Old 12-02-2008, 04:52 PM   #1
Hex Axle Tool!
Finally bought one of these gems so that I can pull the front on my 12.
I do the 10 enough and everytime I want to pull the rims on the 12 I get all set up and then give myself the headshaker 'cause I don;t have the appropriate tool
If anyone in the area needs to borrow it sometime let me know. It fits from like 17mm to 24mm.
Old 12-02-2008, 05:22 PM   #2
jimd2p aka Dweezlebutt
Cropduster's Avatar
I Ride: In full tuck at 35 mph
If yours was a 17, should have said something Bryan. I have one of those. Nothing bigger in hex though.
Old 12-02-2008, 05:29 PM   #3
Appreciate the offer Jim. The front on my 12 is a 22mm, guess I'll need to ride abit harder so that I get good use outta my new tool. Although I spend enough on tires as it is...
Old 12-02-2008, 05:44 PM   #4
gpd323's Avatar
I Ride: A POS
Also, a spark plug socket has the proper hex head for my ZX14. The hex head being the part you attach the ratchet to.
You flip over the spark plug socket, insert it into the axle bolt, and stick an extension into the socket and it becomes the perfect tool. For the Kawasaki's that is.
Spark plug socket of course for the peanut pulgs, the BCPR types.
I have used it many times on my front wheel. Try it, you may like it!!
Hey Brain, yes that is a cool tool also. Not trying to take the thunder, just a cheap alternative.
Cheers and beers.
Old 12-02-2008, 05:46 PM   #5
^^ Now ya tell me I'll keep that in mind should I ever be stuck without my new tool
Old 12-02-2008, 05:47 PM   #6
I Ride: 03 R6
where do you get your big hex tool? like a 22 or 24mm
does lowe or home depot carry it?
Old 12-02-2008, 05:50 PM   #7
cobra525's Avatar
I Ride: better than him^^some day
cant you just leave the pinch bolts tight like everyone else
Old 12-02-2008, 06:05 PM   #8
You might be able to get a big hex tool at the hardware store? I'm not sure.
I got bought mine at the Yamaha shop tonight, Cycle Gear has them as well. It's a "multi tool" as it fits all sportbikes.
Old 12-02-2008, 06:25 PM   #9
cobra525's Avatar
Um, it was a real question. I am assuming (yeah I know) that you got it for removing the axle right? do you not have the abilty to leave the pinch bolts tight until after you loosen the axle bolt?
This really isnt meant as a jab.
Old 12-02-2008, 06:58 PM   #10
DogoZX's Avatar
Doubt it. You can order one from here.
http://www.kneedraggers.com/details/...l--614662.html
Old 12-02-2008, 07:01 PM   #11
DogoZX's Avatar
My zx14 is 22mm on both sides.
Even if you leave the pinch bolts tight on one side, you need a big azz hex for the other.
Old 12-02-2008, 07:08 PM   #12
cobra525's Avatar
So you can not put a real wrench on either side? If that is the case, I did not know that.
Yet another reason to hate Kawis
Old 12-02-2008, 07:19 PM   #13
Pilot in Command
RVFR's Avatar
I Ride: Honda............Ducati?
I'm not going to say anything, Snap-On FTW.
Old 12-03-2008, 07:38 AM   #14
I Ride: Suzuki SV1000N, CRF450R, XR100
A big bolt with the right size head and a couple nuts run together at the end works fine. FYI
Old 12-03-2008, 08:21 AM   #15
L/R, inverted spark plug socket, Motion Pro Hex tool, Home made hex tool.
NAPA also has some LARGE Hex sizes available in 1/2" drive .
Old 12-03-2008, 08:30 AM   #16
SpeedGeek's Avatar
I Ride: whenever I can
Axle tool from motosport.com for $29.99
Old 12-03-2008, 08:43 AM   #17
Mic
Mic's Avatar
I Ride: with both cheeks hanging off each side.
That's what I do
Old 12-03-2008, 09:36 AM   #18
gpd323's Avatar
I Ride: A POS
You only loosen the right side pinch bolts. That allows you to use the inverted spark plug socket to loosen and pull the axle off the 14. You do not need to touch the left side pinch bolts or axle nut. You leave them in place.
I discovered the inverted spark plug socket trick on the Zx14 forums. Can never register, no moderator replies, so I just troll the topics.
Old 12-03-2008, 09:47 AM   #19
SRWitt's Avatar
I Ride: cause I'm a Loowwlife
Wow one was included in the tool kit for my Buell. Doesn't mean it isn't cheap and won't snap on you, as learned by a Buell riding coworker. Local shop used his factory hex tool to remove the front on his Lightning, snapped it in half (the buell one has a groove machined all around the outside of it with a circlip at the middle so you don't shove the thing all the way into the axle when wrenching. Took the mechanics at this shop a full day to do a 5k service (oil change/general lookover of the bike) and change two tires because of this broken tool.
Old 12-03-2008, 09:59 AM   #20
ScooterRash's Avatar
I Ride: GSXR1000
Brian, wasted your money dude!
That tool won't work on anything if there is a Pilot Power in the garage!
And I know your battle cry "I love me some Pilot Powers"!
I have that same tool but my favorite tool is the genuine Suzuki wrench made for removing the axle. It's expensive but damn it's sweet.
You should have borrowed mine! But then you'd have to give up those PP's!
Right On! Right On!
Are you going to get your bum out to the track this up coming season, dude?
Old 12-03-2008, 10:17 AM   #21
FastCat's Avatar
I Ride: GSXR-1100 & a B12
Fastcat's ghetto-fabulous axle-tool: (I have them in various sizes)
Old 12-03-2008, 11:20 AM   #22
Right On! Right On!
There was a disclaimer on the packaging that said something about it not working if rider has PP"s on their machine. Being the rebel that I am I didn't believe it. Bought it anyways and it appears to have worked, I think it was propaganda from Suzuki riders
It is my intention to get out the track this coming season and see what kind of fun I can have on my 10. Want to get with great dudes like you and LateApex and improve my riding skillz
^^ Sweet!
Old 12-03-2008, 11:52 AM   #23
ApexHack's Avatar
I Ride: YZF750, 1000RR
Ding Ding Ding, we have a winner. $5 at most. Metric bolts have metric heads, who would've thunk it?
Old 12-03-2008, 12:22 PM   #24
DogoZX's Avatar
Oh yes, I already know all of the "ghetto-fabulous" tricks!
Old 12-12-2008, 03:24 PM   #25
THOE's Avatar
I Ride: any women that will let me
Here is a link to a Front Axle Tool on Ebay right now that is smokin deal and covers most applications. If you have trouble finding it the item number is 110325812093 just paste and copy it in the search bar on Ebay, there selling them for $11.95. The link is below try and copy and pasting it, if not use the item number instead.
http://cgi.ebay.com/ebaymotors/HAYAB...Q5fAccessories
The PNW Riders riding time is 03:33 PM.
