09 Ninja 250 Cruising RPM's
Discussion in 'Motorcycle Talk' started by Aj555, Aug 11, 2012.
  1. Hey everyone! Ive been riding my ninja for the past month (obviously a new rider) and certainly noticed that cruising speeds for the ninja is around 7500/8k rpms. I was just wondering is it ok for the bike to be cruising around 9250/9800 rpms for a long distance?
    Im planning to go to Seattle - Spokane to visit my friend and rather get their in a shorter time so cruising speed around 80.
    **About 300 miles, near 5 hours following speed limit**
    Thanks!
  2. No..the RPM's won't hurt the Ninja at all, having said that....I did go 1 tooth up on the CSS on my 10' Ninja 250 8)
  3. on my '03 250 I went to Salem an back this past June....averaged 80-85 mph@10k +/- rpm's............seemed to be ok...other than my miles per gallon dropped a little...went from 65-68 mpg...down to 60 mpg.....the 250 is a good little motor and can handle the rpm's.....they have been making them for so long, they have a pretty good life expectancy considering the rpm's that they will be run at!....
  4. No problems. I had my 04 at 11k+ for over 200 miles without a problem. It burnt a negligible amount of oil at high speeds over these kinds of trips(maybe 1mm on the sight glass).
  5. Ok sick, Thanks guys! Yeah wasnt sure and all cause i have cruised around 10k for a few miles and it sounded like i was about to kill the engine, but sounds like its pretty solid. Thanks again!
  6. it does take a little getting used to the high rpm's sounds....but they do hold up very well....
  7. that where you want to be!.....
2012 Ninja 250r Motorcycles Nov 23, 2016
2015 Ninja 650 ABS. 680mi, Warranty! $4500 Motorcycles Nov 21, 2016
2013 ninja 300 Motorcycles Nov 11, 2016
2009 Ninja 250 part out Gear, Parts, & Accessories Sep 26, 2016
2015 Kawasaki Ninja 300 ABS (white) Motorcycles Aug 31, 2016
