Old 11-03-2009, 07:30 PM   #1
GS1200's Avatar
I Ride: BMW 1200GS, Buell XB12XT
Hauling a motorcycle
Occasionally I have to haul my bike in my pickup or on the flat bed trailer. I use 4 ratchet type cargo straps. I get nervous doing it this way as I have to leave my tail gate down on the truck and the flat bed (car trailer) has no sides. I noticed some guys use a device that holds and locks in the front tire. That might work for me as I could transfer it between the truck and trailer.
What is the most secure way to transfer a bike?
Old 11-03-2009, 07:34 PM   #2
I Ride: Suzuki Boulevard C90, Honda CM250C, My Wife's Scooter
I normally use 6 straps: two big ones (one at each end) and 4 smaller ones (one on each corner for stability), and I've not had any problems over thousands of miles.
Old 11-03-2009, 07:51 PM   #3
xrdotimcr's Avatar
I Ride: therefore I am.
Haul? A bike? Designed to ride on the street?
Foreign concept. =)
Old 11-03-2009, 07:54 PM   #4
coastiepete's Avatar
I Ride: 2007 ZX-10R SE, 2005 450 EXC, 1980 GS750 Cafe Project
Are you worried about the tires slipping out from under? or the bike falling over and having nothing to keep it from falling out?
Old 11-03-2009, 08:01 PM   #5
varment's Avatar
I Ride: 2008 Ninja 650R
Ride it....
Old 11-03-2009, 08:04 PM   #6
Debi's Avatar
I Ride: 2005 Suzuki DRZ400SM and 2003 GasGas EC250
I use 3 straps and that's it...all is good.....the straps are not the ratchet type
Old 11-03-2009, 08:06 PM   #7
Click's Avatar
I Ride: I just keep it in the garage and make the neighbors think I ride
I've hauled a lot of bikes with only two straps. One on each bar holding it to the front of the truck bed. Dirt bikes and street bikes. Had three dirt bikes at one time in the truck once. One time, went down to Az with a TL1000 and VFR strapped in the back of the truck with two straps each. Was working on a drag boat team and went down for the finals. Go rained out so didn't get to ride. Came back, stopped in Truckee for dinner, then took off at night hitting triple digit speeds in the truck trying to get to Roseburg. Bikes didn't move. Never had a problem.
Old 11-03-2009, 08:11 PM   #8
odin544's Avatar
I Ride: '08 Ducati 848 street , '03 R6 race (for sale), '07 R6 race
I use 2. you dont need anymore. Unless your driving like a fucking idiot.
Old 11-03-2009, 08:59 PM   #9
midvalleysuperbiker's Avatar
I Ride: Aprilia Tuono, Ducati GT1000, Moto Guzzi Centauro, Bimota DB4, Yamaha FJR1300
I use a Baxley Sport Chock with 2 straps in front and 2 in back to keep the rear from moving around over bumps.
Once you use a Baxley you will wonder how you were ever able to do without it.
Old 11-03-2009, 09:10 PM   #10
Cherry Pie
Whitefire's Avatar
I Ride: KFC
Originally Posted by midvalleysuperbiker View Post
I use a Baxley Sport Chock...
If you want a Baxley Chock, get a hold of GixxerTek & see if he has any left.
Wheels Chocks
Faron@GixxerTek.com
253.234.4797
Old 11-03-2009, 09:18 PM   #11
I guess I use a bunch of straps because I don't want the bike moving around on the flatbed trailer, and straps are cheap. I trailered 4 big scooters up from CA without incident.
The furthest I've trailered a bike was down to ~ 100 mi. SE of Houston; I was driving the motorhome down there for a 3-month job, and wanted local transportation. Sometimes there's a good reason you can't ride everywhere.
Old 11-03-2009, 09:18 PM   #12
Harbor freight sells several chocks to choose from.
That being said I LOVE my Baxley.
I use a Canyon Dancer tie down with plastic cups to fit over the handelbar ends.
I use 4, 2" wide H.D. tie downs.
I have hauled anything form 50cc's to 1300 cc's without any trouble.
Old 11-03-2009, 09:25 PM   #13
I hate canyon dancers
every time i use them, i need to replace my grips
the side force always pulls my throttle grip in, wedging it against the start/kill switch.
Can you further explain the plastic cup thing? does it negate the grip damage?
Old 11-03-2009, 09:29 PM   #14
ckholloway's Avatar
I Ride: Hayabusa
I use a canyon dancer (because of plastics) and 2 motorcycle tie downs up front and to off the grab just for my own piece of mind. I have never had any problems either and also have hauled everything from 50cc to 1300cc both in the bed of the pickup and on the flat bed. Make sure you get the straps up front good and tight but not so tight that you blow out the fork seals.
Old 11-03-2009, 09:30 PM   #15
Outofsync's Avatar
I Ride: the bike that I am allowed to ride.. I dont own one... <-----Fail
Holy hell 4, 6 straps? Are you kidding?
You need 2 straps... MAYBE 3.... You need to compress the front and it will not move...I am sure there are some videos on youtube is your having disfunctions.... But seriously.. 2 straps...
Old 11-03-2009, 09:31 PM   #16
ckholloway's Avatar
I Ride: Hayabusa
The plastic cup type he is talking about is the newer design canyon dancer. I have heard of that problem using the older design before but I have never had any problem with mine and have used it on many motorcycles
Old 11-03-2009, 09:34 PM   #17
Ahhh, I see. I will look into them. i gave my old one away cause it sucked so bad. i figured out a way to use 4 soft extension loops with ratchet straps on my bike. it works perfect, and doesn't hit the fairings at all.
Old 11-03-2009, 09:36 PM   #18
Thats why I use the plastic cup models. No trouble with them!
The cups fit over the ends of the bars and the grips are not hurt.
Canyon Dancer II's
LINK>>>http://www.canyondancer.com/Barharn2.aspx
Old 11-03-2009, 09:43 PM   #19
Canyon Dancer II's
See why i love this place? learn something new everyday! thanks!
Old 11-03-2009, 09:43 PM   #20
odin544's Avatar
Canyon Dancer II's
the plastic cup ones like james is talking about are the only canyon dancers I would consider using. The old ones suck. I use cycle cynch and love them.
http://www.cyclecynch.com/index.html
Old 11-03-2009, 09:45 PM   #21
ckholloway's Avatar
I Ride: Hayabusa
Why does everyone have so much trouble with the original. I am not saying I am better then anyone else by any stretch of the imagination but I have had zero problems with mine. Have I just been lucky over the past several years?
Old 11-03-2009, 09:49 PM   #22
The older style had a tendency to roll the softer material grips on a couple of my bikes.
Pulling the grip in-board and away from the bar end.
There no chance of this happening with the newer cup design.
Old 11-03-2009, 09:55 PM   #23
ckholloway's Avatar
I Ride: Hayabusa
Oh sure I understand that part of it and if I was to go buy one today I would buy nothing less then the newer one. What I am asking is, Am I the only person that has not had problems with the strap type. I would replace it if I had but why fix what aint broken. I will make shit up thats broke on the bike so momma doesn't mind when new parts show up from the brown truck, but to go blow 40 bones on a new canyon dancer when I have never had problems with the old one??? MMMMMM i don't think thats gonna happen. I know you gotta be right cause I have heard about that happening to alot of guys that have used the strap type but not to I.
Old 11-03-2009, 10:04 PM   #24
GS1200's Avatar
Wheels Chocks
Faron@GixxerTek.com
253.234.4797
That is exactly what I had in mine. Thanks
Old 11-03-2009, 10:05 PM   #25
I just read through the FAQ's on the canyon dancer website. It seemed to be a be a hot topic on there. maybe if yours was ummmm.........frayed in one section you would need a new one? like maybe if a razor blade or pair of scissors rubbed on a piece of webbing? and if she's reading this.........Then definitely don't tell her i told you
Old 11-03-2009, 10:22 PM   #26
odin544's Avatar
A baxley is a waist of money in the back of a truck. It does NOTHING. The tie downs hold the bike upright.
Old 11-03-2009, 10:37 PM   #27
Outofsync's Avatar
000000000000000000000000000000000
Those wheel chocks are great for stationary situations and MAYBE a trailer... Not for anything else IMO... You still have to strap the bike... And if you do THAT right... Your wheel is not going anywhere..
Old 11-03-2009, 10:41 PM   #28
Especially in a truck bed. just put the tires in the channels molded into the bed.
I can see the concern if it's a wood or smooth metal deck trailer though. that stuff can get a bit slippery. Maybe in an erratic movement the tire could slide sideways on the surface? i said MAYBE
Old 11-03-2009, 10:55 PM   #29
chadbobb's Avatar
I Ride: 94 Seca II, 92 Honda Nighthawk 250
http://cgi.ebay.com/ebaymotors/Motor...Q5fAccessories
Would any of you guys trust this? I am almost interested in trying it
Old 11-03-2009, 10:59 PM   #30
Would I trust the devices ability to hold the front wheel up, yes. would i want my back wheel, chain, and front sprocket spinning all the time? No
Would i want the added wear on the rear tire? No. for a tire that only lasts 3-4k miles, and costs nearly 300 bucks, every mile counts
Old 11-03-2009, 11:01 PM   #31
I think it'd put unnecessary wear & tear on the final drive.
Old 11-03-2009, 11:01 PM   #32
Outofsync's Avatar
WTF are those straps attached to?
Old 11-03-2009, 11:05 PM   #33
Outofsync's Avatar
WTF?
"Will this type of towing affect my odometer reading?
Most odometers function in conjunction with the front tire. Because the front tire is elevated while in tow, the odometer does not register any additional mileage. That being said, there are exceptions to any rule, so please refer to your owner’s manual or contact the manufacturer with regards to your bike."
Old 11-03-2009, 11:05 PM   #34
chadbobb's Avatar
This is true. My honda nighthawk 250 probably would be ok. The tires last a very long time on that lightweight bike.
If only it was easy to remove the chain temporarily
Old 11-03-2009, 11:07 PM   #35
chadbobb's Avatar
WTF
"Most odometers function in conjunction with the front tire. Because the front tire is elevated while in tow, the odometer does not register any additional mileage. That being said, there are exceptions to any rule, so please refer to your owner’s manual or contact the manufacturer with regards to your bike."
That's how my honda nighthawk is.. No idea on my seca II though, just bought the thing.
Old 11-03-2009, 11:09 PM   #36
Outofsync's Avatar
^^^Most sportbikes do NOT work this way....^
Old 11-03-2009, 11:13 PM   #37
Most newer sport bikes, anyway. The EFI system monitors final output speed, so that pulse is also used to drive the speedometer.
That being said, the speedometer/odometer won't register unless the ignition is switched on.
Old 11-03-2009, 11:14 PM   #38
OOk
beansbaxter is too lazy to come up with something but he will get to it, eventually...
OOk's Avatar
I actually have condor wheel chocks mounted on my trailer but the baxley works even better too. It has a locking mech that keeps the wheel chock pivot from letting the bike role back. Protip: make sure to keep the bike in gear when trailering too.
Baxley > Condor (but in my defense I didn't know about Baxley when I got my Condor chocks. I have a Baxley for pit doody now tho.)
"Once you go Baxley, you will never go back-slee."
(It's the vodka that makes me hilarious)
Old 11-03-2009, 11:16 PM   #39
Outofsync's Avatar
True.... Still wondering about those straps though....
Old 11-03-2009, 11:17 PM   #40
chadbobb's Avatar
are you talking about how they attach to the bike or to the towing mechanism?
The PNW Riders riding time is 02:19 AM.
