Old 10-15-2012, 07:46 AM   #21
blakegaston's Avatar
I Ride: GSXR600 // KTM 450 SMR
Originally Posted by Pvster View Post
Yup, practice. If you're having to deal with 0-1% throttle openings in the corners, you're doing it wrong I hate to say. You do NOT want to enter a corner off throttle. At least maintain steady throttle to hold a consistent speed, or apply light throttle. Also try bumping up another gear before entering a corner. It sounds like you need to work on better throttle management more than body positioning right now.
When trail braking into a corner? Like T11 at the ridge? Sharp decreasing radius corners?
Old 10-15-2012, 07:48 AM   #22
Go see Nels! He can smooth out your throttle response....get a Power Commander or ask him about ECUnleashed.
Old 10-15-2012, 08:49 AM   #23
S1KRR's Avatar
I Ride: BMW S1000RR, Suzuki SV650
Another plug for Nels at 2WheelDynoWorks, he installed a PC5 and did a custom tune on my S1000RR with the stock exhaust and did a great job smoothing out the power delivery and softening the on/off throttle feel at lower to mid RPMs.
Old 10-15-2012, 08:52 AM   #24
Racer Extraordinaire
theJrod's Avatar
I Ride: w/ Optimum Performance Rider Training
While you DO enter a corner with the throttle closed, you should be back on the gas (maintenance throttle) before the apex of the corner. Even in T11 at TRMP.
Old 10-15-2012, 08:53 AM   #25
nemisis714's Avatar
I Ride: 2011 Kawi Versys and a 1999 Yamaha WR400F
Originally Posted by Gotama View Post
aye
Aye
Old 10-15-2012, 09:41 AM   #26
I Ride: ZX14
There are a couple of things you could do:
1. Select a higher gear which will reduce your RPMs and reduce the power available, which is the easiest solution. This will smooth the throttle response significantly.
2. Get and install a Revolver Throttle Kit that adjusts the sensitivity of the throttle.
See http://campaign.r20.constantcontact....ZclaYc6X7EI07t
Old 10-15-2012, 09:49 AM   #27
Texasl's Avatar
I Ride: 2007 Moto Guzzi Norge, 1988 H-D Electra-Glide
Originally Posted by MarvTravis View Post
There are a couple of things you could do.
1.Stay in a higher gear so there's less power available
Government mathemetician?
Old 10-15-2012, 11:49 AM   #28
paradox206's Avatar
I Ride: DRZ400sm "The Honey Badger" & VFR800 "Toasty"
Thanks for asking this! I've been wondering the same thing about my VFR. I knew most of it was due to my lack of skills but it sounds like getting a tune couldn't hurt either. Time to do more research!
Old 10-15-2012, 11:53 AM   #29
I Ride: 2008 BMW R 1200 GS
The only way that you'll ever eliminate that 0%-1% throttle slap is with the judicious use of a clutch, or with an automatic transmission. Practice will make it more tolerable, but you'll never eliminate it.
Old 10-15-2012, 12:36 PM   #30
I didn't experience it though with the ninja 250... or at least, it was considerably less...
Going on / off throttle in like... 5th gear is much easier and more comfortable for the initial crack of throttle. However, once its cracked open, then I have too little power to be usable.
Old 10-15-2012, 12:39 PM   #31
I typically only have this issue when my chain is too slack....but I do also have a PowerCommander and a Nels tune.
Old 10-15-2012, 09:32 PM   #32
I couldn't find on the website what a Nels tune goes for. Can anyone give me a rough ballpark?
Also, is it pointless to get a Nels tune before getting an exhaust / PC / etc? Would I benefit more investing in those mods first?
Thanks again!
Old 10-15-2012, 10:31 PM   #33
Nels runs ~$150 for a full tune.
He can FlashTune your ECU, so you don't need a Power Commander, but it costs more.
You can make all the mod.s if you want, but Nels can still greatly improve a stock bike.
Old 10-15-2012, 10:48 PM   #34
Gotama's Avatar
I Ride: for me
here is another satisfied customer
pubic Awesomeness
Old 10-16-2012, 01:57 AM   #35
Darvax's Avatar
I Ride: GSX-R600 20th Anniversary
pubic Awesomeness
Lol on two counts there.
Old 10-16-2012, 05:57 AM   #36
tornaido's Avatar
I Ride: Like a Boss
Go jump on a 650 twin, or any big twin. Commute around on it. Get back on your modern inline 4. Smoothness Problem solved.
Old 10-16-2012, 06:51 AM   #37
Wyckedan's Avatar
I Ride: An 06 R6 with OPRT
Thanks again!
Just call him. Ask questions, get answers from him, buy what he says will help, and your bike will be happier for it.
Old 10-16-2012, 07:18 AM   #38
Originally Posted by Wyckedan View Post
Just call him. Ask questions, get answers from him...
And be ready to be on the phone for 30+ minutes: this guy is just full of information that he likes to share!
Old 10-16-2012, 08:16 AM   #39
Thanks for all the advice. After my KFG service, I will give Nels a call!
Old 10-16-2012, 12:16 PM   #40
I ride an SV1000....I can confirm this. Nels has yet to get his hands on it...still twitchy.
