Old 02-24-2010, 06:11 PM   #21
BigDZX10R's Avatar
I Ride: "10 ZX10 Ninja, 09zx6R, '08 ZX10R sold
Originally Posted by BigDZX10R View Post
Im 265, not around the middle, and it brings the front tire up shifting into 4th! Custom race map on the PCIII. Ive SMOKED a busa twice and had it to 180 with more to go. Guess i really like the rush. Thing makes huge power but always looking for more... I really appreciate all the input though! Thanks!
I dont dive a Caddy and i dont want a huge bike....
Sport bike , that is
Old 02-25-2010, 09:15 AM   #22
I Ride: upstream.
Probably the safest thing to do is find the servo connection to the sub-throttle plate arm and disconnect it. Then lockwire the sub-throttle plate arm in the open position. You can then test whether or not the mod is giving you the benefit you are looking for.
The reason being, if you look down your intakes (with airbox off), imagine stripping one of those screws holding the secondary throttle plates. Some people have had some horror stories taking them off in the FZ1 world.
Old 02-25-2010, 08:48 PM   #23
Defiler of Threads
TRAIL BOSS's Avatar
I Ride: for OPRT with an '07 SXV550 (The Darkness) and a '13 ZX14R (Mjölnir). DGA sucks.
Originally Posted by coastiepete View Post
yup, i'm 230 without gear, and my 07 always pulls like a freight train.
I'm about the same, and I've never had a complaint about the eyeball crushing power that my bike makes.
Originally Posted by vagrant View Post
After all of this, if you really really need more throttle response, search zx-10r.net for the riflemans's throttle tube or smething like that. He mods the little cam/pulley thingy to make it less of a turn to WOT. Enjoy.
(no I have not done it)
After looking at that mod, I'd be a little leery. You have to dremel your throttle cable housing to make it work, so if you fuck up, you're off the road till a new one arrives.
Besides, all you really need to do is just turn your wrist faster. You're wrists are nice n limber, Matt.
Originally Posted by Lone Rider View Post
Didnt know flies out was a common mod on the 10.
It's not, actually. A few people have done it, myself included, with relatively inconclusive results. It doesn't "unleash the beast" the same way it does with the 14.
From what I can tell, it makes the throttle much more responsive, but at a severe loss of low opening smoothness. No HP or torque gains from the first time I dynoed at DucSea to the last.
It'll throw an error code at you. You have to leave the servo functional or install the correct resistor.
BigDZX10R, I hate to tell you this, but unless you're rockin' a number plate on the front of that 08 of yours, you need schooling before speed mods. Especially considering the miniscule anmount of throttle response you gain, I'd recommend spending your time elsewhere. I can tell you for certain that it will be a disappointment.
To be quite honest, I sincerely doubt you're capable of utilizing the full HP potential of even a stock ZX10R. Most mortal humans aren't. Get some track days under your belt and really learn that machine. It'll go a hell of a lot farther for you than pulling the flies.
Old 02-26-2010, 07:11 AM   #24
I Ride: upstream.
Yep, the way I wrote that you are right.
I should have written,"Disconnect the mechanical connection between the servo and sub-throttle plate arm, do not disconnect the servo itself."
That's really the best thing to do in this case, easily reversible.
Old 02-26-2010, 07:22 AM   #25
ddonacazx12's Avatar
I Ride: 05 zx12r
ummmmm... yeah. cuz everybody knows how lacking the zx10 is in power...
Old 02-26-2010, 08:03 AM   #26
»-(¯`·.·´¯)-> PNW
vagrant's Avatar
you know it baby. Actually, the real problem the rifleman's throttle mod was attempting to fix was the amount of turn to WOT. Some people have experience (on the track for the most part) that you need to either (a) start with your wrist in a really weird position, or (b) grab another handful halfway thru your twist in order to get to WOT.
This issue is most prevalent at the track when you are holding "maintenance throttle" through the corner and then trying to open up to WOT as you exit the corner. Maybe its cause Im slow, but I've really only noticed a couple times and you can always adjust your riding style and/or gearing/gear selection to avoid the problem. Of course, Im never really that close to the ragged edge.
Old 02-26-2010, 05:54 PM   #27
BigDZX10R's Avatar
TRAIL BOSS...Thanks! After reading what you guys said and zx-10r.net, i dont think it's worth doing. Just asking a question from somebody that knows more than i do...It doesnt sound as good as the guy that told me about it said it was. Thanks again everyone!
I never said the 10 doesn't make huge power...
Seriously, THANKS!
Old 02-26-2010, 07:10 PM   #28
Defiler of Threads
TRAIL BOSS's Avatar
Seriously, THANKS!
No worries, man. Again, it's nothing personal.... Just a universal truth.
Old 02-26-2010, 07:15 PM   #29
mustang1's Avatar
I Ride: hayabusa
It's your monkey ,pet it as fast as you want.
