| Newbie Joined: Aug 2012 From: Eastside I Ride: 05 CBR 600rr | Slip on exhaust leak, anyone familiar with Tiger Patch Instant Repair? My RS5 Yoshi slip on pipe fit into the OEM one, but no matter how much I torque the fastner bolt, there is still some play causing exhaust leak. Bought as is: -No clue on the year of the pipe. -No gasket (none shown on the install instructions from Yoshi either). I was recommended to use "Heavy Duty Tiger Patch", muffler or tailpipe instant repair tape. http://s7d5.scene7.com/is/image/CanadianTire/0383732_1?$medium$&defaultImage=image_na_EN[/URL] Does anyone have any experience with this stuff? Or any recommendation to fix the leak? Thanks. |
| Training Wheels Joined: May 2012 From: So. OR I Ride: 2006 CBR 1000rr / 2006 CRF450r / LTR450 | |
| Chicken Strips ![]() Joined: Jun 2008 From: Portland Oregon I Ride: 2002 Aprilia RSV Mille R | Sounds like when tighten down goes the slip on moves at the joint? Can you see the leak? If it pretty tight as is and you if solidly attached you can try the paste/tape items. If leak is bigger one of your parts might be out of round. I had a similar problem (slip on end was oval) and I pulled everything off and a car exhaust shop fixed me up in 5min. Good Luck. |
