| | #61 |
![]() ![]() Joined: May 2011 From: LaCenter, WA I Ride: 2003 Copper SV1K | Valve adjustment on my SV was three evenings FYI. And I only have two cylinders! I even have gear driven cams so I don't have to muck with a cam chain. Then throttle body sync, oil change, etc etc. Keep in mind that when you tear it down you will need to find a place that has shims ON HAND so you don't have to wait for them to be ordered. Call around ahead of time to find someone that has some. |
| | #62 | |
| Bat Crazed Joined: May 2009 From: WA I Ride: 08, R1 | ![]()
| | #63 |
| Peg Dragger Joined: Jun 2007 From: Seattle I Ride: YZF750, HawkGT, YSR50, VT1100(parting), '73 CB350F, SV650, CB550F, CB175 | I would think if there was that much fuel getting into the combustion chambers, then some would have gotten into the oil. The oil didn't smell like fuel last night. |
| | #64 |
![]() ![]() Joined: Feb 2008 From: Mill Creek, Wa I Ride: slower than you with a bigger grin! | Hush you with your sensible thinking. 2dizzy can research the shit out of things. |
| | #65 |
| Shredder Joined: Jul 2009 From: Anywhere I can get to on my bike I Ride: 2000 GSX-R 750 | So after reading all the possible problems........ and what it would take to fix them....... I have decided to follow the wise, and senior advice of my forum members and.......... NOT do this shit myself......this time. I'm gonna break down and pay someone to do it, so that I can make sure it gets done the right way the first time. I'll just have to pull it apart and learn about the carbs/valves etc over the winter when I'm not going to be riding. Thanks for all the input. Even though I'm not doing the job myself, I actually have learned alot from everyone's responses, which is kinda the point of being on here. Thanks again Jeff and Daniel for your help the other night. And thanks to David for coming out to my moms house and saving the bike after the battery died..AGAIN. |
| | #66 | |
| Streetfighter Joined: Feb 2010 From: Seattle, Wa I Ride: An 06 R6 with OPRT | ![]()
