![]() ![]() Joined: Sep 2005 From: Bremerton I Ride: 05 KTM 625smc, 03 Are See fiddy one, 05 DRZ470SM, 95 FZR1040, 69 Combat Commando Roadster, 73 Commando Interstate, 67 BSA B44, 71 BSA B50 | These carbe have weird slide diaphrams.... Is there an Oring at teh top on the orifice that supplies vacuum to the top of the slide? Might be missing or dried out |
| Permit Joined: Jul 2010 From: Portland, Or I Ride: 2007 Yamaha FZ6 | They are there and the vacuum resistance when I move the slides is smooth and feels ok. They are fairly rigid though, do you know if they are supposed to be very soft? |
![]() ![]() Joined: Sep 2005 From: Bremerton I Ride: 05 KTM 625smc, 03 Are See fiddy one, 05 DRZ470SM, 95 FZR1040, 69 Combat Commando Roadster, 73 Commando Interstate, 67 BSA B44, 71 BSA B50 | Those have metal diaphrams. Yes? I wonder if there is some corrosion in there binding up the slide |
| Permit Joined: Jul 2010 From: Portland, Or I Ride: 2007 Yamaha FZ6 | ![]() Everything in there is shiny. I ordered a new seal kit and air cutoff valve which puts me $100 over budget on this project but I'll make it back when I sell the bike. |
![]() ![]() Joined: Sep 2005 From: Bremerton I Ride: 05 KTM 625smc, 03 Are See fiddy one, 05 DRZ470SM, 95 FZR1040, 69 Combat Commando Roadster, 73 Commando Interstate, 67 BSA B44, 71 BSA B50 | It would make sense that the slides are not riseing if those cyl are not fireing. I suspect you are on the right track with enricheners |
| Permit Joined: Jul 2010 From: Portland, Or I Ride: 2007 Yamaha FZ6 | I installed new air cutoff valves and started it back up and it was a little better but still bogging, sucking down gas at an alarming rate. I removed the air filter and it revved right up. I'm trying to clean it again but I may end up having to replace it. Thanks for the tips guys! |
| Retired Joined: Mar 2008 From: SE Portland / Bucerias, Nayarit Mx I Ride: 03' CBR1100XX, 84 GL1200A | Uh, you are trying to clean the air filter??? |
| | #29 |
| Retired Joined: Mar 2008 From: SE Portland / Bucerias, Nayarit Mx I Ride: 03' CBR1100XX, 84 GL1200A | Gotcha! Not really thrilled with their filters in street bikes, but they work well in most. Last edited by Desvio; 08-13-2012 at 12:13 PM.. |
| | #31 |
![]() ![]() Joined: Sep 2005 From: Bremerton I Ride: 05 KTM 625smc, 03 Are See fiddy one, 05 DRZ470SM, 95 FZR1040, 69 Combat Commando Roadster, 73 Commando Interstate, 67 BSA B44, 71 BSA B50 | Put the stock airbox back in it. Not enough vacuum impulse to overcome the non resonance of teh airbox being gone walkabout. |
| | #32 |
| Permit Joined: Jul 2010 From: Portland, Or I Ride: 2007 Yamaha FZ6 | ![]() I tried it without the airbox cover on and no filter and it was surge-y and had a hanging idle. No filter and airbox cover on and the hanging idle is better but it starts to backfire a little at mid throttle. I've got an OEM style air filter on its way. I think the previous owner had left the petcocks and either the gas/oil result got pulled into the airbox while it was running, or back flowed into the airbox just enough to destroy the Uni filter over time. |
