| Training Wheels Joined: Feb 2011 From: Seattle, WA I Ride: Triumph Tiger 800xc | The only way not to see the stairs is to keep your eyes closed the whole time you're there. |
| | #27 | |
| Shredder | ![]()
They are where the road runs out at Windy Ridge. You will see them. The folks coming down when we were there yesterday said they counted 405 of them. Last edited by Mrmat25; 07-14-2012 at 04:55 PM.. | |
| | #28 |
| Peg Dragger Joined: Aug 2005 From: Vanquivering with Kevin in WA. I Ride: Kawasaki Z1000; Yamaha RZ350 (2); Yamaha RD400 (2); Yamaha RD350 (2); Yamaha RD125; Yamaha RD60; Kawasaki '72 G5-100; '66 Suzuki X-6 Hustler FINALLY!! | Windy Ridge road (NF99) is 17 miles from the start where you turn off 25, 'til the end @ the parking lot, so 34 miles R/T. |
| | #30 |
| Permit Joined: Oct 2010 From: Vancouver Wa I Ride: Multistrada 1200 | The area at the end of 99 is in the restricted "monument zone" where the penalty for rididng is death. The good news is that outside of that zone within the Gifford Pinchot NF there are hundreds of miles of roads and trails of varying terrain and difficulty. |
| | #31 |
| Shredder | Google maps shows NF 99 going farther than it actually does. The pavement ends at the parking lot and the road goes to gravel there, and is gated. The only road coming off of NF-99 is NF-26. It is paved, but goes to single lane and reportedly has a few short sections of gravel on it. NF-26 runs from NF-99 back to NF-25 about a mile or so North of the NF-99/25 junction. Also, in regards to fuel: If your bike can go at least a solid 100 miles on a tank of gas, then you should have no problem getting up to Windy Ridge and back, so long as you top off in Randle (if coming from the North), or Cougar (if from the south) before heading up. Additionally, if coming from the south, you will first have to go to Randle to top off, before heading back to Cougar. The Eagle Cliff store (a couple miles NE of the Pine Creek Ranger Station, on NF-90) Sometimes has fuel available, but I haven't noticed the 'Fuel Available' sign the last few times I went by there. |
| | #32 |
| Permit Joined: Jun 2012 From: Lakewood, WA I Ride: 2011 Honda CBR250R & 2011 Honda CBR600RR | How do you feel about hitting randle going through nf99 then head back and go down to cougar? Will there be enough gas for just one trip or would I have to head to randle again before I go all the way down? |
| | #33 |
| Shredder | ![]() 34 miles on 99 (up and down). 46 miles from the base of 99 to Cougar. 106 miles total it looks like. vs. 126 miles RT from Cougar up 99 and back 99 to Cougar. With a CBR 600 RR you should be good either way. 25 down from Randle is pretty beat up though. Last edited by Mrmat25; 07-15-2012 at 02:34 PM.. |
| | #35 |
| Shredder | I think I ran into about 6-8 sections of gravel, ranging from 10 to 30 feet. For the most part I just pulled in the clutch and coasted through them. One was pretty choppy though so I stopped completely and went through it in 1st with my feet down. There was one that popped up right after a turn though so I was glad we were taking it easy. All in all it was an interesting road to explore, but I will have no reason to ever ride it again. |
| | #36 | |
| Peg Dragger Joined: Aug 2007 From: West Linn, Oregon I Ride: Dirty | ![]()
| | #37 |
| Shredder | Just rode it Friday (7/13) and yep the washout was repaired. |
| | #38 |
| Shredder | ![]() Secondly, how well do you know your bike (CBR600)? According to 'Motorcycle-USA' you have a 4.8 gallon tank, and according to their testing they got 33 mpg. This means that you should be able to go upwards of 158 miles between fuel stops (assuming your bike can access all the fuel). Even if your not getting at least 33 mpg, you should be able to at least get a solid 140 miles on a full tank if at least getting 30 mpg. The key point here is that you should have no problem making Windy Ridge and beyond. In fact, if you top off in Randle, after hitting Windy Ridge you should have the range to make it to Carson or Trout lake easily. Simply put, your not limited to just going to Cougar because you have to get fuel. Those coming from the south are a bit more limited. We typically advise this: Cougar > WR > Randle: Bike must have a range of 100+ miles. Cougar > WR > Cougar: Bike must have a range of 120+ miles. Cougar > WR > Carson: Bike must have a range of at least 140+ miles. Cougar > WR > Trout Lake: Bike must have a range of 155+ miles. Hope this helps. |
