| Newbie Joined: Jul 2012 From: oxford, ma formerly from gresham, or. | Good Morning.... long story short...my son offered to clean the carbs on my 1998 gsx1100f. got everything apart...carbs cleaned and had to return home without getting it put back together. i need a diagram / picutre / document with the vacuum lines / fuel hose connections for the carbs and the fuel tank so that i can make sure it goes back together the way it belongs. does anyone have a suggestion where i might be able to get this information?? thank you very much for your help. best wishes. |
![]() ![]() Joined: May 2011 From: LaCenter, WA I Ride: 2003 Copper SV1K | Everything you ever wanted to know about Katanas including service manuals can be found here: http://katriders.com/vb/index.php? Be sure to hit the Wiki....lots of good stuff! I'm a member there too....excellent Katana resource. |
