| Two Wheel Art ![]() | "SPOILER" Sepang Pretty uneventful race. I did enjoy watching stoner turn in lap after perfect lap. The Duc did not have a speed advantage and Stoner dominated. Too bad about Hayden running off the track, it looked like he would have easily caught Rossi. |
| Pilot in Command | Speed advantage? no reason to push his luck, he had it in control. Notice how he settled in going faster and faster, set a new track record he did on the 17 lap. what can you say about Hayden.... Sad season, makes ya wonder whats really going on. |
| Mr. Lexus Joined: Aug 2005 From: Redmond,WA I Ride: Brasilian & Thai girls - motorcycles are boring :P | Turned into 200mph parade laps after lap #3 ![]() |
| WMRRA Qualifier Joined: Mar 2006 From: WA | |
| Forum Synopsizer Joined: Jul 2006 From: Renton, WA I Ride: 08 KLR650, 06 DRZ400SM, 04 CRF250X, 03 XR50 | TC isn't quite what you think. It does not allow the rider to simply pin the throttle on corner exit and have zero wheelspin. It could be set up that way, but racers need to be able to spin it up to some degree, and TC still allows that. It just won't spin as much as easily, and also helps a lot towards the end of races when tires are shagged. But if you watch closely, you can still see bikes spinning up, sliding and laying darkies out of corners with TC enabled. |
| | #7 | |
| Two Wheel Art ![]() | ![]()
Do the TC systems they are using allow more controlled spin or do they go about that by creating a really flat torque curve? | |
| Forum Synopsizer Joined: Jul 2006 From: Renton, WA I Ride: 08 KLR650, 06 DRZ400SM, 04 CRF250X, 03 XR50 | ![]() As far as actual traction control, different teams use different methods, retarding timing, adjusting FI ratios, etc to achieve a more controlled spin. You can actually hear the system working at times, it can sound similar to a bike hitting the rev limiter, but more subtle than that. |
| MotoGP Contender Joined: Jul 2005 From: moscow, id I Ride: Street-Z1000 Race-'88 Hurricane and '01 Gixxer 600 | I read something a while back that Ducati is using an ultra-fast servo to control the intake butterflies. They have a screamer motor that has numerous peaks and valleys in the power curve but huge top end power. The servo controlled butterflies are so fast that the ECU can change the intake and give the perception of a flat torque curve. A very innovative way to make amazing peak power numbers but still yield a ridable bike. |
