Old 05-26-2012, 02:27 PM   #1
ride57's Avatar
I Ride: 97 748, 96 900 SS/SP
Rattle can paint
This is my "new" rattle can paint job. Originally I was going to have a guy from work paint it for me. But then the wife got laid off from work, so I ended up just spraying it black.
I was at wallyworld yesterday and saw "Rust-Oleum Textured Metallic" paint
total cost?
$6
Old 05-26-2012, 02:39 PM   #2
muddyroy's Avatar
I Ride: 2007 Suzuki SV650
Nice! Who needs a whole bunch of shiny bits! I think it looks cool!
Old 05-26-2012, 02:43 PM   #3
DirtyDucRider's Avatar
I Ride: Twins!!
Hey that actually looks pretty good! Slap some decals on it, and you can't tell the difference! (In pictures anyway)
I would have said "Good enough for government work!" But that actually looks better!
Side note: what kind of wheels are those? They're bad-A!
Old 05-26-2012, 02:52 PM   #4
courier11sec's Avatar
Looks good.
Also, about the sick wheels.
Now you need some wheels for your car so you can take those hubcaps off!
Old 05-26-2012, 02:55 PM   #5
671kidd's Avatar
I Ride: Hyosung GT650R
Thats a real nice job man. How long did it take you to do the whole bike? Im thinking about doing the same thing but possibly a different color.
Old 05-26-2012, 03:03 PM   #6
Sentor's Avatar
I don't know if you've polished/waxed it yet, but it could turn out even better if you put some nice clearcoat over it, even the spray stuff works well.
It just needs a light sand on the under layer, the primer, the paint and then clear if you choose... It doesn't take long at all to rattle can a bike. Maybe 2 hours or so if you want tons of layers.
Old 05-26-2012, 03:11 PM   #7
671kidd's Avatar
hmmmm, i might look into doing it that way.
Old 05-26-2012, 03:54 PM   #8
crxracer98328's Avatar
I Ride: kx450f
gloss and some wet sanding will make it look new...unless your going for flat-ish. looks pretty good though!
Old 05-26-2012, 06:59 PM   #9
ride57's Avatar
dirtyduc these are Carrozzeria wheels
Its a textured paint, so I don't think wax would work. I am sort of wondering how hard it will be to clean when it gets dirty.
I should try some clear coat, I know they make it in a can.
It took a few hours, ( I rattle canned primer and paint about a year ago) So all I did was light sanding and spray. I left the front fairing on and taped off the windscreen. I taped off the seat instead of taking it off.
It took just one can, with a little left over.
Old 05-26-2012, 07:14 PM   #10
tornaido's Avatar
I Ride: Like a Boss
I'd like to rattlecan my bike too but am worried about gas spray eating the paint and paint coming off when cleaning the bugs off it. any suggestions from others with the same paint job?
Old 05-26-2012, 07:17 PM   #11
fattiremike's Avatar
I Ride: 2007 RWB VFR800, 2005 CBR 600rr Trackbike
Looks nice! I recently painted my track bike. I cleared it with Krylon clear enamel, and at the first track day proceeded to spill gas all over the tank! It promptly removed the clear coat and a bit of the color coats in a split second. I quickly grabbed some paper towels and tried to wipe the gas off, and it just turned into a big gooey mess. So, I did some research and found some stuff from Eastwood, that is a two-part epoxy clear in a can! It's 22 bucks a can, but sprays on very easily, and is gasoline resistant. I have even tested it, and so far, so good! I would recommend at least doing your tank with it.
Old 05-26-2012, 07:52 PM   #12
I Ride: 1979 Suzuki gs850
2k works great
http://www.sgcardetail.com/USC-36800...-Prodview.html
Old 05-26-2012, 07:57 PM   #13
mulletman's Avatar
I Ride: 2005 GSX-R600
I recently used some Belton Molotow spray paint to paint my track bike. Awesome stuff, tons more solids than any other spray paint I've ever used. The clear is good stuff too. I bought mine from Art Primo in Seattle, after having Rustoleum wrinkle up and turn to crap on me. If you're going to use spray paint, use this stuff. The high-pressure "premium plus" cans are so awesome. No issues with cleaning, and gas spills aren't damaging as long as it's cleaned up promptly.
Old 05-26-2012, 08:02 PM   #14
tornaido's Avatar
I Ride: Like a Boss
Where can I purchase this eastwood two part product? Remember its specific name?
Old 05-26-2012, 08:05 PM   #15
Jeffytune's Avatar
I Ride: Harley FLHT
Forget the bike, is that a 59 or 60 T-bird?
Old 05-26-2012, 08:10 PM   #16
http://www.eastwood.com/spray-max-2k...t-aerosol.html
Old 05-26-2012, 08:28 PM   #17
tornaido's Avatar
I Ride: Like a Boss
bitchin' thanks!
Old 05-26-2012, 08:30 PM   #18
tornaido's Avatar
I Ride: Like a Boss
anyone have experience with smoking headlights? I had my SV's taillight smoked and it looked amazing but was done in a professional shop. I saw a corvette with smoked headlights and it looked sweet.
Old 05-27-2012, 12:46 AM   #19
ride57's Avatar
59 Tbird. Pretty much all the suspension parts are new. I replaced front/rear springs, control arm bushings, tie rods, shocks, ball joints etc.
2 new pistons, rings, crank/rod bearings, cam, timing chain and gears, lifters.
New holly carb. 2 months ago, the old carb caught fire and burned the carb, air cleaner and some plug wires.
The fire is why I rattle canned it black. RAT RODS FTMFW
I also just ordered some of that clearcoat.
Old 05-27-2012, 07:45 AM   #20
This is the stuff I used. Supposedly, it goes over ANY surface without it wrinkling! I was really impressed by how hard the stuff got, and only in a couple of hours. The Krylon clear was still soft after a couple of days, and the fuel still took the topcoats off after a couple of weeks. Oh, after you activate the internal chamber, you only have about 12 hours to use it before it sets up in the can.
http://www.eastwood.com/spray-max-ra...t-aerosol.html
