| Permit Joined: Aug 2012 From: "The East" I Ride: GSXR | Ok, so here it goes. I have a 2006 gsxr 600. I was riding down the road and as I look down, I see that my temp starts rising past the regular where it usually sits. So as I'm riding, continually checking the temp, it goes up about 10 degrees in fahrenheit than usual and shuts off... I try to start the bike back up, and nothing, dead battery. Long story short, I recharged the battery and check the voltage with the bike running. At idle speeds, all power is coming from the battery, the generator kicks in as the revs increase. Obviously this isn't normal and I have no idea where to start. I've never did any mechanical or electrical work on a bike, but I have worked plenty on cars and know how to use tools. I would really appreciate it, if someone could point me in the right direction. Thank you in advance. |
| Superbiker Joined: Oct 2010 From: Everett, WA I Ride: 05 GSX-R750, 08 675, 72 XL250 | Your fan has stopped working? Low coolant? Start simple and keep it that way. Btw there is a gsxr fault code sticky at the top of this section. Getting a shop manual will help explain things for you as you go, like expecting no/little initial charge at idle rpms. |
| Permit Joined: Aug 2012 From: "The East" I Ride: GSXR | As far as the temp, I believe as the battery lost power, the fan stopped working. I did take a look at the sticky, but no error/fault codes were thrown. So technically everything is working as it should, but my battery is draining awfully fast especially when I'm in traffic and the rpms stay low. Also, the generator is still producing power, just not at low rpms. |
| | #4 | |
| Superbiker Joined: Oct 2010 From: Everett, WA I Ride: 05 GSX-R750, 08 675, 72 XL250 | ![]()
| Pit Crew Joined: Jul 2012 From: granite falls, wa I Ride: with gardening gloves | I know it sounds stupid but always start simple and the retardedly obvious, I've had electrical issues in the past that were nothing but a fuse and or a relay |
| Track School Dazed ![]() Joined: Oct 2005 From: CENTRAL I Ride: When I can | Have you check'd the battery? Have you cleaned the battery cables and terminals? Have you load tested the battery to see if its still good? Have you attempted to recharge the battery? |
| Permit Joined: Aug 2012 From: "The East" I Ride: GSXR | I connected a multimeter and watched the voltage on idle and with throttle open. ![]() ![]() ![]() After talking with some people, I believe the issue is with the rectifier, but im not certain, and will be doing some more tests tomorrow to hopefully figure out whats going on. Thanks all for your input, I highly appreciate it! |
| Shredder Joined: May 2011 From: Everett. WA I Ride: GS1150 Rat bike, NSR(G)500cc two stroke,CBR 900rr | Check the amp draw on the fan too. Could be the fan is dieing/something is stuck in there causing it to over heat? ![]() Just guessing. |
| Permit Joined: Aug 2012 From: "The East" I Ride: GSXR | ![]() Thanks for the input. |
![]() ![]() Joined: May 2011 From: LaCenter, WA I Ride: 2003 Copper SV1K | So it looks like it may be the regulator or the stator. Time to get a manual and test each component. Given that the voltage did rise with RPM, I'm thinking it's actually the stator rather than the regulator/rectifier. Looks to me like there may be a burnt winding or two. IIRC, GSXR's are notorious for cooking stators and rectifiers. |
![]() ![]() Joined: May 2011 From: LaCenter, WA I Ride: 2003 Copper SV1K | ![]() Typically rectifiers either work or they don't. There is a continuity test to be performed with an Ohm meter but you'll need a manual for the Ohm specs and the wires to test. |
| | #14 | |
![]() If you short the temp switch how long will the fan run without the bike running? I highlighted the another part where you don't provide the info needed to help. There is no point to steer us or yourself into a particular diagnosis. For me, you have not ruled out the battery (which seems at this point the most likely from your numbers). How much current can it generate and for how long? Does it match the specs? How long does it take to recharge? Does it have it's full capacity? Unless you are checking your charging system with a current meter you can get very blindsided by a battery that appears to be good as this greatly effects system voltages. | |
| | #16 | |||
| Licensed Joined: Feb 2012 From: Lynnwood, WA I Ride: 1998 CBR900rr for the street and 2007 CBR600rr for the track | Step 1: Buy or download a manual Step 2: Test Stator and regulator per the manual (or a little internet investigation will give you the procedure but every manual ive bought has paid for itself 10x) Step 3: Replace faulty component(s) Im with redkat, uuuusually a rectifier is dead or not, so likely the stator, but do the tests and you'll know. |
| | #18 | |
| | #19 | |
