| Race Qualifier | Figuring out the lever length you want So I've spent the last few years, just riding. But now I want to slowly start changing the suspension and controls to fit me better. When it comes to levers, I've never ridden with anything less then the stock full sized levers. I know many people use aftermarket shortie levers. I'm not confident I'll like the shortie levers; maybe it's something you have to get use to? How did you decided to go to shortie levers? Was it a great choice or did you regret it? Any help in helping me decide for myself when that time comes is greatly appreciated. |
| Licensed Joined: Feb 2009 From: Bellingham, WA I Ride: 2007 CBR1000RR, 2006 WR450F | I've heard of people wrapping tape around their stock lever where the shortie lever would end, wrap multiple times to make a "ball end". If they never feel their ring finger touch the ball (using 3 or 4 fingers on the bar), they probably don't need the extra lever length. I use stock levers, but if I bought aftermarket I'd go shortie on brake, stock length on clutch because I feel myself using my middle and ring finger on the clutch sometimes. |
| Training Wheels Joined: May 2012 From: So. OR I Ride: 2006 CBR 1000rr / 2006 CRF450r / LTR450 | Yes you want shorty levers. Use two fingers. That's what both the bikes and the ladies like. Buy adjustable ones to get the perfect pull for blipping and control. You know you want them! [IMG] [/IMG] |
| Moto2 Contender Joined: Sep 2008 From: where they don't have lawns. I Ride: Red bike, Brown truck, various collections of junk held together poorly. | I can't see using adjustable levers. Short ones work fine for me. for the Chinese Pazzo knockoffs.Mine are Pazzos that came with the bike but the knockoffs I've seen are pretty much indistinguishable. |
| Novice Racer | at first I had stock then I thought it would look cool with the shorty ASV C5 levers the shorter lever are ok for the street , but...................... then I started doing a lot of track days and felt less confident with the short levers , a couple of times I meant to hook 2 fingers on the brake lever and barely hooked one so I went with the full size levers once again so yeah I kinda of regret buying the shorties , but I was able to sell them at a good price |
| Chicken Strips Joined: Jul 2009 From: the Hill Country I Ride: for escapism | I liked the shorty's aesthetically...but on the track, my FU finger kept missing the sweet spot on the lever, no matter how I adjusted it. Switched back to long levers, and quite happy. But, it's all personal preference... |
| Moto2 Champion Joined: Mar 2006 From: spokane, wa I Ride: 2008 SXV4.5 + 1985 RZ350 + 2010 YZ250F + | I didn't think they made two finger clutch levers? Even the so-called Shorties are longer than what I ould purchase. I was looking for identical length brake and clutch, but have never found them. |
| Superbiker Joined: Aug 2009 From: Chicagoland I Ride: 2010 RC8R; 2009 ZX6R; Percheron/Paint (equine variety) | Stock are fine for me. I only use two fingers on the brake, but full hand on the clutch - having stock full length works well for both and they aren't expensive to replace if I wreck. Yeah, see if you can borrow a bike with shorties to see how they feel. |
| Peg Dragger Joined: Oct 2010 From: Renton WA I Ride: to StarDuc's.... | I'm running the stock full length levers on the Duc, and I only use my index finger for braking. But I use all 4 on the clutch due to the pull effort needed. I could go with an asymmetrical setup, with a long clutch and a shorty brake. But the stock levers work just fine, so I'd rather spend that money on gear/tires/track days.... |
| Superbiker Joined: Oct 2010 From: Everett, WA I Ride: 05 GSX-R750, 08 675, 72 XL250 | To get the optimum balance between reduced weight/less aero dynamic drag and comfort in using your controls the best thing to do is cut your stock levers down 5mm at a time until you have it just so. It is not unusual to end up with asymmetric results. If you miss the "ball" on the end JB weld can be added. This method also allows for that custom look too. |
| | #17 | |
| Novice Racer ![]() Joined: Mar 2006 From: Marysville, Wa I Ride: my race bike, poorly. | ![]()
FYI. If some one shows up at tech with any kind of non stock or "glued" on ball end. The bike may fail. Just sayin' | |
| Superbiker Joined: Oct 2010 From: Everett, WA I Ride: 05 GSX-R750, 08 675, 72 XL250 | ![]() PM sent. Last edited by Andy Capp; 05-28-2012 at 08:12 PM.. |
| Moto2 Champion Joined: Mar 2006 From: spokane, wa I Ride: 2008 SXV4.5 + 1985 RZ350 + 2010 YZ250F + | The worst thing about stock levers is that you tend to grab them in a different location every time, getting different leverage also each time. The clutch isn't as important, since its mostly used for starting and stopping, not so much for shifting up or down, but the brake is kind of important for consistency. |
