Old 02-22-2010, 09:12 AM   #1
PNW Administrator
beansbaxter's Avatar
I Ride: ZX-10R
Question inverted front forks?
I know inverted forks look cooler, but what other pro's and con's are there?
Not every motorcycle has inverted front forks, so what are the advantages?
Old 02-22-2010, 09:17 AM   #2
I Ride: 05 r6 ravin
dont know but would like to
Old 02-22-2010, 09:19 AM   #3
Jabomb9's Avatar
I Ride: slow!
Less unsprung weight = more responsive/better handling.
Old 02-22-2010, 09:19 AM   #4
I Ride: 07 YZ450F, 74 XL350
the way I understand it, the one of the benefits is less mass to move up and down...
also, it's the new hawtness, so you have to have them or you're a noob.
Old 02-22-2010, 09:21 AM   #5
midvalleysuperbiker's Avatar
I Ride: Aprilia Tuono, Ducati GT1000, Moto Guzzi Centauro, Bimota DB4, Yamaha FJR1300
I seem to have more seal problems with inverted forks.
Not horrible but it seems more often than with "standard" forks.
Maybe a marginal seal will start leaking sooner.
Easier to get rock chips on the tubes.
Old 02-22-2010, 09:28 AM   #6
Red Label Moto's Avatar
I Ride: All kinds
All forks (conventional or inverted) have larger diameter outer tubes, and smaller diameter sliding tubes. I'm fairly certain the main benefit of installing them on a motorcycle with the sliding tubes at the bottom is it allows the larger diameter tubes to be held in place by the triple clamps. By clamping the larger or "stronger" tubes the entire assembly is stiffer with less deflection over bumps, turning, braking, landing wheelies, etc.
What do I win?
Old 02-22-2010, 09:53 AM   #7
justin86's Avatar
I Ride: 06 R1/ 06 CRF450R and single moms!
less unsprung weight and the forks flex less at the triple clamps
Old 02-22-2010, 09:53 AM   #8
Monster4570's Avatar
From: ...stumblin' through the parking lot of an invisible 7-11...
I Ride: for my daily recommended allowance of vitamin B12
I'm pretty sure the primary advantage is, as stated above, less unsprung weight. This allows the fork to respond better to irregularities in the road surface keeping the tire on the ground better.
Old 02-22-2010, 09:58 AM   #9
curveaddict's Avatar
I Ride: ..., 1987 Yamaha FZR1000, ...
What do I win?
Ding! Ding! Ding!...You win an all expense paid trip to your kitchen! Grab yourself a beer!
That is the main advantage of inverted forks.
Old 02-22-2010, 10:41 AM   #10
Fast Eddie 919's Avatar
I Ride: Shotgun
Since I'm in no danger of wading them up in a stoppie or of running down the Track Lizards anytime soon.....I'm not too worried about trying to look the part either.
Old 02-22-2010, 11:45 AM   #11
Wrench's Avatar
I Ride: Pitster Motard
The main benefit of inverted forks?
The fork bushings are dramatically further apart inside inverted forks making them much more stable. What alot of riders feel as "less flex" may be slightly less actual tube flex, but more importantly, less slop between the upper tube position and lower tube position. Bushings also last longer.
At least, that is how it was explained to me when I attended a Race Tech / GMD Computrac seminar.
Old 02-22-2010, 05:31 PM   #12
Hmmm... I kinda like it when a thread turns into a learning experience.
Old 02-22-2010, 06:46 PM   #13
Inverting your forks make them stiffer, like this site makes me.
Old 02-22-2010, 06:48 PM   #14
BigDave's Avatar
I Ride: Slow and Steady...
Well put!
Old 02-22-2010, 06:50 PM   #15
DesmoDave's Avatar
I Ride: white & nerdy
This is PNWR record, 12 posts before we headed off into the weeds....
All the reasons I've heard have been noted, less flex, less weight, plus, if the racers use them, they MUST be good!
Flexy forks on a flexy bike with 30 HP can be very exciting!
Old 02-22-2010, 07:01 PM   #16
(Oregon) City
CopperSV1's Avatar
I Ride: 12 Wee-strom Adventure
Thanks for in the info...Good question.
Way to go Beans....There you go making this forum useful and informative! LOL
Old 02-22-2010, 07:06 PM   #17
h_travis's Avatar
I Ride: 04RC51-05600RR-05DRZ400sm
What do I win?
thats exactly correct
Old 02-22-2010, 11:49 PM   #18
PNW Administrator
I Ride: ZX-10R
Originally Posted by monster4570 View Post
hmmm... I kinda like it when a thread turns into a learning experience.
Tags
forks, front, inverted, suspension
