| Peg Dragger Joined: Mar 2011 From: here going there. I Ride: because I can. | Looks like you've got a good winter project. Compression problem and it is smoking? It does sound like rings. Could be valves, I'd check them anyway. Start hunting down somebody that can pull the engine down for (or with) you. Do you have a shop manual for this thing? |
| | #22 | |
| Endorsed Joined: Apr 2012 From: Bonney Lake, Wa I Ride: 79 Suzuki GS850G | I'm putting some gas in the tank today and I'm gonna try that. ![]()
I do have a shop manual. By pull it down do you mean take it apart? The mechanic slang isn't one of my areas of knowledge. Also, my dad is kinda like Don Corleone. He always knows a guy. He's talking to one of those guys to see what that guy thinks and if he'd be willing to take a look. | |
| Training Wheels Joined: Apr 2012 From: Port Angeles I Ride: 2010 R1 Vale' Edition, '86 GTR1000 | need 2 pull the cover off and check valve clearance and cam lobes for wear. sound fairly catastrophic...if the cams show no wear and your clearance is bad, the valve seats or valves themselves are burning out |
| Endorsed Joined: Apr 2012 From: Bonney Lake, Wa I Ride: 79 Suzuki GS850G | The valve clearances were pretty good when I checked them, but I'll do it again. |
| Licensed Joined: Jul 2012 From: Spanaway, Wa I Ride: PS1000LE | Like posted before try running the bike on the prime position. If no improvement pull the fuel line to see if fuel flows freely when petcock is placed in prime position. If fuel just dribbles out, remove the petcock. The internal screen attached to it could be plugged and needs cleaning. Let's ensure good fuel flow first to rule that out as a problem. |
| | #26 | |
| Peg Dragger Joined: Mar 2011 From: here going there. I Ride: because I can. | ![]()
| Novice Racer Joined: Apr 2007 From: Youngstown NY I Ride: Speed Triple, GS750, KX 500, 450 EXC-R, KH400, MXZ 700 Renegade | Before you spend too much money, find somebody who knows how to check compression. Your story about the other guy sounds fishy. maybe he had a bad gauge. if it DOES turn out to be a bad piston/ring/cylinder...........it's prolly cheaper to jut buy a used engine, and then save up for a rebuild on that one. |
| | #29 |
| Licensed Joined: Sep 2010 From: beaverton or I Ride: 82 honda sabre v45 | [QUOTE=DevanJones;2833772]I'm putting some gas in the tank today and I'm gonna try that. Which Slick 50 product? And the car was leaking oil so my dad and I sprayed it down with engine degreaser and then rinsed it off at a car wash to find the leak. Then my dad pulled out one of my spark plugs since it had some oil around it's base and there was quite a bit of oil in it. We think either oil got somewhere it shouldn't when he removed the plug or water got somewhere it shouldn't when we rinsed. We pulled the distributor cap and it was pretty rusty but we're gonna work on it more today. i know if u look at there oil treatment one it say helps rings and seals, thats why i was thinking that. the oil leak on the car into the spark plug areas sounds like the seals and valve cover gasket, and u more then likely got water in a connection or dist and when that happens cars dont like to start, i did that to my daughters car and had to replace plugs and clean them all out there was water sitting in them, then the car started and ran alot better, |
| | #30 | |||
| Endorsed Joined: Apr 2012 From: Bonney Lake, Wa I Ride: 79 Suzuki GS850G | ![]()
| | #31 |
| Shredder Joined: May 2011 From: Tacoma, Wa I Ride: 2008 Buell 1125R | ![]() ![]() |
| | #34 |
| Endorsed Joined: Apr 2012 From: Bonney Lake, Wa I Ride: 79 Suzuki GS850G | I'll be there. |
| | #35 |
| Shredder Joined: Jul 2008 From: Cornelius, Oregon I Ride: Everyday | 30K would be surprised if it were rings that is low miles for that bike. Sounds like an issue with valve or a leaking gasket. If it sat for awhile not running the gaskets could have dried and cracked. The result would cause a leak air/oil could get into the cylinder and cause that type of issue. |
| | #36 | |
| | #37 |
| Railer ![]() Joined: Jan 2008 From: teh rock | Don't put majick stuff in the oil. Just don't. Whatever it is that it's supposed to do... the same oil in the crank case is splashing through your clutch too. No telling what it will do to that. |
