| Endorsed | Alternate bars for '07 V-strom? Hi there! I have a Wee strom (the 650) and the stock bars are killing my wrists!! Anyone know where I might find some high quality straight bars that would mount up? |
![]() ![]() | They have tubular bars, so you can put any shape bars you want as long as they aren't way taller, which might require longer cables. I would go with tapered bars, as they are much stronger. You'll need adapters or new mounts for the 1 1/4" center size of the tapered bars, but they are pretty cheap. Here are some: http://www.rockymountainatvmc.com/p/...ZED+BAR+MOUNTS |
| Knee Dragger Joined: Jul 2005 From: spokane I Ride: other peoples when they let me, working on Honda VF750 | U have to know what to ask for first, bars have dimensions: diameter, height, drawback, center bar etc. If u like your present bars Except for the angle, I'd suggest a vice. |
| | #4 | |
| Endorsed | ![]()
Thanks Pete! | |
| Railer ![]() Joined: Jan 2008 From: teh rock | The stock position of my bars made my wrists hurt too. Loosened up the risers and rotated the bar down a little. That cured the problem. It's something to try for free. Just be sure not to turn them down so much you trap your fingers or dent the tank at full lock. |
