| Superbiker | 83 Nighthawk 550/650 torque spec on cyl head cover Hoping a mechanic might have this in a Honda book, or someone else has an old manual for the 83-85 Nighthawk 550/650's... Can anyone tell me what torque should be on the bolts for the cylinder head cover for an 83 Nighthawk 550? My new head gasket is showing up tomorrow, and I cannot find the manual online... I can get it off Amazon for ~$30, but thought I would ask around first. |
| Streetfighter Joined: Oct 2008 From: EUGENE IS JUST MY NAME; I LIVE IN PORTLAND I Ride: 2002 CRB600 F4i | |
| WMRRA Qualifier Joined: Jun 2007 From: Seattle I Ride: YZF750, 1000RR | 6 - 9 ft-lb (72 - 108 in-lb) isn't much. I wouldn't be using a torque wrench unless you have a 1/4" or 3/8" drive in-lb version. You don't want to strip those. |
| | #4 | |
| Superbiker | ![]() Edit: I figured it wouldn't be a lot of torque, but figured I should see if anyone had a better answer than my "turn til tight plus 1/4 turn" torque level. Last edited by SatansPetFerret; 06-11-2009 at 09:26 PM.. | |
| Pit Crew Joined: Jul 2008 From: Klamath Falls, OR I Ride: '78 CX500 (rebuilding); '84 VF500F (fixed!) | ![]() IMHO you would be better off trying to find the correct manual. Keep digging as I'm sure it's out there somewhere. I've found that forums specific to certain bikes will have a link somewhere to the manuals. That's how I got manuals for my CX and VF. -Jake |
| MotoGP Champion Joined: Apr 2007 From: soap lake wa. I Ride: 00kaw12r, 97 tls1000, 96gsxr1260 turbo freakshow, kz1300gt, 88gsxr1100, 86gsxr750, 82gsx1100ez, 79kz1300, 75 ducati750gts, 72 gt550 cafe | I'll bet theres a torque sequence(pattern) too... it would be best not to wing it... FREE and clean, Ripp'n |
