| | #43 |
![]() ![]() Joined: May 2011 From: LaCenter, WA I Ride: 2003 Copper SV1K | Only thing I can figure out is I found an exhaust leak the other day on the rear cylinder pipe where it connects to the manifold down below. I need a new gasket for it. Other than that, it seems to be a common trait. Runs fine, plugs are good color, so.....not gonna worry about it anymore. |
| | #46 |
| Endorsed Joined: Apr 2008 From: Everett, Wa I Ride: 2003 SV650S | Nice SV. If you would like some front end suspension info, I replaced my springs with race tech springs and added race tech emulators to it. I haven't done anything with the rear suspension yet but i am sure you can find some info on what to get if you do replace it. svrider.com is also another great sv site to look into. |
| | #47 | |
| Railer Joined: Feb 2005 From: West Richland I Ride: Pitster Motard | ![]()
I believe the 650 forks are a non-cartridge type, and the 1000 are a cartridge type. The RT Emulators are actually "cartridge emulators" to make them work similar to cartridge forks, which his already are. My guess is that his 1000 forks only need a good shim stack and maybe spring rate correction to work well. | |
| | #48 | |
