Old 04-20-2010, 11:35 AM   #1
SparkyzGixxer's Avatar
I Ride: 1998 GSXR 750
Harley vibration at above 65mph
Ok my buddy has a 98 Harley softtail with the 80 cu. In. Motor. He says that he can't really go over 65 without uncomfortable vibration. He was told it is normal for that motor and all. I think that there is something not right.
What are the possibilities? My friend lives in anchorage alaska so I will get as much info as I can. But only being able to do 65 just don't sound right. Even for a Harley.
Old 04-20-2010, 11:38 AM   #2
Wyckedan's Avatar
I Ride: 2012 Aprilia RSV4 Factory APRC with OPRT
A Harley can get up to 65mph???
Old 04-20-2010, 11:58 AM   #3
Wench
ducatichick's Avatar
I Ride: to Victoria's Secret
Engine vibration, and/or other kind(s) of vibration?
I'm brainstorming here: improperly balanced wheel(s), scalloped front tire, loose steering bearing, loose/damaged motor mount (does this thing have hard motor mounts or rubber bushings?).
Has it always been like this, or did it get worse over time or...?
Old 04-20-2010, 12:01 PM   #4
Eugene's Avatar
what she says
Old 04-20-2010, 01:00 PM   #5
Harley1's Avatar
I Ride: 2014 FLHXS
My first guess would be to inspect/tighten/replace motor mounts.
Old 04-20-2010, 01:06 PM   #6
When was the last time the bike was looked over and everything tighted up?
Old 04-20-2010, 01:09 PM   #7
cityxslicker's Avatar
I Ride: Buell XB9SX City-X
It would be helpful to know the model of softail.... ie does he have the 21 inch front tire or the 16.... my bet is that it is a FX with a 21, and as a 98, betting before the twin cam switch over. The motor on the Softail is bolted directly to the frame with no dampening, your vibration isolation is from counterbalancing the motor... which really didnt come into having any significant affect before the twin cam set up.
He has a couple of options... make sure everything is all torqued down.... put a bigger fatter 16 inch tire up front... trade in for a new softail.... trade in for a newer FL tour bike. OR.... ride it, and pull over at every Starbuks out there....
Old 04-20-2010, 01:12 PM   #8
Degenerate's Avatar
I Ride: Busa.
If it were me I would start with the wheels follow him and watch for a possible bent rim. then get up beside him and look for any odd moving parts. then work to the shocks and up from there. Dads Ultrarglide classic at 65 does not vibrate abnormally.
Old 04-20-2010, 01:15 PM   #9
starkmojo's Avatar
I Ride: 92 TDM 850, 74 cl450
I will that. When I got my bike it was hard to even ride at all, but even after
Replacing:
tires (it came with the OEM tires- 34 years old and 27K miles they were smooth and hard as... well you get the picture)
shocks
swing arm bushings
fork oil
while it was WAY better it still had this wierd feeling over 75. I found out that someone had replaced the main motor mount with allthread that was 1/2 the diameter of the stock bolt
that fixed it.
check the engine mounts- if they are rubber see if they are hard or split.
Old 04-20-2010, 01:39 PM   #10
MadManx's Avatar
I Ride: Lived to tell about it..
Its a Harley.
Old 04-20-2010, 01:44 PM   #11
saltlick's Avatar
I Ride: 04 Honda CBR 600RR
they didnt rubber mount those engines until 2003 right? I rode a harley that wasnt rubber mounted, i could certainly go over 65mph.
Old 04-20-2010, 01:56 PM   #12
Lizi_wesson's Avatar
I Ride: 72 CB350 Inline four cafe racer, 98 VTR 1000 Honda Super Hawk, 74 TL 125 trials bike, 06 XR650L sumo, 07 CRF150F
Not to be like that, but srsly, if your friend can't figure out what is wrong him/herself, bring it to a shop. Don't rely on a bunch of people to tell you when they have no idea, either. Can't diagnose a problem like that. It's like 10 people with blindfolds on running their hands over an elephant and trying to decide what it is. Ridiculous waste of time.
As a shop owner, it could be alot of things, as Ducatichick said also. BTW it should not be anything specially shakey over 65 if it isn't under 65...rubber mounted engine not a factor here.
Bring it to a shop, and yeah, like Dragracer said, make sure they tighten EVERYTHING up, too.
Old 04-20-2010, 02:03 PM   #13
WMRRA #2 Overall Points Champion
NoQuarter#121's Avatar
I Ride: on ice at 15F below zero. GO ICEHOLES!!!
the softail didn't get the Twin Cam B (balanced) motor until 2000.
Harley never made a rubber mounted softail. (still don't)
The closest thing would be a Wide Glide assuming you mean the Softail model with the 21" front wheel and not a Fat Boy or Heritage all with the softail chassis, but with the bigger front end and 16" wheel.
Some of the after market frames had softail styling with the Wide Glide style rubber mounts.
Gotta watch those as well on bigger motors...
The older softails feel like a paint shaker is underneath you when your rolling. Its different for sure. Not sure if I actually miss it, but you knew you were on a Harley fo sho!!!
The vibes can damage motor mounts if not maintained properly.
Tell him look for broke stuff, if nothing is busted he should try to ride another similar vintage softail.
It might just be the good vibrations of the solid mounted motor!
Old 04-20-2010, 02:27 PM   #14
<snip>...
OK, so this proves my point. Even the guy doesn't know what kind of bike he is asking about for his friend.
Also, even if he was able to find "broke stuff", it needs to go to a good mechanic, anyway.
and, if he doesn't know what it's supposed to feel like already....
anyway.
BTW single fire ignition upgrade helps alot. Also selling it and getting a StreetRod, which is nice and smooth.
Old 04-20-2010, 04:02 PM   #15
I think the first thing I'd check after the motor mounts is the engine / tranny alignment. They want to pull the tranny sideways...
Just a thought.
My Shovel has had it's tranny get a little out and it'll shake. Same with my Norton.
Old 04-20-2010, 04:07 PM   #16
Harley's Avatar
I Ride: In Cowboy Boots
id say front motor mount or wheel-- take it in or check it out before something happens on the road
