09:31 AM   #67
I Ride: '05 Triumph Tiger 955i
I don't know if the SV has a vent hose under the tank but you may want to lift the tank and make sure if it has one that it isn't pinched/blocked. Otherwise, open the tank to vent the tank and see if it does it again after another ride.
Old 02-25-2010, 10:14 AM   #68
10guy's Avatar
I Ride: Misty
Is your SV fuel injected?
It is common for newer bikes to be vented around the key hole, if yours is and you are hearing it it might not be venting properly.
Did the bike run OK on your trip home?
Old 02-25-2010, 10:32 AM   #69
tbolt's Avatar
Opening the cap stops the hiss, but it returns after the next ride.
Yep, it's FI, and it's running just fine.
However, I think I may have found the answer... something to do with crazy hippie CA emissions shit. The cap is apparently different on CA bikes.
Old 02-25-2010, 10:49 AM   #70
10guy's Avatar
I Ride: Misty
That is a vent you are hearing, not positive but it doesn't seem like CA would allow venting into the atmosphere like that.
On the way home did you run a longer stretch like an hour and a half or more? If you did and the bike didn't start to run like crap then it is venting properly.
Is there a tiny hole next to the key hole on the cap?
You should be able to tell if your bike is a CA or not by the vin #.
Old 02-25-2010, 01:07 PM   #71
trailgoon's Avatar
My 05 SV hisses/whistles all the time. Sometimes its after a ride, other times from sitting out in the sun. I just pop the cap (it pops up a little from the pressure when released). My bike runs fine, I don't think its anything to worry about.
Old 02-25-2010, 09:29 PM   #72
hrothgarbike's Avatar
I Ride: Is it raining? Not the shiny one!
Put some bubble gum on it. It will stop the hiss and smell good!
Old 02-26-2010, 07:49 AM   #73
tbolt's Avatar
Ha!
Thanks for the confirmation, Trailgoon.
From the forums, it looks like some SVs are special in this way and others aren't, but CA bikes are more frequently special than others.
Old 03-09-2010, 09:20 PM   #74
Brian_M's Avatar
I Ride: 2006 Suzuki DR-Z400SM
Hey does anyone have a motion pro chain breaker/riveter tool on hand? I've actually got the tool but the threads on the inside of the alignment bolt are partially stripped so the tool is basically useless. I just need need the alignment bolt to put my new chain on (already got the old one off).
Old 03-10-2010, 06:26 AM   #75
I got the little $20 chain tool. I think you need the $110 one, assuming you need the riveter.
Old 03-10-2010, 07:53 AM   #76
trailgoon's Avatar
I've got a "home made" Chain Press riveter, My dad built it for replacing the 520 chain on my 750 Honda shadow Spirit.
Corvallis / Albany
The center pin can be removed to press the the plates down together, and then with the pin in it can be used to swage the heads of the master link. When using it on my shadow we put enough pressure on the pins of the master link with a good seal that the grease inside the heads of the pins literally exploded.
let me know if you'd like to use it.
Disclaimer: By using this tool you understand that you are responsible for the results and improper use could lead to improper chain connection. Improper chain connection could lead to an accident, in which you could experience serious injury or death. I am in no way responsible or liable for any accidents, injuries, or deaths from or related to your use of my tool.
Old 03-12-2010, 10:48 PM   #77
10guy's Avatar
I Ride: Misty
I've heard good things about Jonus in Philomath at Independent Motorcycle, never used him myself though. He is a good guy to ride with if that means anything.
Old 03-12-2010, 10:49 PM   #78
QCD
QCD's Avatar
I Ride: GSX-R 750 K9 and '03 BMW K1200GT
Lightbulb
Independent Motorcycle Repair
1623 Main St
Philomath, OR 97370
541-929-6493
Jonas will take care of you
(pronounced Yo-nas)
Old 03-13-2010, 06:01 AM   #79
Originally Posted by damadiel View Post
do you guys know a good shop thats reasonably priced for service , i want to get the fluids changed out and all that stuff since i just bought the bike and not sure when last owner last had it done , i know power yamaha dose it but thats a long drive from here in tangent lol but its a nice one thanks for any info
chris
bike is 06 650r Ninja
Changing the oil and flushing the radiator is pretty easy self maintenance stuff that you should learn to do yourself. (Chain lubrication, tire pressure and battery maintenance is another.) Think of it as a bonding experience to get to know your new bike. Brake fluid change is a little trickier and may need someone to teach you, otherwise Jonas is your man and the #1 choice among local forum members.
Old 03-13-2010, 10:01 AM   #80
thesomberlainv70's Avatar
I Ride: like a tidy cat.
Paint Gun Query (attn .Brandon?)
If anyone has a paint gun they would be willing to loan or assist in using I'd be interested. I think Brad is snickering at my dive flag cowl.....although it did hold up under a few moments scrutiny as being OEM I'd like to match the white/red lines of my fuel tank to the red cowl.
  PNW Riders > Oregon Riders > Eugene Region > Corvallis / Albany
