| Endorsed Joined: Mar 2009 From: Portland I Ride: Y2K Bandit 600 to escape the voices | To LED or Not To LED? I'm thinking to change to a low profile set of LED signals because I've already broken 2 signals and the OEM signals are four times as expensive as LEDs. Seems like a simple project but thought I'd get some advice before taking the LED dive.Concerns I have are: 1. the quality of aftermarket LED products (they all seem cheap, non durable) 2. special electrical requirements (flash control/resistors/connectors) 3. does this raise/lower the value of a bike? Any advice is appreciated! |
| Track School Dazed ![]() Joined: Oct 2005 From: CENTRAL I Ride: When I can | Lowers bike value. Why? Because they are NOT LEGAL. They are 'For show Use Only'. They dont meet D.O.T. standards. Cop's look for reason's to pull you over. If your in an accident, you have modified the safety equipment on the bike. You could be held responsable for the accident. Yes, most applications require an in-line resistor to slow the flash of the signal to a useable speed. Stock works best. Check ebay or a forum that specializes in your bike for some clean used signals. You dont add value to a bike by adding mod's. Last edited by james1300; 10-06-2009 at 04:33 PM.. |
| Pit Crew Joined: Jan 2008 From: Salem, OR I Ride: My pony. Saddle's waiting. Come & Jump on it.... | Do not anticipate any return on mods performed to the bike. If you like em thats what counts. As for LED's. Do your homework on the front ones. Many aftermarket replacements DO NOT allow for a running light. Your factory ones do. The few that I know of that support the running light function can be expensive. As for the butt end of the bike. Are going to look into an integrated Brake/signal or keep them seperate? There are many options. Most LED's will require a resistor. I prefer the LED's over factory. Much brighter! Have fun with it! PS. Dont roll in Salem with them....as stated below. |
| WMRRA Qualifier Joined: Oct 2008 From: Kent, WA I Ride: 08 cbr600rr graffiti | hello I've got a set of protons front led turn signals on my bike set to strobe 1. they are brighter 2. setting them to strobe gets peoples attention 3. been pulled over before for having improper lights but it was only because my rear turn signal led lights were too small , and i asked the officer if the fronts were ok he said they were fine , just for me to get bigger rear turn signal lights the other thing about proton leds is that you dont have to get a new flasher relay they have a resistor built in Last edited by Gotama; 10-06-2009 at 05:03 PM.. |
| | #5 | |
| Zone Head Joined: Mar 2007 From: Seattle, WA Blog Entries: 1 I Ride: BMW K1200GT--- R.I.P., Triumph Scrambler, Ducati 1098S | If a cop EVER tells you the turn signals are too small, refer him to this RCW: http://apps.leg.wa.gov/RCW/default.aspx?cite=46.37.200 Correct me if I'm wrong, but there are NO size requirements for turn signals, only that they be visible at the specified distance, and they be spaced correctly. ![]()
| WMRRA Qualifier Joined: Oct 2008 From: Kent, WA I Ride: 08 cbr600rr graffiti | firedave he pulls out this pamphlet that states the rcw code the distance is something like 200 feet ok i was wrong its 500 feet and that it needs to be the size of something like business card Last edited by Gotama; 10-06-2009 at 05:15 PM.. |
| Zone Head Joined: Mar 2007 From: Seattle, WA Blog Entries: 1 I Ride: BMW K1200GT--- R.I.P., Triumph Scrambler, Ducati 1098S | I'm not disputing what the cop told you . . . but it appears that any RCW dictating the size of the turn-signal is no longer on the books. It wouldn't surprise me at all if the cop is mis-informed or has out-of-date RCW literature. |
| Zone Head Joined: May 2009 From: Roofies - putting the sensual back into consensual I Ride: like an asshole | PS I LOVE HYPER FLASH ![]() |
| WMRRA Qualifier Joined: Oct 2008 From: Kent, WA I Ride: 08 cbr600rr graffiti | that could be true , havent been stopped for that for over a year or so |
| | #13 | |
| Track School Dazed ![]() Joined: Oct 2005 From: CENTRAL I Ride: When I can | ![]()
"Honest officer, I didnt see him". Last edited by james1300; 10-06-2009 at 07:17 PM.. | |
| Training Wheels Joined: May 2009 From: Brem I Ride: 1 w/ givi balancers | Another advantage of LED's... they're not like christmas tree lights. A couple of the bulbs can burn-out and they're still good. Can't say that about stock blinkers. LED ![]() |
| | #15 | |
| Streetfighter Joined: Sep 2008 From: Kirkland via Dallas I Ride: VTR1000 SuperChicken | ![]()
| | #16 | |
| Zone Head Joined: Mar 2007 From: Seattle, WA Blog Entries: 1 I Ride: BMW K1200GT--- R.I.P., Triumph Scrambler, Ducati 1098S | Again, not to disagree with what the WSP told you . . . . but a current search of the current RCWs reveals NO such dimensional requirements for motor vehicle turns signals. BTW, does a current stock Gixxer, Ducati, Honda have 3.5 square inch turn signals? 3.5 square inches equals 2 x 1.75 or 2.33 x 1.5 The stock signals on the newest BMWs are about 2.5 inches long, about 1.5 inches high, and mostly triangular in shape, therefore , by my estimation of the photos, not 3.5 square inches. ![]()
| Training Wheels Joined: May 2009 From: Brem I Ride: 1 w/ givi balancers | ![]() Sometimes cagers are numero uno.A good designed LED does not have to be smaller than said 3.5 sq ". We're not Rossi can't tell if that K6pdq Der6SM is doing 181 or 182 because of stock windbreakers ...eh blinkers. I always keep in mind I am riding a smaller, often less visible vehicle. Therefore, I overcompensate with bright flashing lights and a loud muffla-horn ![]() |
| | #18 | |
Bike RCW's are different than auto. Wouldn't that 2.5 in and 1.5 in equal 3.75 square inches? | |
| Track School Dazed ![]() Joined: Oct 2005 From: CENTRAL I Ride: When I can | naaa, I just change that $1.35 cent bulb and it looks good. Not like ya got shit burnt out and missing. |
| Streetfighter Joined: Sep 2008 From: Kirkland via Dallas I Ride: VTR1000 SuperChicken | ![]() You're about to be pulled over... Area of a triangle is .... Area= Base x Height/2 Rectangle... Area=Length x Width Last edited by Devil_Doc; 10-06-2009 at 08:51 PM.. |
| Endorsed Joined: Jun 2009 From: Portland I Ride: 1997 Suzuki Katana 600 (GSX600F) | I like mine but you'll have to pick up some Non-inductive Resistors from RadioShack to make them flash the right speed again. Some people like them flashing faster but it wears your blinker-relay-deal out faster |
| Training Wheels Joined: Aug 2009 From: Vancouver, WA I Ride: 03 Triumph Sprint ST 955 | |
