| Streetfighter Joined: Dec 2005 From: Bellevue, WA I Ride: all styles. | Plastic welding vs. JB Weld What are the advantages/disadvantages of plastic welding versus JB Weld on a "bullet"-style mounting tab? Here's a picture of what broke: ![]() |
| Novice Racer Joined: Feb 2006 From: Ames Lake rd I Ride: Yamdalarisosaki's w/ a nos! | You might possibly be able to get away w/ using Plasti-weld, I've found the stuff in the black dispenser(sp) to be stronger than that in the clear dispenser Im thinking it might bond a little better due to the chemical reaction ,than the JB I know theres a guy on CF that can weld plastic (Lauralynn's ol' man or??) good luck to you w/ it |
| Superbiker Joined: Mar 2005 From: Brooklyn, NY I Ride: GSXR | They are both right but I would plastic weld it. Plastic weld will make one solid piece rather than jb weld adhering two pieces together. If you do jb weld it rough the shit out of the surrounding area and apply widely to give it something to grip to. |
| Novice Racer Joined: Apr 2006 From: seattle I Ride: 1krr | i was told by a very experienced mechanic that plastic welded my fairings that plastic welding mounting tabs isn't the best idea. He suggested JB weld. I forget why... |
| Novice Racer Joined: Feb 2006 From: Ames Lake rd I Ride: Yamdalarisosaki's w/ a nos! | I wasn't awake enough to notice "bullet style" mounting I'd also opt for JB over Plasti-weld in that sitch but a actual plastic welder would be best IMO Soggy... great tip! Im gonna use that 1 next time I need!! |
| Railer Joined: Feb 2005 From: West Richland I Ride: Pitster Motard | 2-part plastic epoxy. WAY better than "plastic welding" with heat, chemically bonds itself in a way that no other epoxy can beat, and still maintains the original (though small) bit of flexibility. Get it at Wally World, or just about any auto parts place. Usually comes in a black plastic dual-syringe style. I prefer the Devcon brand, but just about all of them are the same. |
