| Endorsed Joined: Mar 2010 From: Kent, WA I Ride: The Kung Fu Grip! | October SCREAMIN Deals - $39 Oil Change, $199 Minor Service, $399 Major Service Don't let fall scare you away from maintenance! Three levels of SCREAMIN deals: $39 Oil Change $199 Minor Service $399 Major Service *(Parts & tax not included) Call us to schedule your appointment today 253-397-4474 or info@kfgracing.com ![]() |
| Post Whore (In Training) Joined: Jul 2006 From: Portland OR I Ride: wee-strom, | OK thanks for being a site sponsor but before I can evaluate the offer, what is included in each of the three levels of service? (I can do my own oil change, w filter for $8 in parts and 10 minutes of my time $30,) |
| Joined: Oct 2005 From: Renton I Ride: At the track. | Grats! |
| Endorsed Joined: Mar 2010 From: Kent, WA I Ride: The Kung Fu Grip! | Minor Service: 2.0 - 3.0 (Depending on Bike) Engine & Carburetors: • An oil change • New oil filter • New air filter (or cleaned) • New NGK spark plugs • Replace coolant Chassis & Brakes: • Battery checked - terminals; clean and tight, electrolyte level, held down securely. Vent Tube - not kinked, routed properly, not plugged. • Brake calipers removed & cleaned • Brake pistons degreased • Chain adjustment, cleaned and lubrication • Frame - cracks at gussets, accessory mounts, look for paint lifting • General lubrication and inspection • Hydraulic fluid system flushed • Levers & pivots cleaned and lubricated • Lights checked - headlight, taillight, brake light & turn signals • Steering - Head Bearings, no decent or tight spots through full travel, raise front wheel, check for play by pulling/pushing forks. • Suspension - Front Forks, smooth travel, equal air pressure/damping, anti-dive settings. Rear Shock - smooth travel, equal pre-load/air pressure/damping settings, linkage moves freely and is lubricated • Swingarm Bushings/Bearings, raise rear wheel, check for play by pushing/pulling swingarm • Throttle & clutch adjustment • Tire pressures checked and adjusted, check tread depth, wear, weathering, evenly seated, bulges, embedded objects Major Service: 4.0 - 8.0 (Depending on Bike) Everything listed above + • A thorough check of your valve clearances (adjusted if needed) |
![]() ![]() Joined: Mar 2006 From: Seattle I Ride: 1099cc L-Twin in a sporty arrangment | ![]() ![]() |
| Licensed Joined: Feb 2012 From: Bellevue, WA I Ride: GSXR600 // KTM 450 SMR | If anyone is trailering a bike from north (I'm in bellevue) to KFG for service, if you have space in your trailer or truck and can take my bike there for a servicing, I would be very grateful! |
| Superbiker Joined: Jan 2009 From: Wenatchee, WA I Ride: a slow bike fast | U work on Buells? I need my valves adjusted ... shit. I need my chain serviced.... shit... I need... to figure out what the fucking high pitch whining coming from my bike is.. really tho |
| Endorsed Joined: Mar 2010 From: Kent, WA I Ride: The Kung Fu Grip! | Some, give us a call or email to let us know what Buell you have. |
| Shredder Joined: Jan 2006 From: Yakima I Ride: 2011 Ducati 848 EVO 06 r6 (gone) | Screamin deal I say.. wish I were closer I need a major done one my duc...think their picky on it being done by a ...duc cert tech tho :(...399 instead of 1200 sounds mighty fine to me |
