Old 12-11-2012, 05:02 PM   #1
Treavor's Avatar
I Ride: 2005 R1, 2004 R1, 2001 R1, 2002 R6, 2003 R6 (Sold)
Rust in tank
Just started a new project. Am I correct in assuming that rust inside a gas tank is not possible to remove? Never ran into the issue before. There any home methods or products that can remove rust at all?
Old 12-11-2012, 05:18 PM   #2
GRN
I Ride: 2 wheels
Do a search on st.n and ADVrider, I'm sure there will be plenty of info there.
Old 12-11-2012, 05:22 PM   #3
I bathe with candles, flowers, jazz music, and rubber ducky.
galenernest's Avatar
I Ride: in my wet dreams
I've had good luck with the Kreem treatment... It's a kit that's about $25 and it works well if you follow the directions precisely. If you screw it up, though, it becomes a huge mess.
Wow, the price went up a bit... here's a link
http://www.bikebandit.com/kreem-fuel...iner-combo-pak
Old 12-11-2012, 05:23 PM   #4
Prep's Avatar
I Ride: 2002 R1
i used metal rescue it worked good and you can reuse i found it on the net
just let it set overnight
http://www.metalrescue.com/home.aspx
Old 12-11-2012, 05:30 PM   #5
MidwesterneRR's Avatar
I Ride: 1998 CBR900rr for the street and 2007 CBR600rr for the track
There is a kit you can buy that will remove and coat, i personally dont think kreem is the best product. POR 15 seems better.
http://www.svrider.com/forum/showthr...k+rust+removal
Ive used electrolysis to remove rust, it works well, but should really be followed up with a coating kit anyway.
Old 12-11-2012, 05:58 PM   #6
This!! Electrolysis to remove the rust, POR-15 to seal the tank. Kreem, IMO, is a terrible product.
Old 12-11-2012, 06:52 PM   #7
Dave R's Avatar
I Ride: motorcycles
this is what our favorite painter and tank restorer Russ Foy at Custom Classics uses to coat them once cleaned out. It is also a very popular product used to help prevent the swelling of plastic tanks used on Ducati's and others. As with any product proper prep and application is paramount. He generally charges around $200 to get rust out, seal tank and a quick paint buff.
http://www.caswellplating.com/restor...nk-sealer.html
article
http://www.webbikeworld.com/t2/caswe...l-tank-sealer/
Old 12-11-2012, 07:49 PM   #8
Squidward's Avatar
I Ride: '98 Valkyrie, '75 CB400F Cafe
Electrolysis then POR15 or bill Hersch... Both work great if you follow instructions precisely
Old 12-11-2012, 09:21 PM   #9
RC51's Avatar
I Ride: Motorcycle
I've seen videos of guys filling their tanks with screws or aquarium gravel and shaking the shit out them (or putting them in a dryer) to get it all out. Doesn't work as well as electrolysis though.
Old 12-11-2012, 09:27 PM   #10
Mitch F's Avatar
I Ride: every god damn day
Here's the DL. I've done this plenty of times.
First, strip the tank of everything possible. Petcocks, fuel pumps etc. Plug all petcock bolt holes, vent holes etc etc so the tank is watertight. Fill (to the brim) with white vinegar and various nuts/bolts, and seal it up. Shake it really well every hour or so, then let it sit overnight. The acidity of the vinegar will eat away the rust. Drain the vinegar and rinse VERY well with HOT water. Set the tank somewhere to dry (I like to put it very near a heater or heater vent to evaporate the water quickly). Once it's dry, POR-15 it.
Search for POR-15 instructions for motorcycle tanks for detailed instructions.
DO NOT LET THE POR-15 PLUG ANY HOLES IN THE TANK. Petcock holes, bolt holes etc. IT DRIES EXTREMELY HARD AND IS NEAR IMPOSSIBLE TO REMOVE ONCE CURED.
After the tank is cleaned and POR'd, you will never deal with rust again. Ever.
You're welcome.
Old 12-12-2012, 03:51 PM   #11
Treavor's Avatar
Thanks guys. ill do some research on these products and see whatll work for me. didnt know there was so many options for this.
Old 12-12-2012, 04:59 PM   #12
RevrdMark's Avatar
I Ride: 05 Speed Triple - " Hopper ", 78 Yam XS400 - "Cranky"
I used electrolysis to de-rust two tanks on my cafe project and it worked great.
There are a couple pics of my set up in the build thread 1978 xs400 cafe build. There are a zillion Utube videos how to do it and web sites explaining it.
Old 12-12-2012, 05:57 PM   #13
Sentor's Avatar
We're going to be using the por15 this weekend on a severely rusted tank. We'll let you know how it works.
Old 12-12-2012, 06:59 PM   #14
Forum Admin
I Ride: '05 Busa, '81 Seca 550, '78 Hawk, '69 Z50A
I've used the "handful + of washers" with gas several times with pretty decent results..
The one time I had a tank that was not only rusted, but had a few pin holes in it, I found that my local radiator shop was the ticket.
He completely cleaned the inside, soldered the holes shut, and Redkot'd the inside. All for a whoppin 50 bucks. Kind of tough to beat a deal like that...
Old 12-16-2012, 12:36 PM   #15
I Ride: ... here and there
For removing rust, if you don't have an electrolysis rig, and don't want to deal with nasty chemicals, go with EvapoRust.
EvapoRust
I've used it and it works great. One of the safest to use that's out there, afaik. Easy clean up. I found it at Harbor Freight, but check their website for other retailers.
Old 02-22-2013, 08:02 PM   #16
take risks's Avatar
I Ride: with a smile
This thread made my day.
POR-15 it is for me.
Old 05-29-2014, 10:07 PM   #17
Dvonahn's Avatar
I Ride: 1995 kawasaki ZX6R
Would it be ok to use the air hose and shoot some air up through all the holes after I coat it before it dries to clear them out? My POR-15 should be here tomorrow
Old 05-30-2014, 11:57 AM   #18
Mitch F's Avatar
That should work, but I'd use low pressure so as not to disturb any more POR than you have to. Also, it will run like a mother fucker, you very well may have to do it every half hour or so until it's cured enough to not drip/move/etc
Old 05-30-2014, 02:40 PM   #19
102warrior's Avatar
I Ride: 01 Futura, 990 Adventure
I just used metal rescue on an old three wheeler tank, it worked better than the white vinegar for me. Do keep the solution warm like they describe. But I really like the water soluble and not having to worry as much about disposal. Just my 2 cents
Old 05-30-2014, 04:26 PM   #20
tunus's Avatar
I Ride: 2009 Triumph Street Triple R and 03 Yamaha WR450F (plated)
I vote for electrolysis + POR15. The POR15 steps took me almost half a day to complete properly , but the results were excellent.
