Old 08-18-2012, 08:22 AM   #1
smoak's Avatar
I Ride: 1982 Yamaha Maxim XJ650
What would cause my bike to do this?
Yesterday and Thursday I rode to work on my bike with no issues. However, on the ride home (on both days) my bike slowly lost power and then just died as if it was out of gas even though the tank was at least half full. It would not start again until I let it sit for a few minutes, but eventually it died again while riding it home.
The bike was running fine in the morning with no apparent issues. It was pretty hot yesterday and Thursday, could the bike have overheated? It is air cooled and I was in slow moving traffic on both days.
Could a bad battery cause this issue? I don't know how old my battery is, but a few weeks ago I did have to top it off with distilled water and charge it.
My bike is an 82 Yamaha Maxim XJ650. Does anyone have any ideas?
Old 08-18-2012, 08:28 AM   #2
Coils overheating and losing spark.....gas boiling in the carb bowls...hard to say without testing it.
Old 08-18-2012, 08:44 AM   #3
Mitch F's Avatar
I Ride: every god damn day
I'll put my money on a clogged fuel filter
Old 08-18-2012, 09:41 AM   #4
Or a clogged gas tank vent
Old 08-18-2012, 10:19 AM   #5
Picture Whore
shelbyguy's Avatar
first thoughts
Old 08-18-2012, 10:53 AM   #6
smoak's Avatar
How do I tell if it's clogged? The fuel filter looks about half full of fuel.
Old 08-18-2012, 11:13 AM   #7
WaGigKPN's Avatar
I Ride: 2002 Honda VFR800
If its an in line visual filter just replace cause they r cheap.
Prob not coil over heating b/c it would take longer than a couple min for it to cool down and even if it did it would over heat very quickly.
On a bike that old and if it only happens when hot i would think tank not venting.
It seems your issue is between gas tank and carbs
Old 08-18-2012, 11:31 AM   #8
smoak's Avatar
Ok, it's an inline filter so I'll try replacing it first.
Old 08-22-2012, 07:31 PM   #9
smoak's Avatar
Put in a new fuel filter and it happened again today. It may be a venting issue at this point.
Old 08-22-2012, 08:52 PM   #10
I Ride: '82 Yamaha XJ1100J
I have an '82 X1100, and it has a vacuum actuated valve that allows fuel to flow from the tank when the engine is running. The vacuum from the running engine actuates the valve and allows it to flow fuel.
The petcocks can be set to four different settings...off, on, res, and pri...pri is short for prime which bypasses the vacuum valve (so you can start the engine if it has been sitting a long time and or the carbs have been drained). You can try running the bike with the petcock set to prime and see if the problem goes away. I would caution against leaving the bike sit like that as these old bikes tend to have leaky floats in the carbs...and with no vacuum valve to shut the fuel off you can literally fill your engine with fuel...or worse dump most of your tank out on the garage floor and blow up your garage.
If yours is similar it could be that the vacuum valve diaphragm has a leak in it and won't stay open. You can buy a rebuild kit cheap off of Ebay.
Some of the XJ's have the similar vacuum valve built into the petcock itself...and I would imagine they could have similar issues. Again you'd need to rebuild the valve and/or petcock(s).
By far the best source for this era of Yamaha XJ's is www.xjbikes.com forums. Hard to beat as a source of info for XJ's.
Hope this helps...
Mike
Old 08-22-2012, 08:59 PM   #11
WTFO's Avatar
Run it till it dies then open the gas tank filler cap - leaving it open - and then try and restart it - if it fires up OK and seems to run OK then you probably got a clogged tank vent
Old 08-22-2012, 09:06 PM   #12
BTW, the tank vent is in the cap...the tend to get rusty and clog.
Old 08-22-2012, 09:47 PM   #13
Listen when you open it. Sometimes you can hear air entering the take. Like the 'doors' on the starship 'Enterprize'. I'd have said 'sucking' but that would have sent this group into hyperdrive. Gotta watch your back with this crowd!
Old 08-24-2012, 08:13 PM   #14
Psychotinner's Avatar
I Ride: 1980 CB750K and whatever else i can get my grubby mitts on.
The petcock can also become clogged, especially if it has a 90 degree bend in it. It happened to me.
Old 08-24-2012, 08:16 PM   #15
ZXWUT?'s Avatar
I Ride: 05 625 SMC
But you just said sucking
Old 08-24-2012, 08:38 PM   #16
WTFO's Avatar
What is sucking what ???
