| Training Wheels Joined: Oct 2012 From: bellevue | F650GS No Power to the Gear Howdy, My BMW F650GS seems to have some sort of problem between the engine and the gearbox (read: clutch?). Gearbox shifts smoothly. I was just rolling down a hill doing some engine braking when it went. The engine runs perfectly, but when I put it in gear, no power is sent to the wheel. Nada. I can switch it into any gear when it's on, so I don't think its a gearbox issue. I had the bike in 1st and was rolling it backwards. Neat! The guy who helped me get the bike home thinks it's a clutch issue. Any thoughts? I really hope it's just a clutch problem. |
| Track School Dazed ![]() Joined: Oct 2005 From: CENTRAL I Ride: When I can | Harbor freight is my friend. They could be yours too! Just replace the damned torx heads with something you like. Like the 8mm hex heads that come on Honda's and Suzuki's! (just be sure to double check the thread pitch)! Damn U-boat drivers! |
| Training Wheels Joined: Oct 2012 From: bellevue | Alright, I stopped by Harbor Freight a third time and finally got the bit I needed. My tool collection is growing splendidly! Anyways, ![]() Does something look wrong to you here? Frickin' spring washer and nut fell off (!) and the sprocket worked it's way off the shaft. End result: Lots of sound, no go. I pulled the chain off and inspected the sprocket and splines--doesn't look like there is any damage. Hooray! I called Ridewest and they have the parts in stock, so I'm going to go pick it up tomorrow and get the sucker back together. |
| Track School Dazed ![]() Joined: Oct 2005 From: CENTRAL I Ride: When I can | That chain needs cleaned, Lubed (every 500 miles or less) and adjusted.(follow your owners manual) If the chain fails, it can cause engine case damage. That can be crazy expensive if not fatal to your bikes engine. It can also be fatal to you if your in heavy traffic at speed. |
| Endorsed Joined: Apr 2010 From: PNW, WA | fbn, you SHOULD have an itty bitty Torx in the tool kit that will fit all them miserable screws. They shaped it to look like an Allen wrench. Weird how that just came apart. I check mine every couple hundred miles, and its never even been loose. And if you're not into scrubbing the chain clean eery few hundred miles, instead of 'normal' chain lube, try using DuPonts Teflon Spray Lube. http://www.webbikeworld.com/t2/motor...n-chain-saver/ Been using the blue stuff for a couple years now, and it works great and picks up about 80% less crap than the greasy lube does. Last edited by DeeG; 10-25-2012 at 07:40 PM.. |
