| Permit Joined: Jul 2010 From: Portland, Or I Ride: 2007 Yamaha FZ6 | 1982 CB900C slowly dies Hey all, I recently picked up a 1982 CB900C in non running condition. 44K New battery, spray clean of the carbs and it started right up but was smoking and backfiring. Compression was low in the middle cylinders so I did a valve adjustment. After buttoning it back up, it started, less smoke, still smoking though (likely valve seals) and it had a bad vacuum leak somewhere and was till backfiring when it warmed up. I sealed things up and when I started it, it seemed happy until it started to warm up. It sputtered some but smoothed out as I decreased the choke. After idling 30-40 second with choke off, the idle dropped out and eventually it died and would not start again. I pulled the plugs and they are black, and in the right two cylinders, the plugs were actually wet and, oddly, the pipes on those cylinders were actually cool. Thinking coil fade, I checked the spark and they were all pretty good. Visible under fluorescent lights. I wire brushed the plugs, set the a/f screws to 2 turns out, let the engine cool some and tried to start again and it didn't start. Compression #s: 160,180,120,150 The cold cylinders are the lower compression, but they should still be ok I reckon. The jets are stock size and the air filter is a Uni. That filter may be gummed up with oily backfire though. Thinking its 'flooded' I pulled the plugs and will let it rest for a while. I examined the Air Cutoff valve on carb#1 and it appeared to be in fine shape. I have not torn into the rack to examine them all. I have been running a strong mix of SeaFoam during my tests, this last even was run with fairly fresh, 87 octane with no SeaFoam Other than cleaning that airfilter, is there something obvious, or not obvious that I haven't checked yet? Thanks for any thought or input! |
![]() ![]() Joined: Sep 2005 From: Bremerton I Ride: 05 KTM 625smc, 03 Are See fiddy one, 05 DRZ470SM, 95 FZR1040, 69 Combat Commando Roadster, 73 Commando Interstate, 67 BSA B44, 71 BSA B50 | I had an 83 CB1000c Basicly the same bike. Be very carefull with the pilot air needles. They are a very long taper and VERY fragile. Parts are not plentifull for those carbs either. I would put in new plugs and give it a shot after cleaning the carbs really well. 2 1/2 turns out from GENTLY seated worked well for mine. Also, pull the pilot air screws and have a serious look at the order of the spring, washer and Oring. Mine had them wrong. |
| | #5 | |
| Permit Joined: Jul 2010 From: Portland, Or I Ride: 2007 Yamaha FZ6 | ![]() ![]() ![]()
I'll check the fuel level in the bowls like RedKat suggests and will probably end up pulling the needles and cleaning the carbs again. | |
| Knee Dragger Joined: Jul 2005 From: spokane I Ride: other peoples when they let me, working on Honda VF750 | I wire brushed the plugs, - NEVER DO THIS in the right two cylinders, the plugs were actually wet and, oddly, the pipes on those cylinders were actually cool. - you know that's because they are not firing? spray clean of the carbs - not a real carb cleaning |
| | #7 | |
Oh, and what strangerin said. Spraying crap at carbs isn't cleaning them....need to dip them if they are questionable. | |
| Railer Joined: Feb 2005 From: West Richland I Ride: Pitster Motard | You can revive wet-fouled spark plugs very easily. Cook the tips clean (center electrode) with a propane torch. Get them red-hot. This mimics the cleaning that happens under normal combustion conditions. Are you absolutely certain you have the valves adjusted correctly? ![]() |
![]() ![]() Joined: May 2011 From: LaCenter, WA I Ride: 2003 Copper SV1K | Two spark plugs are fouled black with fuel.....I'd say his petcock is working just fine. |
| | #11 | |
![]() ![]() I won't be able to work on this til Monday, but thanks for the thoughts! | |
| | #12 | |
| Knee Dragger Joined: Jul 2005 From: spokane I Ride: other peoples when they let me, working on Honda VF750 | Originally Posted by Wrench You can revive wet-fouled spark plugs very easily. Cook the tips clean (center electrode) with a propane torch. Get them red-hot. This mimics the cleaning that happens under normal combustion conditions. Are you absolutely certain you have the valves adjusted correctly? ejether: I'm certain about the valves. Thanks for the tip on cleaning plugs! normally maybe, but tracking has ruined your plugs a chanc to say it again:NEVERNEVER DO THIS |
| Permit Joined: Jul 2010 From: Portland, Or I Ride: 2007 Yamaha FZ6 | ![]() I said more precise. Float height, as you say, does not equal fuel height so a float height of, say, 14 mm *may not* be the same in all bowls. With the wet height, you can check to see how close they are to being the same (http://en.wikipedia.org/wiki/Accuracy_and_precision) But, in anycase, but doing this in this case, I'm not trying to determine if they are set correctly, only if they are stuck open. If they are stuck open then the fuel level in the tube will rise to the level of the air jets on the carbs (at least) If they are not (stuck open), then the level in the tube will max out at some, lower level. Since, often, its easy to find a measurement of where the level of the fuel in the tube should be in realtionship to the top of the bowl, I may actually be able to tell if the floats are set correctly, though I haven't looked into that for this bike yet. Mostly I'm just using it as a qualitative measurement of the health of the float needle valve. You live up to your signature strangerin, but fear not, thou crusty codger, I have purchased new plugs and will not wire brush them in the future. When you say tracking, what do you mean exactly? I gather you mean damaging the electrodes with the brush? |
| | #15 | |
I also am familiar with the test you are doing. You specifically stated "You can check your float heights wet". When in fact you cannot, it's the fuel height you check. Also, it can't be more precise than measuring the float height, as there is no specification nor measurement for fuel height in the bowls. It's only good for checking if there is fuel, or if the needles are leaking. Good luck with the carbs. | |
| Permit Joined: Jul 2010 From: Portland, Or I Ride: 2007 Yamaha FZ6 | ![]() ![]() ![]() On some bikes, there is a specification for fuel level. On my 92 Seca II there is a line on the back of the bowl that you use to set the floats wet. Thanks for the well wishes. |
| | #17 | |
| Knee Dragger Joined: Jul 2005 From: spokane I Ride: other peoples when they let me, working on Honda VF750 | ![]()
it's bad enough to fight the original gremlins wo/ putting more in as you're working. If you look closely at the insulator on the center electrode you will see what look like little tracks-pieces of metal that the wire brush left behind, it's a path to ground for the spark. The unlucky people may get thhe engine to start, but have a mystery miss. | |
| Endorsed Joined: May 2009 From: Woodland, WA I Ride: OP's for now. | The manual for my bike actually gives the procedure and the measurements for doing exactly that. I used it to double check that I set the float heights correctly. |
| Knee Dragger Joined: Jul 2005 From: spokane I Ride: other peoples when they let me, working on Honda VF750 | I'd really be interested in hearing that number, part because I am working on some Ninja carbs, part just comparison to my old KZ (1mm below). |
| Permit Joined: Jul 2010 From: Portland, Or I Ride: 2007 Yamaha FZ6 | I confirmed last night that the needle valves are operating properly and the floats aren't set so badly that the bowls are overflowing. That said, it was still only running on two cylinders. 1+2 were running 3+4 were not. Since the coils run 1+4 and 2+3, I think I can still look at something other than bad coils. If I open the throttle wide open with the choke off, 3+4 will *just* start to puff but the engine won't rev. Confirms a super rich condition in those cylinders. Ordinarily, I'm used to clogged carbs running lean, not super rich, but these carbs have that air cutoff valve enrichment circuit thing and I think they are stuck open letting in extra fuel. Regardless, I give up on getting it running as it is so I tore the carbs down and am doing a full cleaning (like I should have done in the first place). The air cutoff valves were pretty gunked up like I expected. The PO said the carbs were rebuilt by a pro last year and except for the gunked up air cut off valves, they look pretty clean so thats good. They'll be even cleaner soon. |
