FS: 2002 SV650 Part out
Discussion in 'Gear, Parts, & Accessories' started by st.mats, Apr 15, 2016.
Tags:
  1. Feel free to shoot me offers. I take PayPal and am happy to ship.
    Forks 1-2mm out of true $70
    Carburetors $80
    Top Triple Clamp with Ignition and key $60
    Starter Motor $55
    Gauge Cluster/ Speedometer $60
    Airbox with K&N filter $50
    Right side Engine and Clutch cover and Water Pump $35
    Valve Covers $35
    Pair System w/canister and tubes $25
    Fairing Stay / gauge mounts (bent slightly) $20
    Rear Seat (scuffed) $30
    Rear Undertail fender, License Plate Light $30
    Clear Wind Screen $20
    Rear Center Fairing (needs Post glued back on) $20
    Right Side Controls / Throttle Tube $25
    Wiring Harness (original condition) $25
    Misc Bolt and fasteners and fairing brackets $20
    Ignition Coils (pair) $20
    Rear Turn Signals (pair) $20
    Secondary Fuel Petcock vacuum valve $20
    Cam Chain Adjusters $15 for pair.
    Speedometer sensor and wire (rotor broken) $10
    Rear Caliper, mount, hanger $15
    Rear Subframe (a little bent, but hard to notice when bolted in) $20
    Sprocket carrier $15
    Inside Upper Fairing Trim $15
    passenger pegs $10/each
    Regulator $20
    Front Signals (maybe OEM?) $15
    Rear Brake Master Cylinder, reservoir and brake line $15
    Rear Brake brace Stay $15
    Radiator Fan $15
    Axle/chain adjusters $12 for both.
    Side Stand with switch $12
    Headlight and gauge wiring harness $10
    Rear axle and spacers $10
    Front Axle and Spacer $10
    Thermostat Housing and hoses $10
    Overflow Tank $10
    Oil Temp Sensor $8
    Rear Tire mud guard $9
    Starter Solenoid and starter wires $10
    Horn $5
    Rear Brake switch $5
