| | #81 |
| Licensed Joined: Dec 2006 From: Kennewick, WA I Ride: DRZ400SM (Dirted) | Me either. Mazda Milena 95-99 was the one I was looking for and it was used successfully because of electronic variable valve timing worked out the bugs of the Miller cycle. |
| | #82 |
| Superbiker Joined: Mar 2005 From: Brooklyn, NY I Ride: GSXR | ![]() You gotta ask a question after you answer. |
| | #83 |
| Superbiker Joined: Mar 2005 From: Brooklyn, NY I Ride: GSXR | Ok I'll get it going again. No calcs on this it should be super easy if you know what your talking about. A bike is putting out 50ft/lbs of torque at 7500rpm is putting out 71hp. The same bike putting out 50ft/lbs of torque at 15000rpm is putting out how many horsepower? |
| | #85 |
| Superbiker Joined: Mar 2005 From: Brooklyn, NY I Ride: GSXR | You are correct! Now ask a damn question! Ahem... please ask a question. |
| | #87 |
| Superbiker Joined: Mar 2005 From: Brooklyn, NY I Ride: GSXR | ![]() Anyways, a particle collector is used to attract stuff the EPA deems harmful to humans. Before installing new clutch fiber plates you must do this for five hours before installing them? |
| | #88 |
| Licensed Joined: Dec 2006 From: Kennewick, WA I Ride: DRZ400SM (Dirted) | Yes, for the first part but they serve a different purpose on VERY large engines. They precipitate oil particles from the crankcase to prevent an explosion hazard. ok, motorcycle question: What is the reasoning behind left-hand kickstarters on enduro bikes? |
| | #89 |
| Superbiker Joined: Mar 2005 From: Brooklyn, NY I Ride: GSXR | I would hazard to guess its so the right leg has brake control if bike stalls in a bad spot? Or if the the grade is not optimal its easier to get off the bike and kick start it with your right leg? hmm... |
| | #91 |
| Superbiker Joined: Mar 2005 From: Brooklyn, NY I Ride: GSXR | I thought you had me on that one! Explain how a two stroke expansion chamber works and why they can only be tuned to one rpm band at a time? For bonus brownies, how does exhaust water injection help improve performance? |
| | #92 |
| Licensed Joined: Dec 2006 From: Kennewick, WA I Ride: DRZ400SM (Dirted) | The expansion chamber acts like a vacuum for the exhaust head pipe. As gasses flow into the larger chamber, the pressure drops and exhaust is pulled into the chamber, pulling exhaust out of the header pipe and assisting in evacuating the cylinder. The "tuning" comes into play when the exhaust gasses pressurize the chamber to the point that it no longer helps evacuate the cylinder. Larger volume chamber=more rpm's. Bonus: Water injection flashes to gas in the header pipe, expanding rapidly into the chamber and allowing the bike to be "on the pipe" at relatively low rpm's. |
| | #94 |
| Superbiker Joined: Mar 2005 From: Brooklyn, NY I Ride: GSXR | ![]() When increasing the stroke of an engine what is the most significant improvement in engine output? |
| | #95 |
| Licensed Joined: Dec 2006 From: Kennewick, WA I Ride: DRZ400SM (Dirted) | "F" originally stood for "footshift" the letter came along when they switched from the handshift on the tank. As for the stroker, I would say the biggest improvement would be on the torque curve. Moving the rotational mass and forces applied to the crank farther from the center of rotation, it seems logical. A total guess though. |
| | #96 | |
| | #98 | |
| Railer Joined: Feb 2005 From: West Richland I Ride: Pitster Motard | ![]()
| | #99 | |
| Chicken Strips Joined: May 2005 From: Cheney I Ride: slow old bikes - fast as they will go | ![]()
Why are Earles forks better than telescopic forks for sidehacks? | |
