| Peg Dragger Joined: Aug 2009 From: Gresham, OR I Ride: 2005 Kawasaki 636 | These bolts look pretty important, any idea where they go? 2005 636, had everything ripped apart, replaced thermostat housing. My brain is super foggy right now, what the heck are these bolts for. They look important since they are so big. ![]() |
| Streetfighter Joined: Feb 2007 From: Seattle I Ride: 06 600RR | first thing I thought. check this out: http://i329.photobucket.com/albums/l...ginemount1.jpg those bolts look a lot like the ones here ^ 92153c and 92153b worth a look |
| Pit Crew Joined: Oct 2010 From: WA I Ride: 86 Yamaha FJ600, 93 CBR900RR, 92 GSXR750, 01 Hayabusa | With those collars they look like they go through a rubber gromet or plastic piece to me and they're fairly long. Try airbox as stated before or battery box depending on the bike. EDIT: Is that grease or locktite on the end of the threads? They look like they could be through bolts if that is dirt/grease. |
| Peg Dragger Joined: Aug 2009 From: Gresham, OR I Ride: 2005 Kawasaki 636 | never touched the airbox, only took off gas tank/thermostat and obviously fairings. annnd the bike still f'ing overheats. thermostat tested fine, fluids flushed. ordering a servo elim and hopefully that helps. |
| Pit Crew Joined: Oct 2010 From: WA I Ride: 86 Yamaha FJ600, 93 CBR900RR, 92 GSXR750, 01 Hayabusa | Bad water pump impeller. They could be out of the tabs on the back of the tank. They are usually rubber mounted. |
| Novice Racer Joined: Feb 2006 From: Beaverton, OR I Ride: 2008 R6 Race Bike - #52 - And whatever's in the shop! | ^^^ Oh yeah, Kawi and most newer yamaha's have the pivot near the battery and the front tank holders. Good call redkat. |
| Peg Dragger Joined: Aug 2009 From: Gresham, OR I Ride: 2005 Kawasaki 636 | The gas tank has 4 bolts, 1 up near handle bars, and two below the seat that are black. Then the pivot bolt. I'm saying F it, obviously I didn't need the bolts. Rode around today and nothing fell off. |
