| Training Wheels Joined: May 2012 From: Bellevue, WA I Ride: Honda Nighthawk 250 | Spark plugs smell How shall the spark plugs smell? I wanted to be good with my bike so I've changed oil first, now I changed spark plugs and I've noticed that one of them smelled with fuel while another one had no smell. I imagine that it is a bad thing they smell different but which one is wrong and what may be the problem? |
| Novice Racer Joined: Feb 2006 From: Beaverton, OR I Ride: 2008 R6 Race Bike - #52 - And whatever's in the shop! | How does it run? It's carbed, correct? You may have just twisted the throttle without it being running... |
| Training Wheels Joined: May 2012 From: Bellevue, WA I Ride: Honda Nighthawk 250 | It runs pretty good. It is curbed. The only thing I can complain about right now is a little bit of vibration at high engine RPM. IŽll give it a ride and IŽll check the plugs again taking care to not to touch the throttle. Shall it smell with fuel or it should have no smell? |
| Novice Racer Joined: Feb 2006 From: Beaverton, OR I Ride: 2008 R6 Race Bike - #52 - And whatever's in the shop! | If one jet is throwing too much fuel at it, it may not burn it all? Maybe your carbs need to be synched. When was the last time the carbs were gone through? |
![]() ![]() Joined: Mar 2009 From: Spokane Valley I Ride: Suzuki Boulevard C90, Suzuki DRZ400E, My Wife's Scooter | ![]() ![]() KevinD |
| Shredder Joined: Jul 2009 From: Beaverton I Ride: Harley FLHT | I would think it would depend on what cycle the cylinder was in when it was shut off. If it was just starting the compression stroke, I would hope there would be fuel on it. If they LOOK the same, your most likely good to go. |
| Knee Dragger Joined: Jul 2005 From: spokane I Ride: other peoples when they let me, working on Honda VF750 | it's more about how they look, frm NGK prob more than u need- http://www.ngksparkplugs.com/tech_su...qs/faqread.asp |
| | #9 | |
| Licensed Joined: Mar 2010 From: olalla, washington I Ride: ducati 1198s, 13 crf450, | ![]()
fish you .... well ![]() | |
| | #10 | |
| Training Wheels Joined: May 2012 From: Bellevue, WA I Ride: Honda Nighthawk 250 | ![]()
