| MotoGP Champion ![]() Joined: Jul 2006 From: Pullman, WA I Ride: '73 CB350F, '86 VFR750F, '00 Aprilia RS250, '04 Aprilia RSV1000 R Factory, '07 Vstar 1100 Classic | Storm before tha calm... A SLOW-MOVING FRONT WILL TRACK INTO THE AREA THIS EVENING AND PERSIST THROUGH EARLY WEDNESDAY MORNING. THIS SYSTEM WILL INITIALLY PRODUCE A MIX OF RAIN AND SNOW EARLY...BUT WILL TURN TO ALL SNOW OVERNIGHT ABOVE 2000 FEET. THE HEAVIEST AMOUNTS OF SNOW WILL LIKELY ACCUMULATE OVER THE HIGHER TERRAIN OF THE CAMAS PRAIRIE AND PALOUSE IMPACTING THE TOWNS OF WINCHESTER...POTLATCH...GIFFORD ...AND MOSCOW. 1 TO 3 INCHES OF SNOW IS GENERALLY EXPECTED IN THIS AREA... HOWEVER LOCALIZED AMOUNTS UP TO 4 TO 5 INCHES ARE POSSIBLE. A SNOW ADVISORY MEANS THAT PERIODS OF SNOW WILL CAUSE PRIMARILY TRAVEL DIFFICULTIES. BE PREPARED FOR SNOW COVERED ROADS AND LIMITED VISIBILITIES...AND USE CAUTION WHILE DRIVING. THIS ADVISORY INCLUDES THE FOLLOWING LOCATIONS...THE NATIONAL WEATHER SERVICE IN SPOKANE HAS ISSUED A SNOW ADVISORY ABOVE 2000 FEET...WHICH IS IN EFFECT FROM 8 PM THIS EVENING TO 5 AM PDT WEDNESDAY. A SLOW-MOVING FRONT WILL TRACK INTO THE AREA THIS EVENING AND PERSIST THROUGH EARLY WEDNESDAY MORNING. THIS SYSTEM WILL INITIALLY PRODUCE A MIX OF RAIN AND SNOW EARLY...BUT WILL TURN TO ALL SNOW OVERNIGHT ABOVE 2000 FEET. THE HEAVIEST AMOUNTS OF SNOW WILL LIKELY ACCUMULATE OVER THE HIGHER TERRAIN OF THE CAMAS PRAIRIE AND PALOUSE IMPACTING THE TOWNS OF WINCHESTER...POTLATCH...GIFFORD ...AND MOSCOW. 1 TO 3 INCHES OF SNOW IS GENERALLY EXPECTED IN THIS AREA... HOWEVER LOCALIZED AMOUNTS UP TO 4 TO 5 INCHES ARE POSSIBLE. A SNOW ADVISORY MEANS THAT PERIODS OF SNOW WILL CAUSE PRIMARILY TRAVEL DIFFICULTIES. BE PREPARED FOR SNOW COVERED ROADS AND LIMITED VISIBILITIES...AND USE CAUTION WHILE DRIVING. THIS ADVISORY INCLUDES THE FOLLOWING LOCATIONS...MOSCOW... PLUMMER...POTLATCH... GENESEE... PULLMAN...COLFAX...ROSALIA... OAKESDALE...POMEROY... ALPOWA SUMMIT. Phuckin-A. That is all... |
| Zone Head Joined: Jan 2006 From: Pullman, WA I Ride: '06 1200C, '71 CB350 | Crap...more of it. I rode to Tri-Cities yesterday and had to ride back this morning. I was riding in front of that storm that hit around 11:00 the whole way. I actually had a legitimate reason for speeding the entire way. I wasn't back in P-Town for more than 15 minutes when the hail started. BTW, the road from 12 to Dusty (Central Ferry) is fairly fun with the proper amounts of speed applied. ![]() |
| Speakerphone Bandit Joined: Apr 2006 From: clarkston,washington I Ride: hayabusa | wtf,is winter ever gonna end? |
| Zone Head Joined: Jan 2006 From: Pullman, WA I Ride: '06 1200C, '71 CB350 | |
| Speakerphone Bandit Joined: Apr 2006 From: clarkston,washington I Ride: hayabusa | |
| MotoGP Champion ![]() Joined: Jul 2006 From: Pullman, WA I Ride: '73 CB350F, '86 VFR750F, '00 Aprilia RS250, '04 Aprilia RSV1000 R Factory, '07 Vstar 1100 Classic | Friday. Maybe Saturday. Relax. |
| MotoGP Champion Joined: Mar 2007 From: Lynnwood, WA I Ride: nekkid SV650 | it's nevar gunna end |
| Superbiker Joined: Aug 2005 From: Moscow I Ride: Only girls now... | Yeah!!! |
| MotoGP Champion ![]() Joined: Jul 2006 From: Pullman, WA I Ride: '73 CB350F, '86 VFR750F, '00 Aprilia RS250, '04 Aprilia RSV1000 R Factory, '07 Vstar 1100 Classic | Actually, check out Sunday...mind you, this is for Spokane...Moscow/Pullman is expecting one degree higher! ![]() ...and for the L/C valley: Friday: Sunny, with a high near 67. Saturday: Sunny, with a high near 78. Sunday: Mostly sunny, with a high near 79. |
| Superbiker Joined: Aug 2005 From: Moscow I Ride: Only girls now... | Yea, but its a trick... Its gonna get colder. |
| Newbie Joined: Apr 2007 From: Moscow ID I Ride: 2000 R6 | The cold is never going to go away. Thats it I'm moving to Pheonix ![]() |
| MotoGP Champion ![]() Joined: Jul 2006 From: Pullman, WA I Ride: '73 CB350F, '86 VFR750F, '00 Aprilia RS250, '04 Aprilia RSV1000 R Factory, '07 Vstar 1100 Classic | |
| MotoGP Contender ![]() Joined: Feb 2007 From: Pullman, WA I Ride: '00 Buell X1 Lightning, '91 kTm 300, Project - '67 CB77 | have fun with the smog I think next winter I'm gonna pick up a old XL125 or some old dualsport and rock that thing all winter, walking in this is stupid. ![]() ![]() Last edited by Chipper6; 04-09-2008 at 12:38 AM.. |
| MotoGP Champion Joined: Oct 2006 From: Bellingham but my heart will always be in pullman I Ride: 06 gixxer 1000 | i blame al gore. just like he invented the internet he invented global warming so its all his fault |
| MotoGP Champion ![]() Joined: Jul 2006 From: Pullman, WA I Ride: '73 CB350F, '86 VFR750F, '00 Aprilia RS250, '04 Aprilia RSV1000 R Factory, '07 Vstar 1100 Classic | I still wanna try the zip-ties around the tire and wheel working as sort of plastic "chains". I bet that would work, and with a proper design (wider ties, more durable and flexible plastic with "teeth" to bite into the ice and snow) I bet it would actually make it possible to ride with a small amount of snow on the ground...or at least get enough intermittent traction to high side... |
| MotoGP Contender ![]() Joined: Feb 2007 From: Pullman, WA I Ride: '00 Buell X1 Lightning, '91 kTm 300, Project - '67 CB77 | found a bicycle photo ![]() |
| Training Wheels Joined: Aug 2007 From: Moscow, ID I Ride: Human Powered | We just need to get some of these tires: So, since it can't be called a darky in this case, are they leaving "whities" on the corner exit? -Dan |
| MotoGP Contender ![]() Joined: Feb 2007 From: Pullman, WA I Ride: '00 Buell X1 Lightning, '91 kTm 300, Project - '67 CB77 | its coming down in pullman right now... bout a quarter inch so far |
| AnthonyADMulisha Admit or Deny!?!? Joined: Sep 2005 From: Newport beach, California I Ride: Raven R1 | Ahhhh. its 60 degrees out...mmm |
| MotoGP Champion Joined: Aug 2006 From: Spokane, WA I Ride: Cuz' it makes me smile! | I saw that storm warning last night. that sucks. |
| MotoGP Champion Joined: Mar 2007 From: Lynnwood, WA I Ride: nekkid SV650 | that zip tie idea could be either awesome or not awesome, but using screws as studs....not awesome.....I could see one from the front coming off and popping my rear |
| MotoGP Contender ![]() Joined: Feb 2007 From: Pullman, WA I Ride: '00 Buell X1 Lightning, '91 kTm 300, Project - '67 CB77 | naaaaaaaaa |
| MotoGP Champion ![]() Joined: Jul 2006 From: Pullman, WA I Ride: '73 CB350F, '86 VFR750F, '00 Aprilia RS250, '04 Aprilia RSV1000 R Factory, '07 Vstar 1100 Classic | Give it a try on your bike, Jeff... ...awwww...I forgot... Well, you still have the 10 speed...go for it! |
| WMRRA Qualifier Joined: Jul 2007 From: Idaho I Ride: a little Ninja 250 | poor bikeless jeff. ![]() this weekend is looking up. we are down to one rig now that my precious camaro has been sold off...which means steven has to take that and leaves me home ALL DAY with a 4 year old. i am the luckiest girl in the world. no really. |
| Superbiker Joined: Aug 2005 From: Moscow I Ride: Only girls now... | Phil caused this cold weather. The SOB said he wishes it never warms up... Last edited by Van; 04-10-2008 at 12:24 AM.. |
| MotoGP Champion Joined: Mar 2007 From: Lynnwood, WA I Ride: nekkid SV650 | ![]() ![]() ![]() stab him ![]() |
