| Chicken Strips Joined: Jun 2010 From: Vancouver, Wa I Ride: 2000 Honda VFR800, 2008 Husqvarna TE-610, 2004 Ninjette | Need help with setting sag I bought my Husky a couple months ago and I'm considering getting the rear shock lowered by about 1", but before I do that I realize that I should probably set the sag up for me and my weight to know for sure. I'll need to have it set up again once I do the lowering so I'm hoping to avoid paying to have it done twice. Could anyone local that knows what they're doing, help me out? |
| Chicken Strips Joined: Jun 2010 From: Vancouver, Wa I Ride: 2000 Honda VFR800, 2008 Husqvarna TE-610, 2004 Ninjette | I don't have a spanner but I've got a long, heavy duty screwdriver & a dull chisel also. I bought the bike from a guy that's got 50-75 lbs on me & he had the suspension set up for him @ RPS Suspensions. He didn't have any paperwork to prove that but he was very honest with everything else. Also, the bike feels like it doesn't need a heavier spring. |
![]() ![]() | Should sag about 4" with you on it and after you set that, about 1" without you on it if the spring is right. If it sags much more than 1", spring is too stiff, much less, spring is too soft. |
| Novice Racer | ![]() after sag is set if it still sags more than 1" spring is too soft , and if it's much less than 1" spring is too stiff |
![]() ![]() Joined: May 2011 From: LaCenter, WA I Ride: 2003 Copper SV1K | Yeah he had that backwards. |
| Chicken Strips Joined: Jun 2010 From: Vancouver, Wa I Ride: 2000 Honda VFR800, 2008 Husqvarna TE-610, 2004 Ninjette | ![]() ![]() ![]() ![]() |
| Defiler of Threads Joined: Apr 2007 From: Arlington I Ride: for OPRT with an 06 ZX-tenaaaaargh Fighter and an 07 SXV550 (The Darkness) | Okay... A.) It should be a supermoto. Get on that. B.) Why are you lowering your dirt bike? |
| Peg Dragger Joined: Mar 2007 From: Redmond, WA I Ride: what others won't | Don't set your sag now. Set it after you lower the bike. No sense in doing it twice let alone paying for it twice. How do you plan on lowering it? Sending it to RDS to limit travel? Have you considered a Kouba link and then raising the front forks in the triple tree? Used one in my supermoto and it was tons cheaper than sending my shock out to get lowered. If you do use the Kouba, again - set the sag afterwards since you are changing the geometry. |
| Chicken Strips Joined: Jun 2010 From: Vancouver, Wa I Ride: 2000 Honda VFR800, 2008 Husqvarna TE-610, 2004 Ninjette | 1) I ride it like a super-moto. Does that count? 2) Again, it's because it's too tall and I'm tippy-toeing it when I get on or stopped at a traffic light. I lost my balance and dumped the bike today because I don't even have the balls of my feet on the pavement. I think if the sag is adjusted to my weight and equipment and that doesn't lower it enough, I'm going to lower it through the shock rather than a lowering link. |
| Chicken Strips Joined: Jun 2010 From: Vancouver, Wa I Ride: 2000 Honda VFR800, 2008 Husqvarna TE-610, 2004 Ninjette | Sigh....... Why is it I keep having to explain things over and over again to those folks up near Seattle??? |
| | #15 | |
| Peg Dragger Joined: Mar 2007 From: Redmond, WA I Ride: what others won't | ![]()
![]() ![]() trying to help you and you slip in a jab about Seattle. You're mistaken here. Setting the sag for your weight will not gain you the amount of lowering you need. Plus you never said that setting sag was your way of getting your feet closer to the ground. It makes no sense for you to set the sag now and then reset it again after you have it lowered. I know what you're going to say - "but if I set the sag now, I'll have an idea of what I need to lower the bike too." Doesn't matter. Why? Because when you set the sag again after lowering you'll be at a different height again. Thus - no need to set up sag now. Lower first. Also - are you trying to set up the sag as a street bike or as a dirt bike? There's a difference. We ask because you haven't supplied enough information. You're asking for something that suspension shops pay for. You'll go through the same questions with them. No need to get snippy about it here. | |
| | #16 | |
| Chicken Strips Joined: Jun 2010 From: Vancouver, Wa I Ride: 2000 Honda VFR800, 2008 Husqvarna TE-610, 2004 Ninjette | Now we're getting somewhere. Thank you for your insight- I've responded in red. ![]()
| Chicken Strips Joined: Jul 2011 From: Edmonds I Ride: with a :) | |
