| Zone Head Joined: Feb 2008 From: Olympia, WA I Ride: Kawasaki zx14 | Problems with chain What are you all using to clean your chain. I have 11.2k miles on my bike in about a year and a half, and my chain has one link that has seized. It goes around the sprockets, but then is cok-eyed and I think it's making the chain bounce up and down when I'm riding (I have checked and rechecked, and it is adjusted for slack properly). I have spent multiple times cleaning it with wd40 for 30+ minutes at a time, but I can't get it right. I neglected my chain for about 3k miles once and the chain hasn't really recovered I don't think. I simply don't believe that wd40 is bad for the o-rings because oly zx12 guy got something like 40k miles out of a chain with ONLY wd40 if I remember correctly. What is the secret for chain cleaning and lubing perfection? |
| | #2 | |
| Pit Crew ![]() Joined: Jun 2008 From: Portland Oregon I Ride: 01 Speed Triple/Suzuki RF900 95 | ![]()
Are you oiling the chain when it is warm or cold? You ride in the rain alot? Leave the bike outside alot? How often did you adjust and lube the chain? How are you applying the oil? | |
| Pit Crew Joined: Aug 2007 From: medford, OR. I Ride: 06 R1/ 06 CRF450R and single moms! | WD-40, WD-40, more WD-40 and a brush to get the grime off. Then finish off with chain lube. At 11K of hard riding under the right conditions will kill a chain. Lots of water(wash your bike a lot?) or dust/grime. If WD-40 and chain lube won't get rid of the kink in a few rides it or make it better then it is there to stay... |
| Streetfighter Joined: Jan 2009 From: Federal Way I Ride: 2 wheeled ones | Once a link has seized it is almost impossible to "unkink" it. It probably has some galling on the metal itself and your only real choice is to replace the chain. Sorry |
| MotoGP Champion Joined: Sep 2005 From: Bremerton I Ride: 03 Are See fiddy one, 05 DRZ400SM, 95 FZR1040, 69 Combat Commando Roadster, 73 Commando Interstate, 67 BSA B44, 71 BSA B50 | Two ways to check if the chain is beyond it's service life. Pull the chain off the rear of the sprocket. Can you lift it much? How much side play is there on the top run. Chains wear by developing slop in the pins and bushings. O ring chains are lubed at the factory. You aren't going to get any more lube in past the orings. All you can do is clean it with WD40. I use a Pro Oiler on my 1040 FZR and get 25k to 30k out of a chain. If you have a seized link it's time for a new chain. The key to long chain life is not lubing it, but keeping it clean. |
| MotoGP Champion Joined: Sep 2005 From: Bremerton I Ride: 03 Are See fiddy one, 05 DRZ400SM, 95 FZR1040, 69 Combat Commando Roadster, 73 Commando Interstate, 67 BSA B44, 71 BSA B50 | Whaddya think is in WD40?????????????? |
| Superbiker | Last edited by mikefsu; 07-01-2009 at 06:35 AM.. |
| WMRRA Qualifier Joined: Oct 2006 From: north bend,wa I Ride: 09 ninja 500, 08 crf230l,ZX-14 | Water Displacement 40's main ingredient is fish oil. It's great for taking the stickers off your bike. I also used it on a yellowjackets nest yesterday, works great. I used it without a match. Last edited by busatim; 07-01-2009 at 06:38 AM.. |
| Zone Head Joined: Apr 2007 From: Out of your mind I Ride: like it’s gonna rain tomorrow. | WD40 for the past 2+ years with no issues. 30 mins. of cleaning with WD.... that just might be your problem. I go around the chain twice and then wipe it down with a rag until it's close to spotless... we're talking 10 mins. tops. Once I'm done with that I apply the chain wax and it's all good. |
| Picture Whore Joined: Apr 2008 From: TACOMA / 253 I Ride: my bikes...and all my friends bikes lately | fyi. bled the dizzer and read brake works betta ur just mad that BOTH ur bikes are broke... ![]() |
| Superbiker Joined: Jul 2006 From: Thurston County, WA. I Ride: GSXR1000 | REPLACE THE CHAIN! Keep in mind WD40 is a penetrating oil. Although it does break the grease and grime down so the chain becomes sparkling clean, it also will penetrate around the orings and dilute the grease which is packed between the pin and bushing. If it works for you, keep using it but I wouldn't recommend it. If you want to keep your chain in good working order, use kerosene, diesel or a chain cleaner such as Motorex 611 chain clean (Which I use and it works great) |
| | #16 | |||
| Zone Head Joined: Feb 2008 From: Olympia, WA I Ride: Kawasaki zx14 | Thanks for the replies everyone!!!! ![]()
I never ride in the rain, I hate it. My bike has only stayed outside once in its lifetime. It stays in a garage. mnfr recommends checking the chain every 600 miles. I had to do it more often than that at first because the zx14 stretches chains for the first 5000 miles and it was always needing tightened. I apply the oil by putting it on a rear stand and spray it on the middle as the chain is going around, and then a little on the outside. ![]() ![]()
| Endorsed Joined: Jan 2009 From: Kingston, WA I Ride: 2007 Honda Rebel (for sale), 2005 Suzuki C50 | A timely thread for myself. I just hit 3k on the odometer and nagged the wife to dig out the manual to see if it needed anything. I cringed when I saw the chain needed cleaned/lubed/whatever every 500 miles and she had no idea if the chain had ever been lubed since she bought the bike (over a year before I met her). I was just going to just spray it down with Bel-Ray chain lube but I see I'm going to have to work on it with a brush and cleaner product first. |
| Training Wheels Joined: Oct 2007 From: Snohomish I Ride: '82 Suzuki GS1100E & '95 GS500E - '07 BMW K1200R Sport | I clean the chain on the Suzuki every 1,500 miles or so with kerosene, followed with PJ1 Blue label chain lube. This is my short range bike, so it doesn't have to be done very often. I used to not clean so often, but I don't ride this one as much anymore, so I can afford to keep it clean. ![]() Picture from a year ago, just after cleaning, but coincidently, I cleaned the chain again yesterday. Shaft drive on the long range beemer Last edited by denydog; 07-01-2009 at 10:10 AM.. |
| | #20 | |
| Zone Head Joined: Feb 2008 From: Olympia, WA I Ride: Kawasaki zx14 | ![]()
| Training Wheels Joined: Oct 2007 From: Snohomish I Ride: '82 Suzuki GS1100E & '95 GS500E - '07 BMW K1200R Sport | It's not too bad for 27 years and 36,000 miles (bike, not the chain). But I owe it all to chain maintenance! btw- Don't see too many 630 chains anymore. D.I.D 630 Pro V is the one I've found. |
| Zone Head ![]() Joined: Jan 2008 From: teh rock | You don't need to take the chain off and put it in a bucket with kerosene. Put some kerosene in a $1.50 spray bottle and use it just like you would with the expensive spritz juice. |
| Je Fa Fa Joined: Mar 2007 From: Lynnwood, WA I Ride: 08 naked SV650 | ![]() or a paint brush... or a turkey baster/eye dropper... I unkinked a chain with wd-40 once... it was a neglected chain that just needed a bit of love... |
| Streetfighter Joined: Aug 2005 From: Spokane I Ride: Busa. | Well if the kink is your main issue, I would not take any chances Just replace it. To take care of a chain, I use a rag and just moist it with goof off then I rub the outsides of the chain, not letting the towel touch the inner roller. You can do this while the bike is on the stand and roll the wheel, it takes about 5 mins to clean the outside links. Make sure you DO NOT put too much goof off on the towel so it drips on the O-rings, only apply just enough to let it do its job. Then you need to take the bike out and ride it for a bit to warm up the chain. come back home and put it on the stand and lube it with real chain lube, I use http://www.belray.com/media.fsp?id=1297. You do not need to hit the outside of the chain when lubing, the only parts you need to hit is the roller bearing and the O-ring cavity top and bottom of the chain. Remember The chain is under a extreme amount of stress and to cheap out on lube could cost you plastic, rims, chain covers, tiers or even a bike. So a 10.00$ can of lube is cheap insurance. Besides a can of proper lube will last along time. 300-600mi Lube chain This depends on how hard you are riding and how dry/dirty the lube currently on there is looking. Last edited by Degenerate; 07-01-2009 at 11:48 AM.. |
| MotoGP Champion | I have had a problem with a kinked link many times. I have always found the culprit to be the master link. I have replaced the master link when it begins to kink and the chain runs fine until the master kinks again. Perhaps they aren't sealed as well as the other links. Perhaps the clip or the press (depending on type) does not provide the same contact pressure. I've also noticed that masters will tend to stretch more than the other links, making them no longer seat between the sprocket teeth. This will make it jump around. |
| | #27 | |
| Track School Dazed ![]() Joined: Oct 2005 From: CENTRAL I Ride: When I can | ![]()
You use a 'Grunge Brush' to clean the chain on the bike. You dont need to remove the chain from the bike to clean it. Kerosene, YES! Diesel, NO! 'Great success'? No chain maker recommends WD40 or Diesel to clean O/X ring chains. Your chain 'failed' using WD40 as a cleaner, My VStrom 650's chain failed, because the prior owner used WD40 as a cleaner. 18K. My R1 Yamaha has the ORIGIONAL chain on it. 22K and still looking great. I clean using Kerosene and a 'Grunge Brush', available at most Dirt bike shops. I also use a WAX type chain lube, and lube every 500 miles or 200 if Im riding in the rain. | |
| | #28 |
| Streetfighter Joined: Jul 2007 From: Bellingham, Washington I Ride: Two-up and slower then a snail | i use a grunge brush and kerosene every 2-3k miles, just the brush every 300-500. I then use silkolene white graphite lube. I don't use wax because it tends to fling. Manufacturers do not recommend using wd-40 because it degrades the rubber on the O/X rings. I can also cause seized rings because it will displace the ring. The way I would get the seized ring out is to cut the link out. You can pick up another master link (clip or rivet style) to put the chain back together again. Make sure to readjust the chain tension. You can only really do this after the chain has streched out quite a bit. |
| | #29 |
| Superbiker Joined: Dec 2005 From: Bellevue, WA I Ride: a 2006 H-D XL1200C, 2005 Suzuki DRZ-400SM, 1997 Kawa Ninja 500R, and 2003 Yamaha YZF-R6 (racebike). | ![]() That's playing with fire! ![]() |
| | #31 |
| Training Wheels Joined: May 2008 From: Bellevue I Ride: 07' Yamaha | Dude go to any motorcycle store ask for SPRAY chain cleaner http://images.google.com/imgres?imgu...IM7elQfOk9HaDQ its like $12 youll spend 15min and your chain and sprocket will look like new, dont forget chain lube!!!!!!!!!!!! Good stuff |
| | #33 | |
| WMRRA Qualifier Joined: Jan 2008 From: Warrenton, Oregon I Ride: 2004 Yamaha R1 | ![]()
![]() This stuff works great for lubrication. It's about $5 at Lowes. ![]() | |
| | #34 |
| Zone Head Joined: Feb 2008 From: Portland, Oregon I Ride: '07 GSXR-750 | lots of good advice here. If you cant get the kink completely out your SAFEST move is to replace it. Unfortunately with 11K on the sprockets, its also safest to replace front and rear along with the chain as the parts wear down together. A kink in a chain could result in the chain hopping off at speed and snapping... I think Im gonna try the kerosene in a spray bottle and teflon lube trick. |
| | #35 | |
| Daytime Adventure Seeker ![]() | ![]()
| | #37 |
| Daytime Adventure Seeker ![]() | No problem ![]() |
| | #38 |
| Pit Crew Joined: Apr 2009 From: Portland, OR I Ride: 2007 KTM Super Duke | I've used WD-40 for years w/o issue. I replaced the Tuono's chain at 18k, but only because I had someone give me a 520 kit, and the original chain had a bit of rust when I got it. I'm coming to believe that the real problem is either 1) Poor maintenance scheduling (people forget to lube/adjust for thousands of miles). 2) People only re-lube and never clean (like I did with my first sportbike 13 years ago). I think this is why WD-40 works. If you soak the chain and wipe w/ shop rags each time (every 500 miles or so), the chain never sees build up which would prevent parts of the chain from receiving lube. |
| | #39 | |
| Forum Cripple | Gee willikers.. I wonder why ![]() ![]()
Ditto on the replace the chain, however. Once a link has siezed, it's bunk. 11k miles isn't a bad number to get out of a chain, either. | |
