| Superbiker Joined: Mar 2005 From: Brooklyn, NY I Ride: GSXR | Technical Question Game Answer the question correctly then ask one of your own. I'll start it off. Why do most manual transmission vehicles whine in reverse? |
| Cavalier Champion! Joined: Jan 2006 From: Spokane I Ride: The couch... | because reverse gear is a spur cut unlike your forward gears which are helical cut. The whining is caused because a spur gear has straight teach as opposed to the helical gears which have helically cut. This allows the idler gear to make your car go backwards.... Next Question; What car actually uses a muffler bearing? |
| Superbiker Joined: Mar 2005 From: Brooklyn, NY I Ride: GSXR | Some cars use bearings in flaps in the muffler to change flow. Example BMW e36, some mercedes cars, and the african built toyota yaris. Is this right? I won't ask a question until I know I'm right. |
| Cavalier Champion! Joined: Jan 2006 From: Spokane I Ride: The couch... | Very good On the VW Baja it was a junction that allowed water drainedge haha because the exhaust tip stuck up at a verticle angle which allowed alot of water to get into it when it rained hehehehe |
| Pit Crew Joined: Mar 2006 From: Spokane, Wa | Motorcycle or Car? Most cars are self adjusting and use roller rockers so no clearance is serviceable. Motorcycle most of the time the clearances become loose and that is the tapping you hear. But I have on some occasions seen tight exhaust valves. Not exactly sure why, I heared at MMI that the exhaust valve shims grow due to heat, but did not make since, more like the shim was to tall and set up to tight in the first place. Question: How long should a sportbike tire be ridden on before being changed? and what are wear bars? |
| | #9 | |
| Superbiker Joined: Mar 2005 From: Brooklyn, NY I Ride: GSXR | ![]()
You should replace your tire if is either down to the wear bars or reached its heat cycle limit or of course is damaged or cracked. Why do two strokes typically put out more hp than four strokes of the same displacement? | |
| At Banned Camp Joined: Apr 2006 From: bellevue I Ride: aprilia | ![]() what's the name of a rotary (wankel) motor's equivalent to a crankshaft? |
| At Banned Camp Joined: Apr 2006 From: bellevue I Ride: aprilia | ![]() it's not called a crankshaft. |
| At Banned Camp Joined: Apr 2006 From: bellevue I Ride: aprilia | ![]() i thought this was a "answer one THEN ask one forum"? |
