Old 02-26-2011, 06:39 PM   #21
suomycasino's Avatar
I Ride: 2006 Gsxr-600
Been away from the PNW for about 2 years now so i have drifted away from this forum. I still receive notifications to this thread, so if anyone has any questions feel free to ask.
Old 08-31-2011, 06:16 AM   #22
do you know where the terminal is for a 2000 750?
Old 03-31-2012, 10:21 PM   #23
Giday guys I have a strange question for you.
i have a Harris Magnum which is fitted a GSXR1100 Oil Cooled engine.
i am currently modifying to fit a GSXR1000 '04 Throttle Bodies and ECU instead of carbs.
I have finally got to the start up stage and I have a couple of codes coming up which I would like your advice on seeing as I don't have or own a Gixxer thou I don't have experience with these models.
Thanks for the advice as to the Dealer mode for checking codes certainly helped with some head scratching moments.
My questions are as follows.
I have codes C15 ECTS, C28 STVA, C29 STPS and C46 EXCVA being shown.
C 15 & 46 should not stop the motor from starting but the two codes C28 & 29 are not letting me start (Engine Turns but no Ignition and possibly no fuel)
does anybody have any ideas how I can fix any of these conditions to at least allow me to get the motor started.
Thanks in Advance.
Old 04-18-2012, 06:37 AM   #24
I tried this on my K4 600 and it only has 3 prongs I used the paper clip and my bike was okay before i just wanted to see what was wrong with the FI light since it was on after nothing worked I cranked my bike and it didn't turn over the light just blinked repeatedly, it would crank but never started up, I checked my fuel lines for pressure, spark plugs for spark injectors, everything worked fine but Im wondering if maybe since I did that it messed up the computer or somehow,. Help please :\
Old 04-18-2012, 07:52 AM   #25
RideMotto's Avatar
I Ride: 2008 GSX-R1000, 2008 Ninja 650R SOLD
Cool and easy way to check the fault code. Thanks for the info.
Old 12-28-2012, 12:15 AM   #26
norwes's Avatar
I Ride: 06 gsxr 1000
Thanks dude
Old 04-14-2013, 12:35 PM   #27
Something I feel could be useful for this thread:
C14 - THROTTLE POSITION SENSOR
C15 - ENGINE COOLANT TEMPERATURE SENSOR
C21 - INTAKE AIR TEMPERATURE SENSOR
C22 - ATMOSPHERIC PRESSURE SENSOR
C23 - TIPOVER SENSOR
C24 - IGNITION SIGNAL #1
C25 - IGNITION SIGNAL #2
C26 - IGNITION SIGNAL #3
C27 - IGNITION SIGNAL #4
C28 - SECONDARY THROTTLE VALVE ACTUATOR
C29 - SECONDARY THROTTLE POSITION SENSOR
C30 - SECONDARY THROTTLE CONTROL UNIT
C31 - GEAR POSITION SENSOR
C32 - INJECTOR SIGNAL #1
C33 - INJECTOR SIGNAL #2
C34 - INJECTOR SIGNAL #3
C35 - INJECTOR SIGNAL #4
C41 - FUEL PUMP CONTROL SYSTEM
C42 - IGNITION SWITCH SIGNAL
C46 - EXHAUST CONTROL VALVE ACTUATOR
C00 - NO FAULT
Old 06-20-2014, 12:13 PM   #28
Fault Code Checking Procedure
Hi
I refer to the post you sent for how to check dealer codes (2008 ), I own a K3 Suzuki GSXR 600 and the 6 prong plug you refer to is not there under my seat. Is it possible the plug could be situated elsewhere on the bike? The photographs clearly show a fuse cover, with various fuse amp sizes written on it, with a silver background. My fuse box is not under the seat.
Any help in this matter would be greatly appreciated.
Regards
And R
Old 06-20-2014, 12:23 PM   #29
Here you go:
K3 Dealer Mode, just link 2 wires together to get into dealer mode. You'll find them under rear seat cowl opposite side from the exhaust. Mine has a little rubber cover over the end of the white plug connector thingy. The colors your looking for are:
GREEN Wire with a White Stripe and GREEN Wire with a Red Stripe.
Old 06-20-2014, 12:52 PM   #30
Thanks for the quick reply, I did remove both seats, but I think the reason why I could not find the plug you refer to is because I was convinced it was situated under the riders seat nearest to the tank and where the battery is directly underneath. I must admit from looking at the photographs I never thought it was under the pillion seat, where the plastic tool roll is stored.
Many Thank's
Andy R (UK)
Old 06-20-2014, 01:19 PM   #31
TREX 600's Avatar
I Ride: 09 GSX-R1000 09 DRZ 400SM 1970 Yamaha DT250 enduro
Thanks
Old 12-23-2014, 05:06 PM   #32
I tried doing this and I hooked the paper clip to the wrong cables.
When I turn my kill switch to on nothing happens now. And obviously if I try to start
It doesn't turn. Any advice?
Old 12-23-2014, 06:16 PM   #33
Check your fuses.
