| Retired ![]() Joined: Jun 2006 From: Federal Way I Ride: KTM Supermoto, Plated YZ426F, Yamaha GT80 vintage enduro | Confirmed: Honda/Hayes cheated. |
| Retired ![]() Joined: Jun 2006 From: Federal Way I Ride: KTM Supermoto, Plated YZ426F, Yamaha GT80 vintage enduro | "By John Ulrich Part Three I think it’s pretty clear that the case made by Stealth Public Relations Operative Henny Ray Abrams (Cycle News, April 16 2008, page 8 AMA Pro Racing hasn’t released any details concerning the crankshaft installed in the Erion Honda CBR600RR Josh Hayes rode to a convincing victory at Daytona. The original press release issued by AMA Pro Racing stated that “The #1 Erion Racing Honda CBR600RR’s crankshaft was polished, surface treated and metal was removed from it. This is in violation of the 2008 AMA rulebook section 5.4…” At Daytona, an official told Roadracing World Associate Editor David Swarts that the surface of the crankshaft confiscated out of the Erion Honda was highly polished. And for some reason, that if a finger was used to swipe a line in the oil film coating that crankshaft, oil immediately flowed from adjacent parts to recoat and re-establish a continuous oil film. A blurry photo surfaced later, taken by fan Rick Hentz of an Erion Honda mechanic taking apart the engine from Hayes’ winning motorcycle, during the post-race tech inspection. The photo showed the crankshaft to be very shiny and polished; it did not have a stock crankshaft’s dull surface. Swarts called a race team source at American Honda and asked what had been done to the Hayes crankshaft. The source offered his opinion that the crankshaft had been surfaced-treated in a tumbler full of some sort of polishing medium, to reduce friction. It took a former racing crew member to put those clues together. Frank Angel’s day job involves developing powerful Internet search engines, and it often seems that there is nothing the guy can’t find on the web. Angel started with searching for websites that mentioned Erion Honda, which led him to proud team sponsor Crane Cams and then to Mikronite Automotive Technologies, Inc., which owns Crane Cams and is apparently a subsidiary of Mikronite Technologies Group, Inc. http://www.cranecams.com/?show=newsLetters&no=392 http://www.cranecams.com/index.php?s...niteProcessVid Mikronite Technologies Group, Inc. is named for Mikronite, which is, in the words of http://www.mikronite.com , “the brand name for a surface finishing process that strengthens, smoothes and polishes materials to enhance their performance. In other words, Mikronite improves sharpness, durability, lubricity and impact resistance while reducing friction, resistance and corrosion.” According to the company’s website, “The Mikronite process is based on the concept of applying lapping-like scratching under extremely high compression. Objects are placed in a fluidized medium containing an abrasive in a specially designed reverse centrifugal accelerating agitator…This produces molecular-level changes to the surface of an object without changing its size, shape or metallurgy…As a result, surface characteristics of an object are extremely optimized, making them harder, smoother, more polished…with higher lubricity and less friction…Mikronite is solely a mechanical action process. It is not a coating…” Under the heading of Total Product Improvement, the website features a small chart labeled “INCREASE” with a list that includes “Horsepower. Performance.” Another small chart labeled “DECREASE” lists “Friction. Vibration. Temperature.” Under “Effects,” subsection “Coating Synergy,” the website states that a side effect of the Mikronite process is to “alter the surface color to a freshly polished look.” Under subsection “Polishing,” the website states that the process “produces an incredible improvement in the appearance of products. With mirror finishes achieved on many products…a distinctive stand alone attention grabber, with the quality of the part represented in its jewelry like luster.” Under “Effects,” subsection “Lubricity,” the website states that the surface created through the Mikronite process “now has an evenly calculated pattern of channels that promotes capillary distribution, and temporary adhesion of a lubricant, and has a reduced coefficient of friction (COF). If lubrication from an outside liquid is possible then a barrier film may be desirable…” The company makes very specific claims regarding horsepower increases. One example involves dyno tests of treated-versus-untreated automotive ring-and-pinion gears as well as automotive valve train components: http://mikronite.com/dyno.asp Another example found on the Internet also involves Mikronite-treated-versus-untreated automotive ring-and-pinion gears: http://powertvonline.com/video_detail.php?mId=1831 A third Internet site includes an interesting interview with representatives of Crane Cams: http://videos.streetfire.net/video/S...iren_80927.htm While a Honda CBR600RR does not have ring-and-pinion gears, it obviously does have primary drive gears on the crankshaft and the clutch basket, along with two camshafts and assorted valve train parts. It is not a stretch to conclude that a crankshaft treated with the Mikronite process will make more power, if for no other reason than that the primary drive gear will produce less friction. The side benefit--establishing a barrier film--will also improve the crankshaft’s ability to shed oil as it spins in the cases, reducing parasitic drag. The improvement in “capillary distribution,” likely responsible for the crankshaft-in-question’s interesting ability to re-form a wiped-away oil film, may only apply in this case as an indicator that the Mikronite process was used. Kevin Erion disagrees. He told me, “The rules said I had to have a blue crankshaft, and I had a red crankshaft.” His view is apparently that the modifications to the crankshaft in Josh Hayes’ Daytona-winning CBR600RR were purely cosmetic, although the fact that the crankshaft is not usually visible does tend to discount the argument that the Erion team was going for the advertised “distinctive stand alone attention grabber” effect, “with the quality of the part represented in its jewelry like luster.” In any case, it is interesting that SPRO Abrams states, “the problem is with the AMA rulebook. Engineered to be vague…the rulebook specifies two kinds of penalties, which the AMA can impose at its discretion. Category I is for violations ‘that could potentially or effectively enhance the performance of a motorcycle used in competition.’ Category 2 is ‘All other equipment violations.’” So SPRO Abrams is against “vague” rules. Yet he is also incensed that AMA Pro Racing sought to clarify what he denounced as a “vague” rule by issuing a Competition Bulletin: “On Friday, April 4, nearly four weeks after the 200, the AMA issued a tech bulletin that states, ‘Oil galley plugs may be modified, removed or replaced.’” OK. The way SPRO Abrams writes it, a vague rule is bad. Realizing that a rule is vague, and attempting to clarify it, is also bad. A better solution would have been to disqualify two riders, one whose bike carried a crankshaft modified to increase horsepower, and the other whose bike carried a crankshaft that was not modified to increase horsepower. Of course, best of all would be reinstating the rider of the Honda with a crankshaft modified to increase horsepower. Because he’s on a Honda. And because SPRO Henny Ray Abrams is paid by Honda Racing. Got it. To be continued…" |
| Retired ![]() Joined: Jun 2006 From: Federal Way I Ride: KTM Supermoto, Plated YZ426F, Yamaha GT80 vintage enduro | Also with this, if anyone was curious......... Honda was officially denied their appeal, in the coming day. |
| MotoGP Contender Joined: Apr 2007 From: soap lake wa. I Ride: 00kaw12r, 97 tls1000, 96gsxr1260 turbo freakshow, kz1300gt, 94 cbr1000f, 88gsxr1100, 86gsxr750, 82gsx1100ez, 79kz1300, 75 ducati750gts, 72 gt550 cafe | Bling should be legal... but polishing cranks for performance..."they got caught" Polishing of cranks,is an age old hop up. Ya can't polish anything...w/out rearanging and changing the molecular surface configuration. I told 'em, "Ya better run that see thru clutch cover, w/ neon... or your gonna get busted"!!!!!!! Hats off to the Erion boys... Free and clean, Ripp'n |
| Telemark Rider ![]() Joined: Jan 2006 From: ^ Mmmmm, Boobies!!! I Ride: Huge piles of shite. | Yea, they got caught this time. Man up and deal with it, even Honduh can't get away with anything. |
| MotoGP Contender Joined: Oct 2005 From: Issaquah, WA I Ride: Race: 05 GSXR750 - Street: 06 GSXR750 | People need to STOP fucking attaching Hayes' name to this incident. It's complete bullshit to do it to him. ERION HONDA CAUGHT CHEATING! ERION HONDA APPEAL DENIED! Josh is a rider paid to race a bike. He has no idea about the internals of what is going on with his bike. He gets on the bike and does what he is paid to do. Try and win races. |
| | #7 | |
| Telemark Rider ![]() Joined: Jan 2006 From: ^ Mmmmm, Boobies!!! I Ride: Huge piles of shite. | ![]()
Excellent point, this has nothing to do with the rider. | |
| MotoGP Contender Joined: Apr 2007 From: soap lake wa. I Ride: 00kaw12r, 97 tls1000, 96gsxr1260 turbo freakshow, kz1300gt, 94 cbr1000f, 88gsxr1100, 86gsxr750, 82gsx1100ez, 79kz1300, 75 ducati750gts, 72 gt550 cafe | Good point!!!!!!! Back in the day...Trumps dyno'd out w/ one map for tech acceptance, then a way hotter second map was engaged, by pushing at a seat point. I do see "plausible deniability" for Josh. He still looses the points for the race tho.If a rider "knows' does/ can he refuse to ride the bike?... never heard of that. They might have had to go thu tear down scutiny, to establish the mod is legal, so... it could have been cake and eat it too. Another potential cheat story, back in the day.A kawasaki was teched and found to have "hand finished intake ports" the factory explained ALL bikes of this model have it... dang'd if they did, OK!!!!!!!! "Cheating" (creative rules interpritation) is an institution, in ALL type race'n, world wide. I feel a rider has a pretty good idea whats going on... especialy if the bike is obviously that much faster. Everybody knows it's the wrenches/ factory, that is doing the "sneeky pete" It shouldn't hurt his carear. In fact NO factory would consider a rider that wouldn't keep his mouth shut. Free and clean, Ripp'n |
| WMRRA Qualifier Joined: Apr 2008 From: Burien,WA I Ride: '04 CBR 1000rr '93 VFR750F '74 CT90 k4 | TSK,TSk. |
| | #10 | |
| Moderator ![]() Joined: Feb 2005 From: lynnhood I Ride: KTM 625 smc | TL1000S/R | wr450 | CRF50/88 | TTR50 | your mom | ![]()
I'd assume (yes assume) that Josh had ridden many configurations early on in season testing.. and he may not have known exactly what was going on.. when he suddenly got faster he might have noticed something... just playing devils advocate. I don't think he carries by any means the majority of the blame. (I put the erion name on that one) but to claim he's completely innocent? | |
| | #11 | |
| Superbiker Joined: Nov 2005 From: Rathdrum, ID I Ride: cause I'm a Loowwlife | ![]()
For clarification, I didn't see the race, and this is the first I've heard of anything, I'm just saying ya know. | |
| | #12 | |
| MotoGP Contender Joined: Oct 2005 From: Issaquah, WA I Ride: Race: 05 GSXR750 - Street: 06 GSXR750 | ![]()
Josh didnt "suddenly" get faster. I can almost guarantee that a large majority of the riders in AMA, MotoGP, WSBk, etc have zero clue what has been done to their motors/bikes. Thats there team/sponsors responsibility. Their responsibility is to ride the bike and win races. They give input as far as handling, etc and the team makes improvements. I blame 100% Erion Honda for this incident. | |
| | #13 | |
| MotoGP Contender Joined: Sep 2005 From: Bellevue, Wa I Ride: Aprilia Mille R, Gixxer 600, Yamaha WR250, Yamaha TTR125 | Interesting process they used on the crankshaft. It would be funny if Honda decides to incorporate the Mikronite process in their stock bike. Sucks that this happened to Josh. Great guy that always has a smile on his face... From that website: ![]()
| | #14 | |
| Moderator ![]() Joined: May 2007 From: the Westside I Ride: only on the center of my tire. | ![]()
