| | #41 |
| Je Fa Fa | it is a hell of a good thread to dig up though. |
| | #42 |
![]() ![]() Joined: Jul 2005 From: Tri-Cities Blog Entries: 1 I Ride: '05 Busa, '03 KLR 650, '81 Seca 550, '78 Hawk, '71 SL 350, '69 Z50A | While it is nice of you guys to stand up for the new guy... a couple of questions for ya; *Do you know anyone that has paid 160$ for an aluminum sprocket? (if you do...send them my way, I've got some stuff I'll sell 'em.) *Do you know anyone that completely wore out an anodized aluminum sprocket on the street in one summer? Unless they put 10-12K on.... I'll bet DR noticed those two items.. and that is most likely the reason for his comment. We've been dealing with a bunch of worthless older-than-dirt thread bumps lately... it is frustrating when these come back up without any intelligent information. It merely plugs up the home page with junk. If you have good information that adds quality content to the thread, by all means... put it in. Keep in mind, this is the Mechanical and Technical area... not a great place for BS posts. Last edited by mjn; 10-29-2012 at 10:19 AM.. |
| | #43 |
![]() ![]() | I wore out two this summer before I got a steel one, although I did a few track days and using a 520 Al sprocket on an SV1000 may not be the best idea. |
| | #45 |
| Peg Dragger Joined: Mar 2012 From: Gig Harbor, WA I Ride: 2002 Honda VFR800 | I replaced my sprockets this summer. I ride a VFR so it was a no brainer to go Steel. I commute with occasional joy rides and no track days. In my searches i found a titanium set that was lifetime guarantee to never need replacement. I dont have time to look it up again. They were spendy tho. My thought, Since sprockets are so close to the center of rotating mass i dont think they will have noticeable difference (if you stay stock 530). If you switch to 520 i hear the weight savings is in pounds which i imagine would make a difference. That being said, there is a reason they use 530 as stock...Longevity... So if you are a racer go 520 with AL or Titanium. If your not a racer standard 530 Steel. If your rich, why do you care? do what you want! |
| | #46 |
| Moto2 Contender | Bikes are already too damn heavy. I go with aluminum and do notice a slight difference (along with the smaller-gauge chain). |
| | #47 |
| Peg Dragger Joined: Mar 2012 From: Gig Harbor, WA I Ride: 2002 Honda VFR800 | That would mean you are running a 520 setup? which i have heard does make a difference... |
| | #48 |
| Moto2 Contender Joined: Sep 2008 From: where they don't have lawns. I Ride: Red bike, Brown truck, various collections of junk held together poorly. | ![]() ![]() |
| | #49 |
| Streetfighter Joined: Mar 2008 From: Kingston I Ride: the short bus ....... with your mom in the back. | I'm calling bullshit on that one. I can see telling the difference between a 530 and 520 chain kit, but just changing the sprocket out for an aluminum one? I don't think so. |
| | #50 |
![]() ![]() Joined: May 2011 From: LaCenter, WA I Ride: 2003 Copper SV1K | It also wears out much faster..... |
| | #51 |
| Streetfighter Joined: Mar 2008 From: Kingston I Ride: the short bus ....... with your mom in the back. | Not always the case. Too many variables to make a blanket statement. There are quality 520 chains out there that have more tensile strength than cheap 530 chains. Then there are the different ring types, o, x, r, whatever they come up with next. I'd take a quality 520 over a cheap 530 any day of the week. |
| | #52 |
| Moto2 Contender | I changed from steel to aluminum and 530 to 520. Made a noticeable difference. |
| | #53 |
| Streetfighter Joined: Mar 2008 From: Kingston I Ride: the short bus ....... with your mom in the back. | Exactly, you changed both at the same time. |
| | #54 |
| Moto2 Champion Joined: Mar 2006 From: spokane, wa I Ride: 2008 SXV4.5 + 1985 RZ350 + 2010 YZ250F + | I remember an article from an old magazine that weighed the OEM set and a 520 aluminum rear/steel counter shaft sprocket set that seemed like it saved 3.5 lbs or so. That's not insignificant by any means, and will have an effect on rotating mass and unsprung weight. |
| | #55 |
| Shredical | On sports bikes I won't bother with aluminum sprockets. I've had them wear out in under 3k miles. There's more than enough power there to compensate for the tiny bit of weight difference you get from steel. In the dirt, I've run both steel and aluminum without noticing much of a difference. I've run both steel and aluminum on my trail and MX bikes without noticing a difference in weight, power or wear... so I just go for whatever is cheapest. |
| | #56 | |
| Streetfighter Joined: Mar 2008 From: Kingston I Ride: the short bus ....... with your mom in the back. | ![]()
Comparing aftermarket 520 aluminum sprockets to OEM 530 sprockets isn't going to be a good comparison. It's apples and oranges. Start by comparing a set of 520 sprockets in different metals. Or the same with 530. | |
| | #57 | |
The issue with the 520 set is that the tooth area is significantly smaller as is the roller itself. This leads to more pressure on the roller and tooth surface area which leads to more wear. Add aluminum sprockets into the mix and you get even less mileage out of them. I agree, don't compare different ring chains against others. If you compare apples to apples, the 530 will have a longer wear cycle. | |
| | #59 | |
| | #60 |
![]() ![]() Joined: Sep 2005 From: Bremerton I Ride: 05 KTM 625smc, 03 Are See fiddy one, 05 DRZ470SM, 95 FZR1040, 69 Combat Commando Roadster, 73 Commando Interstate, 67 BSA B44, 71 BSA B50 | Tinsile strength is a function of hardness. As measured on a Tinious Olson machine. It measures ultimate strength and elongation as a eprcentage of sample cross sectional area. Wear is somewhat related to hardness but is really more a function of a materials toughness. |
