2001 triumph 600tt street fighter 1300obo
Discussion in 'Motorcycles' started by tantoquez, Feb 6, 2014.
  1. tantoquez
    tantoquez
    Expand Collapse
    3
    51
    Orting, WA
    I have a bike that runs great. Problem is that it wont go into gear. The bike Starts and runs fine but everytime i put it into gear then it kills it. I think the clutch is frozen but I'm not sure. Also i have the title and bill of sale made out to me but just never got around to putting it in my name. I dont have the time,money, or knowledge to fix it. Im looking to sell it for 1300 obo
  2. RedKat600
    RedKat600
    Expand Collapse
    Vintage Screwball
    Staff Member
    11,895
    73
    1,178
    Kickstand switch is shot. easy fix.
  3. nakedinseattle
    nakedinseattle
    Expand Collapse
    4,808
    63
    778
  4. tantoquez
    tantoquez
    Expand Collapse
    3
    51
    Orting, WA
    Would that cause the clutch not to work when the bike isnt running and in gear and still wont roll?
  5. tantoquez
    tantoquez
    Expand Collapse
    3
    51
    Orting, WA
    Im not computer savvy enough to get them from my phone to the forum
  6. Deacon71
    Deacon71
    Expand Collapse
    391
    116
    Salem
    I Ride:
    2001 GSXR 600
    You could text the pics to your email address, then save them from there.
  7. Red Label Moto
    Red Label Moto
    Expand Collapse
    3,073
    53
    678
    Seattle
    Looks like a fair deal. ttt.
  8. Insan3guy
    Insan3guy
    Expand Collapse
    138
    86
    SE Olympia
    will the kickstand switch stop the engine before the clutch gets let out?
    edit: while it's not moving, will it kill the engine if the clutch is still held in and it gets put into gear?
    I went to look at it today and it won't even roll forward in gear with the clutch in. (the wheel drags) Not sure if the kickstand can do that with the engine off
    #8 Insan3guy, Feb 6, 2014
  9. tunus
    tunus
    Expand Collapse
    2,726
    18
    593
    Beaverton, OR / Bellevue, WA
    I Ride:
    the slow kind fast.
    Yes. It's designed to prevent you from riding away with the kickstand down. The OP can unplug the switch and jump the two terminals to confirm that it is indeed the switch killing the engine.
  10. tunus
    tunus
    Expand Collapse
    2,726
    18
    593
    I Ride:
    the slow kind fast.
    Now that I think about it, if the kickstand is down, the engine will stop as soon as you put it in gear. I have a Triumph and that's what they do. Other bikes will allow you to put the bike in gear with the kickstand down, but will die as soon as you begin releasing the clutch.
  11. Insan3guy
    Insan3guy
    Expand Collapse
    138
    86
    SE Olympia
    that's what my 250 did. you can keep the kickstand down and put it in gear but as soon as you release the clutch the engine stops.
  12. RedKat600
    RedKat600
    Expand Collapse
    Vintage Screwball
    Staff Member
    11,895
    73
    1,178
    Eh, engine off, clutch in, in gear, won't roll? That's normal for a lot of bikes, actually, to have the rear wheel drag in that situation. Well, some drag not immobile.
    The only accurate way to test a clutch is with the bike in gear. Just find the kickstand switch and hook the two wires coming from the harness together. NOT the wires from the switch. That will bypass it and I'm 99% certain fix the "put it in gear immediately dies" issue. If it doesn't, then the clutch cable either needs adjusted or it needs a new clutch as the plates are probably stuck together.
  13. EmptiMind
    EmptiMind
    Expand Collapse
    49
    56
    Spokane Valley
    Kind of wish you were closer to me, I'd help troubleshoot the bike. I love Triumphs, even if it was a clutch issue, I'd still consider picking this guy up.
  14. racin600r
    racin600r
    Expand Collapse
    308
    216
    Renton,Washington / Napa California
    My r1 is the same. If my kickstand is down..The bike won't start or it kills the engine. Good safety feature to have though!!
    Sent from my SCH-I605 using Ohub Campfire mobile app
  15. ~JM~
    ~JM~
    Expand Collapse
    243
    186
    PDX
    I know this sounds overly simple, but the first thing that I would do is to change the oil to a motorcycle specific oil or Rotella. Then start the bike & let it completely warm up. Now excercise the clutch by pulling in the clutch lever & holding it in while the engine is running, then release it. Repeat this several times without trying to put the bike in gear. After you have excercised the clutch several times, try shifting into first gear. Does it still die?
    Sounds like you might have a "tight" clutch. Does the bike usually make a loud clunk & move forward a little bit when you first try to ride it after a cold start?
    If you get in the habit of letting it warm up & excercise the clutch a few times before you try to put it in gear, you won't have this problem any longer.
    Good luck
    ~JM~
  16. ~JM~
    ~JM~
    Expand Collapse
    243
    186
    PDX
    Wish you were closer to the Portland area.
    I wouldn't mind buying that bike.
    Good luck
    ~JM~
  17. ~JM~
    ~JM~
    Expand Collapse
    243
    186
    PDX
    NO! A bad kick-stand switch would not cause what you are describing.
    Stupid feature to begin with, especially if it shorts out during a turn. If you can't remember to put your kick-stand up properly, you shouldn't be riding in the first place.
    ~JM~
  18. Sentor
    Sentor
    Expand Collapse
    5,641
    1,116
    Beaverton, OR
    I know this sounds weird, but if his tires are flat/really low on air, he will have a much harder time rolling the bike as well.
  19. Insan3guy
    Insan3guy
    Expand Collapse
    138
    86
    SE Olympia
    tires aren't what is keeping the bike from rolling. they're properly inflated
  20. RedKat600
    RedKat600
    Expand Collapse
    Vintage Screwball
    Staff Member
    11,895
    73
    1,178
    Then you either have a bad kickstand sensor switch, a mis-adjusted clutch cable or a bad clutch. All easy fixes, if you are interested in his bike.
2001 triumph tiger 955i $4000 Motorcycles Jul 30, 2013
2001 Triumph TT600 Motorcycles Jul 23, 2013
2001 Triumph Speed Triple $3750 Motorcycles Mar 22, 2013
2001 Triumph TT 600.. beauty with all the kit. Motorcycles Mar 28, 2010
2001 Suzuki GSXR-1000 $3200 OBO Motorcycles Jan 21, 2016
