Old 03-27-2008, 04:22 PM   #1
Question Ducati Maintance question?
748's, 1000's. What makes a 6K service $800.00?
What all is done on a 2 cylinder, 4 valve engine?
Old 03-27-2008, 04:36 PM   #2
midlman's Avatar
I Ride: 04 998 Ducati (Matrix Edition) 91 BMW R100GS Paris Dakar, 93 Kawasaki ZX-11
Parts are about $250..the rest is labor believe it or not..
Nothing too major about the 6k service..belts are around the 12k mark or 5 years (I think)..
Old 03-27-2008, 04:57 PM   #3
Pilot in Command
RVFR's Avatar
I Ride: Honda............Ducati?
Parts what parts?
Old 03-27-2008, 05:18 PM   #4
midlman's Avatar
Couple of o rings..valve cover gasket..oil filter...I'll dig up my quote and see what else..
Old 03-27-2008, 05:23 PM   #5
FatMatt's Avatar
I Ride: 1972 Schwinn Sting-Ray
Ducati O rings = $25.00 each!
Ducati Valve cover gasket = $125.00
Ducati Oil filter = $75.00
That looks about right!!!!
Old 03-27-2008, 05:33 PM   #6
Matt, your as helpful as Tits on a Nun!
Old 03-27-2008, 06:19 PM   #7
Pilot in Command
RVFR's Avatar
LOL sounding like helicopter parts to me..
Old 03-27-2008, 06:20 PM   #8
winter rules's Avatar
I Ride: 1997 cbr 600f3, kx 500
Old school chevy alternator $30-50
New school VW alt $300-400
Audi same alt as VW $300-600
I might be a bit off on the prices but still it is just a device to charge the battery and keep up on the electrical system draw. I guess if you can pay for the name lets hope you can afford to pay for the game.
I agree though WTF sooooo much.
Old 03-27-2008, 07:32 PM   #9
Buz
Buz's Avatar
I Ride: 08 Zed x 10R
Old 03-27-2008, 07:42 PM   #10
ducatiduane
the chemist's Avatar
Belts are every 12k or every other year. However, you must pull the belts to mess with the rest...so, doing a belt change is nothing but the 80 bucks for parts. Since they have to be readjusted anyway.....
Old 03-27-2008, 08:59 PM   #11
I Ride: A lifted JK 0|||||||0
servicing a 4v ducati (pre testastretta heads) is an all day affair.the valve adjustment is a complete pain in the ass and unless you have a really high lift, the front exhaust requires you to be upside down for quite a bit.
the 2v ducati requires a bit less time and is much easier to deal with, but it still takes the better part of 6 hours to do a complete service on one. at todays labor rates, that is about $500 + parts
the testastretta heads are a snap to do the valves on. just dont take off the timing belts without ducati special tool or you are fucked. the timing marks on the thing make no sense. the punch marks on the cogs are for the pre testa heads. if you try to time one like the early 4v heads, it will never happen.
Old 03-28-2008, 08:21 AM   #12
Sounds to me, I'd be at the mercy of a Ducati shop.
While I do have my own lift, this sounds way too complicated.
I think I better pass. I like working on my stuff myself.
Old 03-28-2008, 09:04 AM   #13
Dragonfish's Avatar
I Ride: in between bikes
At these prices I think I'll just buy an old non-running duc, use it as a museum piece or better yet, fancy doorstop.
Old 03-28-2008, 09:07 AM   #14
96ssportsp's Avatar
I Ride: 2005 Ducati 1000s DS Multistrada: Moto Guzzi Quota
James,
What are you looking at?
Remember the $800.00 is for a complete service. Lots of that you can & would do yourself. Valve inspection/adjustment might need to be done at a dealership. Scott.
Old 03-28-2008, 09:50 AM   #15
midlman's Avatar
Originally Posted by 96ssportsp View Post
James,
I can't find my 6000 mile service quote...but for the most part..everything on it was something I could easily do myself. I didn't see the valve adjust on there..or any belt replacement..which are the two things I would likely have a shop do first (while I watch)..and then in the future do it myself.
If you are relatively handy, I have no doubt that you can do most of the service yourself. If not..you are at the mercy of the dealer..
Old 03-28-2008, 04:34 PM   #16
your 6k service should include valve adjustment and belts. as i have mentioend before, the bulk of the work is the valve adjustment. that is what you are paying for, the rest of it is icing in the cake.
and good luck finding a shop that is going to let you hang out and watch. shops charge for service, not training customers
Old 03-28-2008, 05:40 PM   #17
midlman's Avatar
Even the recommended service guidelines I found only suggest checking the belt ...and replacing at 12k... either way...if they wouldn't let me watch..then I'd just do it myself with the guidance of the web
Old 03-28-2008, 07:56 PM   #18
i am assumming you have a testastretta head bike from the info on your stats. it wont happen on your model unless you so happen to have the special timing tool to put the belts back on and the ducati diagnostic tool called mathesis. the tool actually listens to the harmonic ferquency of the belts. it is important thast the belt have a frequency of 140hz or the valve timing will walk and it could start to advance if the belt is too loose or retard if the belt is too tight. too tight can also lead to catastrophic belt failure and then the end of your motor and possibly you if the motor grendades at speed locking your rear wheel and pitching you off into oblivion.
once again, there is a reason why proper ducati service is expensive. the average joe does not have the proper tools nor training to do it right.
Old 03-28-2008, 08:49 PM   #19
Buz
Buz's Avatar
Bravo,well said and thank you..
Old 03-28-2008, 08:53 PM   #20
tits are helpfull on nuns. all those poor orphans need something to suck on.
