| Newbie Joined: Aug 2011 From: Tacoma, Wa I Ride: on the back of Crivens' bike! & '11 TTR230 | Recommendations for a machine shop... Hi all! Just bought an '83 YZ 100 and need to have the cylinder bored....any recommendations for a machine shop in the (preferably) Tacoma area that can do something that small? TIA |
![]() ![]() Joined: May 2011 From: LaCenter, WA I Ride: 2003 Copper SV1K | You will need to have it replated also in addition to be being bored. That cylinder doesn't have a liner, the bore itself is hardened or plated to withstand the friction. After looking, it has a nickel carbide plating for hardness. If you just bore it, install it and run it you will ruin it. Your best bet is to send it off to a professional motorcycle engine builder so it can be done right. The other option is to have it bored and then sleeved. Neither one is exactly cheap....may want to look at a new cylinder also. |
![]() ![]() Joined: Sep 2005 From: Bremerton I Ride: 05 KTM 625smc, 03 Are See fiddy one, 05 DRZ470SM, 95 FZR1040, 69 Combat Commando Roadster, 73 Commando Interstate, 67 BSA B44, 71 BSA B50 | Milinium technology They can bore, plate, yada, yada No liners please. Bad juju |
![]() ![]() Joined: May 2011 From: LaCenter, WA I Ride: 2003 Copper SV1K | Yeah, that place! Couldn't remember their name. |
| Permit Joined: Aug 2011 From: Tacoma, WA I Ride: Like I'm invisible | I'm afraid you guys are mistaken. This cylinder most definitely has a steel sleeve from the factory. That's the way they made them in '83. Yamaha offered 4 oversize pistons for it in .25mm increments. Casual research indicates that the first YZ with a plated cylinder was the 89 YZ125. So...what we need is a good old fashion automotive machine shop that can handle something with a 50mm bore (i.e. really small). |
