| Endorsed Joined: May 2010 From: Edmonds, WA I Ride: 1995 Honda Shadow | Help, car broke So I was trying to turn left at a light in first gear (manual transmission civic 97) when I heard a thunk and was no longer moving forward. I am thinking transmission issue? The car is in Redmond just off Avondale and I need some recommendation for a tow truck and where to take it. I'm kind of frustrated as I just spent $900 on tires and alignment (alignment was way off, took a kit to get it near right) Any advice is appreciated! |
| Novice Racer Joined: Aug 2006 From: Around I Ride: 2006 GSX-R 600 | |
| Licensed Joined: Sep 2010 From: beaverton or I Ride: 82 honda sabre v45 | will the engine still run? did u try and put it back in gear? or try second so see if first might of gone out but still have second? or reverse. once and a while i will have that happen and its popping out of gear since i didnt engage it all the way. as for tow company grab a phone book or look it up most will be fine just make sure if u have it lowered to ask for a flat bed truck or the reg one will have the rear of the car scrapping.. |
| Endorsed Joined: May 2010 From: Edmonds, WA I Ride: 1995 Honda Shadow | Would move in any gear, I tried them all. The engine runs, Im thinking transmission or CV joint? It is not lowered, its stock, I know no one drives a stock civic Also found out I have Good Sam towing so that helps. |
| | #5 | |
| Endorsed Joined: May 2010 From: Edmonds, WA I Ride: 1995 Honda Shadow | ![]() | |
| Endorsed Joined: May 2010 From: Edmonds, WA I Ride: 1995 Honda Shadow | I appreciate the thought, I wish I knew how to fix one but last time I had the opportunity my dad said no (91 Subaru Legacy when I was 16) and now in an apartment I don't have the space to take anything apart. Someday I will own a home with an awesome garage.... |
| | #8 | |
| Streetfighter Joined: Feb 2007 From: Seattle I Ride: 06 600RR | ![]() ![]() | |
| Licensed Joined: May 2011 From: Vancouver,WA I Ride: 2002 Aprilia Falco, 1991 CBR 1000F, 1998 KX250 | ![]() The CV probably popped out of the transmission. Not uncommon with Honda. Generally you can pop them back in to get you moving but it most likely wont stay there. |
| | #10 | |
| Novice Racer Joined: Aug 2006 From: Around I Ride: 2006 GSX-R 600 | http://www.cascadeautollc.com/ Relatively close to where your ride is. And he may or may not work there depending on what the rules of giving out somewhat personal information are on this forum. |
| | #12 | |
| Endorsed Joined: May 2010 From: Edmonds, WA I Ride: 1995 Honda Shadow | also http://www.cascadeautollc.com/ is lacking in good reviews....and reviews in general. |
| Endorsed Joined: May 2010 From: Edmonds, WA I Ride: 1995 Honda Shadow | I like my civic its cheaper to fix than many other cars and fits in small parking spaces, though I would rather be on my bike any day.... |
![]() ![]() Joined: May 2011 From: LaCenter, WA I Ride: 2003 Copper SV1K | There is a small clip on the end of the axle. They get worn out and the axle pops out. If it pops out again you will need a new clip. Looks really similar to a car key ring. |
