| Permit Joined: Jul 2010 From: Portland, Or I Ride: 2007 Yamaha FZ6 | Charging Sytem Question: Can a faulty rotor make a good stator test faulty? I'm working on a CB900c to sell and its not charging. I've followed some of the tests here and determined that, at least, the stator is bad (No voltage between the yellow wires) . I haven't had time to finish diagnostics yet and I plan on doing that. My question isn't related to the specific diagnostics but it makes me wonder. With my stator, no voltage is being created, but there is no short that I can find. And while I still plan on replacing the parts, or selling the bike (depending on cost) I'm curious: Can a bad rotor make a stator look bad in this way when its not? What do you gurus out there think? |
| Superbiker Joined: Oct 2010 From: Marysville, WA I Ride: 08 675, 72 XL250, 93 PW80 | General statement to answer what I understand your question to be: The output of an alternator is directly related to the strength of the magnetic field. Whether the magnetism is supplied by a field winding or magnet it must be at max to see max output. Magnets can loose magnetism. |
| Permit Joined: Jul 2010 From: Portland, Or I Ride: 2007 Yamaha FZ6 | That's what I was thinking. So if either the rotor or the stator were bad, there would be no voltage from the stator wires and the loss of voltage at the stator may indicate that the stator is bad, that the rotor is bad, or both. Thanks Andy |
| | #4 | |
![]() ![]() Joined: Apr 2011 From: Port Orchard, WA I Ride: 2007 Moto Guzzi Norge, 1988 H-D Electra-Glide | ![]()
Whilst it is not impossible for a permanent magnet to lose magnetism, it is quite rare, and usually needs some sort of external source to make that happen. | |
| | #5 | |
| Permit Joined: Jul 2010 From: Portland, Or I Ride: 2007 Yamaha FZ6 | ![]()
I unknowingly bought the non-running bike this way. 0.4-0.5 ohm resistance between the yellow wires. No faults to ground. I *think* the rotor on this bike is not a permanent magnet. I've read that it is a common point of failure. | |
| Superbiker Joined: Oct 2010 From: Marysville, WA I Ride: 08 675, 72 XL250, 93 PW80 | ![]() Again this is an overview of all alternator devices and not just auto/moto specific. |
| | #7 | |
![]() ![]() Joined: Apr 2011 From: Port Orchard, WA I Ride: 2007 Moto Guzzi Norge, 1988 H-D Electra-Glide | ![]() ![]() |
| Superbiker Joined: Oct 2010 From: Marysville, WA I Ride: 08 675, 72 XL250, 93 PW80 | ![]() ![]() |
![]() ![]() Joined: Apr 2011 From: Port Orchard, WA I Ride: 2007 Moto Guzzi Norge, 1988 H-D Electra-Glide | If I were fancy I wouldn't be nearly as charming and lovable. |
| Pit Crew Joined: Jan 2010 From: Walla Walla, Wa I Ride: 1989 Honda VTR250 (x 4), 1984 Honda VF500F (x2) | Ok, did a little Googleing. Your charging system is shared with the CB750 and CB1100 of the same era, and is NOT a permanent magnet alternator. The magnetic field is from a rotor with windings (not permanent magnets) that is fed voltage from the regulator thru brushes. So if the regulator isn't feeding voltage, the brushes are bad, or the rotor windings are bad, the end result is that you have no magnetic field moving past your stator windings to give you output. I'd suggest that you might want to search on a CB750 forum for troubleshooting info, or find a copy of the service manual - too many things involved to just try replacing one at a time until it works! |
![]() ![]() Joined: Sep 2005 From: Bremerton I Ride: 05 KTM 625smc, 03 Are See fiddy one, 05 DRZ470SM, 95 FZR1040, 69 Combat Commando Roadster, 73 Commando Interstate, 67 BSA B44, 71 BSA B50 | rotor windings can be crap too. Measure resistance Specs are in the manual |
| | #16 | |
| Permit Joined: Apr 2012 From: Richland Washington I Ride: 1981 CB 750f SuperSport | Here's a trouble shooting guide for Honda Dohc bikes. http://www.cb750c.com/publicdocs/cha...ng_system.html new link Last edited by Dlittle; 08-23-2012 at 01:56 PM.. Reason: new link |
| | #18 | ||
Rather than diagnosis by replacement you could try unplugging the field coil and applying battery voltage to it to see if you get an output. Borrowing a dc current clamp meter will be a massive asset in finding out what element is at fault in charging systems. Just to get her running you won't need to replace everything. Last edited by Andy Capp; 08-23-2012 at 07:40 PM.. | ||
| Permit Joined: Apr 2012 From: Richland Washington I Ride: 1981 CB 750f SuperSport | |
![]() ![]() Joined: Sep 2005 From: Bremerton I Ride: 05 KTM 625smc, 03 Are See fiddy one, 05 DRZ470SM, 95 FZR1040, 69 Combat Commando Roadster, 73 Commando Interstate, 67 BSA B44, 71 BSA B50 | Not sure but I might have a bottom end. Don't remember if it's still here or not I'll check tonite or this weekend |
