| Pit Crew Joined: Mar 2011 From: WA I Ride: clean | ![]() Keep in mind, there's always someone (like the above poster) who says "no that's wrong" or "that's bad advice" no matter what way you choose to break in your bike. Honestly, I don't care what way you break in your bike, I only know that the way I will always break in my bikes is detailed in http://www.mototuneusa.com/break_in_secrets.htm |
| Streetfighter Joined: Feb 2010 From: Seattle, Wa I Ride: An 06 R6 with OPRT | What about if you break it in all slow and nice, and your rings fail to seat. You think that's any different? The Factory warranty will still apply. If it were that big a deal, they'd break it in before it ever got to the buyer |
| Licensed Joined: Jul 2010 From: The dark side I Ride: Wrapped in leather, poly carbonate, kevlar and carbon fiber, from head to toe. | http://www.mototuneusa.com/break_in_secrets.htm I've had great results with this as well. But it's your bike. |
| Mr. Pickles ![]() Joined: May 2005 From: Spokane I Ride: 2012 Ultra Blue Metallic Wing w Rockin' Tunes... | Old school method: Follow the manuals recommended break-in procedure, if you don't want to VOID the warranty. If you don't have the patience for that; you shouldn't be riding to begin with... |
| Forum Cripple | A lot of this advice doesn't make sense. Don't stay at one RPM for too long? You're not going to over-wear the particular spot on your tachometer. As long as the motor's running, everything in the motor is moving. You're not going to groove anything differently by running it at 5,000 RPM for 10 minutes than alternating between 2,000 RPM for 5 minutes and 8,000 RPM for 5 minutes, doing a minute at each. Either way it'll have completed 50,000 revolutions in 10 minutes. The website linked advocates its break-in method because it seats the rings into the cylinder bores better than low-rpm, low-stress use. Every single race engine builder will tell you to use this method for a performance motor. They will ALSO tell you to warm the bike up for a solid 10 minutes and heat soak it for another 10 minutes before putting any load on it, and then to change the oil after at the 50-100 mile mark. That method does seat rings better and thus make better compression - but it causes a lot of microscopic metal flakes to get swept up by the oil. Those flakes are not friendly to bearing surfaces and the clutch. The manufacturer's method won't cause the rings to seat as perfectly, but it's also not as critical that the user warm the bike up perfectly or change the oil so immediately. 95% of vehicle owners won't do that.. so the mfgr recommends an easier break-in procedure. Simple. |
| | #26 | |
![]() ![]() Joined: Mar 2006 From: Seattle I Ride: 1099cc L-Twin in a sporty arrangment | ![]() Do you actually know anybody this has happened to or is this just a story? I have bought 4 bikes brand new, first 2 I broke in the factory way, last 2 the hard way. The first 2 crashed all the time, so I assume that factory break in procedure, combined with a lack of knowledge leads to crashing. Or maybe I just sucked at riding and was in way over my head.If you watch any videos of the bike factories every single manufacturer takes a completed bike, starts it up on a dyno, they run up through the gears, and then WOT. It hits some performance spec they have set, then they box it up and ship it to you. Once you get it it's already essentially broken in, but the procedure they have you follow is designed to minimize their liability. The procedure this race shop has come up with is designed to maximize performance. Of course race shops look at engines as consumables, most racers spend more on tires during the course of a season than they do on engines. Numerous people on this board will attest to the fact that either way works. So pick whichever you feel most comfortable with. ![]() |
| | #29 |
| Licensed Joined: Nov 2011 From: Seattle I Ride: 2011 CBR250R | I broke in a 2002 ZX9 by the book and it never ran that hard. And than I did the run it like you stole it ( well almost) on my new 250R and it ran a lot better. I will choose the motoman way next new bike. |
| | #30 | |
| Chicken Strips Joined: Apr 2012 From: Olympia, WA | ![]()
You go buy an $18,000 Panigale and ignore the tech when he says vary the RPMs during break in. Your bike/your money so who cares right? He's asking for advice/opinions on break in; I had the same bike brand new, broke it in myself. Did what the book suggested and what the dealership told me, seemed to work fine. ![]() Last edited by canyon63; 06-19-2012 at 09:26 AM.. | |
| | #31 | |
| Pit Crew Joined: Jul 2009 From: past the Y I Ride: upstream. | CajunMike, I suggest you read the mototune article all the way through. To me, he makes a pretty good argument for his break-in method. Don't miss this part: ![]()
| | #32 |
| Training Wheels Joined: Oct 2011 From: Salem, Or I Ride: '97 Kaw vn1500 Custom HP | The Biggest thing is to make first oil change early ! And don't omit cleaning the screen if it has one. I always did the first change between 300 & 600 miles. Altho, I had a Yamaha that required first change at 150 miles because of a plugged up oil filter with new clutch debree ! The plates break in and the loose fibers plug up the filter & some go to screen. You don't want to run on the oil by pass at all ! That constitutes unfiltered oil ! |
| | #33 |
| Track School Dazed ![]() Joined: Oct 2005 From: CENTRAL I Ride: When I can | ![]() What in general the FACTORY say's is to limit the RPM's for so many miles. Not leaving the engine at a set RPM for a period of time. Then increase the RPM's gradually. It also say's to very the engine RPM but, keep it off the higher RPM's until the engine has miles on it. Most Factorys have a recommened 600 mile service. The oil is changed. (It's full of metal). Caused by the uneven internal engine surfaces mating together. Some 600 mile check's also include a valve inspection. This is to check that one or more of the valves are not too tight. Or, too loose. The FACTORY develops 'Break-in' procedures for a reason. They designed, developed, engineered and, slept with the engine. Developing the best product possiable. Not following their recommended procedures is setting your investment up for failure. Maybe not right away. But down the road. After its out of it's warranty. That MORE engines don't have trouble caused by 'Motomans' procedure is, a testimony to the engineering talent of the Factory designers and engineers. |
| | #34 |
![]() ![]() Joined: May 2011 From: LaCenter, WA I Ride: 2003 Copper SV1K | Yes, because the factory's are ALWAYS right and can never be improved on. At all. I guess this is the end of the aftermarket development and such since the factory's do everything so well. |
| | #35 |
| Newbie Joined: May 2012 From: oak harbor, WA I Ride: 2012 Ninja250R | I appreciate all the advice yall!!! im at 350 miles it sounds like a good idea to change the oil this weekend. The main thing that concerns me is the high RPMs at 60-65mph...i curious to see what this bike will do at the track after 800-1000miles??? as soon as i hit that mark, it will be at th track! I just hope I can hold out that long...I get a free track day with the purchase of my bike! i would like to be able to go over 80mph so i dont get run over....ya know ![]() |
| | #36 |
| Ninja Master | Well first off to break-in your new bike make sure to follow everyone's advice on this forum. I generally crack my case open and add about one liter of extra virgin olive oil, let it warm up then change the oil and the filter. Not only does the bike run better, but bitches love falafal. Or just crack open the owners manual. |
| | #37 |
| Newbie Joined: May 2012 From: oak harbor, WA I Ride: 2012 Ninja250R | I did look at my owners manual first, before i started this thread. but im sure just like most of you who responded i am extremely impatient and want to ride this bitch like i stole it! so i just wanted some imput from anyone who has had similar situations, and motoman seems to have a really good point! im gonna change my oil, look for any metal and ride the shit out of my new toy! Track Day Aug 10th in shelton, cant wait! |
| | #38 | |
| Superbiker | ![]()
| | #39 | |
