| Training Wheels Joined: Feb 2010 From: Coeur d'Alene I Ride: Buell XB9R | one more thing to try.... try using the arm/disarm button while the kickstand is up.. theres a fair chance its tied into the alarm much like a door. |
| Training Wheels Joined: Feb 2010 From: Coeur d'Alene I Ride: Buell XB9R | and if that dosent work you can try this if you dont want to meet up.... have access to the blue valet switch plug on the brain. find a small screwdriver or knife that will fit into the connector and touch both of the pins together... you will have to be a little quick as you only have about 10 seconds to do it.... turn the ignition all the way on then all the way off ( not lock) within 10 second touch the two pins together just for a sec... if it worked your led shoud blink a time or two.. turn the ignition on again.. wait 10 seconds or so then turn it off and try to arm it. |
