| Newbie Joined: Apr 2009 From: Woodinville, WA I Ride: Yamaha R6 | Question:R6 Generator Rotor Projection? I'm new at servicing my bike, so this is a novice question I'm sure... The 1999-2002 R6 Service Manual says "Do not allow the sheave holder to touch the projection on the generator rotor"... what is this "projection" they're referring to? If it was the idler gear shaft or a dowel, you would think they would have referred to those as such. I can't see anything projecting, and don't want to remove the rotor until I know for sure what they're referring to. -Shelly |
| Training Wheels Joined: Nov 2006 From: Bothell wa I Ride: WR450 | They are talking about the reluctor projection peice that triggers the pick-up coil. It may be a small bump on the outside of the flywheel or a series of bumps. |
