'02 R1 hot idle issue
Discussion in 'Mechanical & Technical' started by Maniac 954RR, Jul 30, 2012.
  1. Been putting together project. PO repaired cylinder head and wouldn't run. Cams and cam chain were incorrect, so I fixed and put the bike back together. It now starts easily and runs fine, however at normal and hot engine temps the bike will not idle. Idles fine when cold. Any ideas would be greatly appreciated.
  2. RedKat600
    What do you mean by repaired cylinder head?
  3. Irrelevant to the current issue, however I believe he had frame sliders on it and he laid it down, cracking the head (frame sliders install on upper engine mount bolt and would push it right into the head where the head was cracked) at a water jacket, causing coolant leakage. The head was welded.
    Anyone reading this story should not install frame sliders with that design LOL (or remove them if they have them installed); easier to replace the fairing than the cylinder head. Same thing happened to someone else on these forums on a newer R1 as well.
  4. RedKat600
    Sounds like a vacuum leak or tight valves to me honestly.
  5. Valve clearances are correct, but you might be on to something with the leakage.. A poor seal between throttle bodies and cylinder intake could certainly cause that symptom. Thanks for reminding me as I completely overlooked that! Little carb cleaner around the intake boots should confirm or refute :)
  6. A lean condition will allow you to set idle when cold and it will rise with temp.
    Are the pilot air screws set correctly?
  7. RedKat600
    2002 is FI....no carbs.
  8. Hmmm.
    I thought 03 was the first FI or was that just the R6's?
  9. RedKat600
    2002 was R1...2003 was R6. I do believe.
  10. Sounds like a leak to me as well.Ever sync the tb's??
  11. No, but I probably should. Ill do that when i pull the top apart to check for any poor seals. Thanks!
    For anyone interested here is a great guide.
04 R6 idleing issues Mechanical & Technical Apr 9, 2012
2005 Ninja 250 Idle Issues Mechanical & Technical Apr 21, 2011
idle issue question Mechanical & Technical Mar 30, 2009
03 R1 Idle speed issue.. Mechanical & Technical Jun 11, 2007
DT175 Idle Hanging While in Gear Mechanical & Technical May 26, 2016
