| Streetfighter Joined: Apr 2007 From: Arlington, WA I Ride: A fast bike, VERY slowly. | Headlamp limitations? So I'm looking into some aftermarket lighting for my 10, and I was wondering if anyone knew how much wattage the stock system can handle? I've found some 100w monsters online that would be inSANE, but I don't wanna fry anything. An important note is that these lights will be replacing the stock headlamps, so I'm starting w/ zero wattage. Dumb question, I'm sure, but wiring and lighting are f'ing Greek to me. |
| MotoGP Champion ![]() Joined: Jul 2006 From: Pullman, WA I Ride: '73 CB350F, '86 VFR750F, '00 Aprilia RS250, '04 Aprilia RSV1000 R Factory, '07 Vstar 1100 Classic | If you want pure unadulterated light, go with an HID conversion. They make units that retrofit most bulbs and run at a lower wattage than incandescent. |
| Superbiker Joined: Apr 2007 From: Bothell, washington I Ride: In the rain. You should clean the sand out of your vagina and do the same. You live in washington ya know? | HIDs are the shit. best thing you can do for yourself if you ride at night! I love mine, its the first thing I will to any other bike I buy! |
| Streetfighter Joined: Apr 2007 From: Arlington, WA I Ride: A fast bike, VERY slowly. | ![]() The other problem is that the current lights I have now are non-standard, so finding the HID conversion will be ghey. I want to bolt up some PIAA Dichroics (sp)... mmm. ![]() |
| Superbiker Joined: Apr 2007 From: Bothell, washington I Ride: In the rain. You should clean the sand out of your vagina and do the same. You live in washington ya know? | ![]() you can see how bright an HID low beam is compared to a standard high beam. My kit was a retrofit done by me with a balast and harness from a new lexus. $Free.99 |
| Streetfighter Joined: Apr 2007 From: Arlington, WA I Ride: A fast bike, VERY slowly. | Scratch that. Kit is less than the price of new lights. I'm all over this shiat. Thanks guys!!! |
| MotoGP Contender Joined: Dec 2005 From: bothell I Ride: hayaboosta | me can gets you quality HID conversion for $299. 2 bulbs set. halogen is ghey and for the weak ![]() |
| Superbiker Joined: Apr 2007 From: Bothell, washington I Ride: In the rain. You should clean the sand out of your vagina and do the same. You live in washington ya know? | there are companies online that sell conversion bulb clips so you can slide the HID bulb in the same place as the original in any headlight bucket. |
| MotoGP Champion ![]() Joined: Jul 2006 From: Pullman, WA I Ride: '73 CB350F, '86 VFR750F, '00 Aprilia RS250, '04 Aprilia RSV1000 R Factory, '07 Vstar 1100 Classic | ![]() I've found a retrofit for everything from a typical H4 to much more obscure ones like H13, H10, H8 and even an H1! What retrofit are you looking for? Do you want to maintain a low/high beam? It can be done purely in HID...don't fall for the retrofit kits that use a regular halogen for the high beam... If you do insist on using PIAA, I would recommend the Xtreme White instead of the Dichroics...better usable light spectrum without melting the plastic headlight housing and bike wiring. The only reason I run them instead of HID is because I also have modulators...otherwise I would have HID in everything... Last edited by JohnnyM; 08-12-2008 at 11:48 PM.. |
| | #10 | |
| Streetfighter Joined: Apr 2007 From: Arlington, WA I Ride: A fast bike, VERY slowly. | ![]() ![]()
![]() EDIT: PM SENT. I'll probably call you in the AM, too. Last edited by TRAIL BOSS; 08-13-2008 at 12:11 AM.. | |
| Zone Head ![]() Joined: Mar 2008 From: Seattle, WA | as previously stated, the conversion kits are all very similar and run ~$90-$120 (I havent found any of the $90 ones yet) - these dont include the projectors - they expect you to plug them into your stock reflector housing. My issues is that I was looking at it as a stock headlight replacement - which means I need the projectors too. And then there is the issue with having to go through state inspection. Im a lot concerned about whether they would pass a non-standard projector setup. |
| Zone Head Joined: Oct 2005 From: Burien WA I Ride: 2001 Hayabanondamahauell 1200, 2008 ZX14 Ninja of DOOM | ![]() TB, go to starrotors.com. A friend of mine has their setup and its NICE. 119, no tax, free shipping. SLIM digital ballasts (what you want) in any color temp you want. Thats for 2 bulbs/ballasts. ![]() These are just bulbs, no reflectors. Installation is def more of a pain if you need housings too, but worth it. HIDs in the wrong housing are bright, but throw light everywhere.... Last edited by ninjaofdoom; 08-13-2008 at 08:01 AM.. |
| | #13 | |
| | #14 | |
| At Banned Camp Joined: Aug 2006 From: Kirkland | ![]()
You have projector headlights already tiger... | |
| Zone Head ![]() Joined: Mar 2008 From: Seattle, WA | uhhhhh shudup! you know what I meant. but do I....(that is the real question)? ![]() hang on...can you remove the projector housings from our headlight assy's? or are they integral? Last edited by vagrant; 08-13-2008 at 11:40 AM.. |
| At Banned Camp Joined: Aug 2006 From: Kirkland | ![]() Alright so you don't have two true projectors. The high beam is...the low beam is diffused to spread the light around. If you want true true projectors, you can do something like this...or this kit Or you can just buy bulbs and be done with it. Last edited by wordsareforplay; 08-14-2008 at 08:28 AM.. |
